Soo I am after taking time away from my lightsaber project I am back at it but redesigning it from the ground up including trying to make it much more compact. Starting with using the teensy 3.6, the teensy prop shied, a 4ch pico buck based on the Sparkfun 3ch one that I found on OSHpark (https://oshpark.com/shared_projects/cMroyCWV) and hopefully i'd like to add Adafruit Bluefruit LE UART Friend -BLE so i can change settings via my phone and what ever other tiny parts that might be required like a clash sensor, an adjustable regulator etc.. With all that said I am still quite the noob at this stuff, haven't studied up on it as much as i should have over the last year. The crux of my issue is the space requirements of my design don't give me to much room to work. I have a 4 cell 2S/2P 18650 battery pack and the above eletronics to fit inside a 1.45 to 1.50in ID tube and about 6 inches long space. I might be able to fit a pcb/header/teensy stacked configuration and spread out over about 6 inchs in length with a couple of the smaller boards on the opposite side as well. The height and width is really tight and i can't expand the size of the tube and still hold it.
Long intro aside i am wondering if I can seat/directly solder like a SMD the teensy, prop shield, and other parts and connectors to a PCB without using headers that I would design to make all the connections between boards that I need and just plain convenience to limit how many wires I have connecting between devices. I assume it would be a more secure connection and be more reliable and i could design it more to my needs. I obviously don't have the abilty to do anything super complicated at this point and i am not wanting create any new dev board but just adapt the ones available to me. Instead of stacking them they would be laid end to end one boards one after another. I would still need to make some modifications anyways since the connections on the prop board dont quite match the 3.6 anyways all in all if its possible that would make things a lot cleaner. I'm not sure if there is a term from what i am describing and that limits my reseach options on how to do this. Also is there a eagle file of the back side traces of the teensy 3.6 and prop shield that i could use to line things up in the design software? Any advice, thoughts, etc?
Things also to think about is if it's possible to jack into the micro USB connector on the teensy and move the connector to the end of the board else I would need to get some super slim extension cable since it or the micro sd card would be trapped up against the prop shield.
Also, I noticed on the teensy 3.6 it says the pins aren't 5v tolerant yet the Vin is labeled as 3.6v to 6v. Can i assume that the vin is regulated and its just talking about the other pins that can't have higher voltage's attached to them? (i.e. over 3.3v 250ma) It is a little confusing since i can't see a reason why i would feed electricity into the board except via the main Vin. Wouldn't any power crossing those pins be coming from the board itself going out to power other devices like the prop shield for example, or accent led's etc. My led driver for the main rgbw star would be taking power from the battery pack not through the teensy, only using the pwm's to adjust colors.
I know enough to be dangerous about this stuff but in most things its a process of figurung things out one bit at a time.
Grimmdus
Grimmdus
