Hi- I built a midi controller using the teensy 2.0 and am having trouble reading usbMIDI in and echoing it over to the Serial1.
This is what I have been trying (in many variations) :
None seemed to worked so I tried this, which I got/modified this from arduino midi library sketch-
- doesnt compile. so I tried something like this:
- compiles but doesnt work
Sending usbMIDI OUT works perfectly in my controller code and the 'Blink w/ NoteOn' demo sketch works fine, so I know that hardware/ cables are good and usb midi is being received.
Seems like a fair straight forward thing...Clearly im missing something.
thanks in advance
here is the complete code, just in case:
if (usbMIDI.read() > 1)
inByte= usbMIDI.read();
Serial1.write(inByte);
if (usbMIDI.read())
Serial1.write(usbMIDI.getType(),
usbMIDI.getData1(),
usbMIDI.getData2(),
usbMIDI.getChannel());
// Thru on A has already pushed the input message to out A.
// Forward the message to out B as well.
inByte=usbMIDI.getType();
inByte=usbMIDI.getData1();
inByte=usbMIDI.getData2();
inByte=usbMIDI.getChannel(),
thanks in advance
// control pins output table in array form
// connect 74HC4067 S0~S3 to: PortA =Arduino Mega D29-D26; PortD= UNO- D7~D4; and Teensy- D22,D23,D12,D11 ...... respectively
const byte CCnums [] PROGMEM {16,21,17,22,18,23,24,19,25,20,
26,31,27,32,28,33,34,29,35,30,
36,41,37,42,38,43,44,39,45,40,
46,51,47,52,48,53,54,49,55,50,
59,58,57,56,63,62,60,61,64,65,66,67,
70,68,69,71,72,74,73};
byte CCvals [59] {};
byte SavedCCvals [59] {};
#include <EEPROM.h>
//#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
// midi globals
byte CHANNEL= EEPROM.read ( 24 );
#define CC 0xB0
byte inByte = 0;
byte cmd =0;
byte lastCmd =0; // for running status, do'y send command if same as last time
byte messageCnt = 0;
byte ctrlSend = 0 ;
bool note=0;
byte velocity=0;
byte velocityDest=0;
//byte aftertouchDest;
byte LFOwave;
byte algorithm;
byte incomingMidiByte;
byte previousMillis = 0;
byte preset = 0;
const char Saw [] {"Saw" };
const char Squ [] {"Square"};
const char Tri [] {"Triangle"};
const char Noi [] {"Noise"};
const char *LFOwaveShape [] {Saw, Squ, Tri, Noi};
#define MUXSEL0 12
#define MUXSEL1 11
#define MUXSEL2 23
#define MUXSEL3 22
const byte controlPins[] PROGMEM = {B00000000,
B10000000,
B01000000,
B11000000,
B00100000,
B10100000,
B01100000,
B11100000,
B00010000,
B10010000,
B01010000,
B11010000,
B00110000,
B10110000,
B01110000,
B11110000 };
byte buttonState5[16] = {0}; // current state of the button
boolean lastButtonState5[16] = {0};
byte buttonCounter5[16] = {1};
byte buttonState6[16] = {0}; // current state of the button
boolean lastButtonState6[16] = {0};
boolean buttonCounter6[16] = {0};
byte muxValues1[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};// holds incoming values from 74HC4067
byte prevMuxValues1[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte muxValues2[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte prevMuxValues2[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte muxValues3[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte prevMuxValues3[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte muxValues4[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte prevMuxValues4[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte muxValues5[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte prevMuxValues5[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte muxValues6[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
