Reefhermit
A new installation of Arduino 1.6.12 & Teensyduino 1.34 on RPi 3 . . Cannot get the blink to load on the 3.2.
Loaded blink onto 3.2 with windows and works fine. Switched over to RPi 3 and the LED is blinking, however, when I upload the sketch from RPi 3 the blinking stops and does not continue.
I did follow the 1st time instructions for loaded a sketch!
The default serial port on RPi3 is /dev/tty/AMAO . . Correct?? The other serial port is /dev/ttySO ??
Any help would be appreciated
BTW - I did not install this: sudo cp 49-teensy.rules /etc/udev/rules.d/ . . . . . as described in the installation instructions for Linux?
If this is required is it necessary to run from a specific Dir? I did run from the root Dir but it could not find 49-teensy.rules.
Any advice would be appreciated.
Thanks,
Ken
Thanks,
Ken