byte prevMuxValues6[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
/////// MUX channel = 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
const byte CCBankOP1[] PROGMEM = { 0, 0, 16, 21, 17, 22, 18, 23, 24, 19, 25, 20, 0, 0, 0, 0};
const byte CCBankOP2[] PROGMEM = { 0, 0, 26, 31, 27, 32, 28, 33, 34, 29, 35, 30, 0, 0, 0, 0};
const byte CCBankOP3[] PROGMEM = { 0, 0, 36, 41, 37, 42, 38, 43, 44, 39, 45, 40, 0, 0, 0, 0};
const byte CCBankOP4[] PROGMEM = { 0, 0, 46, 51, 47, 52, 48, 53, 54, 49, 55, 50, 0, 0, 0, 0};
const byte CCBankCOM[] PROGMEM = { 0, 0, 59, 58, 57, 56, 63, 62, 60, 61, 64, 65, 66, 67, 0, 0};
const byte CCBankLFO[] PROGMEM = {74, 0, 0, 0, 0, 73, 0, 0, 0, 0, 70, 68, 69, 71, 72, 76};
const byte ledPin5[] PROGMEM = {0, 0, 3, 24, 4, 10, 9, 0, 2, 1, 0, 0,0,0,0,0,}; //pins that control button LEDs
const byte ledPin6[] PROGMEM = {14, 0, 0, 0, 0, 15, 0, 0, 0, 0, 0, 0,0,0,0,0,};
typedef struct {
uint8_t status; // first byte : status message (NOTE_ON, NOTE_OFF or CC (controlchange) and midi channel (0-15)
uint8_t data1; // second byte : first value (0-127), controller number or note number
uint8_t data2; // third byte : second value (0-127), controller value or velocity
t_midiMsg; // We call this data type 't_midiMsg'
void setup(){
Serial1.begin(31250);
pinMode(MUXSEL0,OUTPUT);
pinMode(MUXSEL1,OUTPUT);
pinMode(MUXSEL2,OUTPUT);
pinMode(MUXSEL3,OUTPUT);
pinMode (15, OUTPUT);
pinMode (14, OUTPUT);
pinMode (10, OUTPUT);
pinMode (4, OUTPUT);
pinMode (24, OUTPUT);
pinMode (3, OUTPUT);
pinMode (2, OUTPUT);
pinMode (1, OUTPUT);
pinMode (0, OUTPUT);
pinMode (9, OUTPUT);
pinMode (A0,INPUT);
pinMode (A5,INPUT);
delay(100); // needed for OLED on teensy
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3D (for the 128x64
display.display(); // Show image buffer on the display hardware.
display.invertDisplay(true);
display.clearDisplay(); // Clear the buffer.
for (byte i = 2; i < 10; i++){
if ( EEPROM.read ( i-2 ) != 0xff ){ // If Eeprom slot is not blank...
buttonCounter5[i] = EEPROM.read(i-2); // Remember Button States from when it was last powered
for (byte i = 0; i < 16; i++){
if ( EEPROM.read ( i+8 ) != 0xff ){ // If Eeprom slot is not blank...
buttonCounter6[i] = EEPROM.read(i+8); // Remember Button States from when it was last powered
display.invertDisplay(false);
ReadPots();
MidiSendAll();
void setPin(int outputPin){ // function to select pin on 74HC4067
byte b = pgm_read_byte_near(controlPins + outputPin);
if (b & 0x80) digitalWrite(MUXSEL0,HIGH);
else digitalWrite(MUXSEL0,LOW);
if (b & 0x40) digitalWrite(MUXSEL1,HIGH);
else digitalWrite(MUXSEL1,LOW);
if (b & 0x20) digitalWrite(MUXSEL2,HIGH);
else digitalWrite(MUXSEL2,LOW);
if (b & 0x10) digitalWrite(MUXSEL3,HIGH);
else digitalWrite(MUXSEL3,LOW);
void loop(){
MidiMerge();
usbMidiMerge();
unsigned long currentMillis = millis(); //check the pots only every x millis
if (currentMillis - previousMillis >= 100) {
previousMillis = currentMillis;
ReadAndSend();
void ReadAndSend(){
for (byte i = 2; i < 12; i++){
setPin(i); // choose an input pin on the 74HC4067
muxValues1[i]=map(analogRead(A2), 0,1024,0,128); // read the vlaue on that pin and store in array
muxValues2[i]=map(analogRead(A1), 0,1024,0,128);
muxValues3[i]=map(analogRead(A4), 0,1024,0,128);
muxValues4[i]=map(analogRead(A3), 0,1024,0,128);
if (muxValues1[i] != prevMuxValues1[i]){
t_midiMsg msg;
msg.status = CC; //For OP boards #1-4
msg.status = msg.status | (CHANNEL-1);
msg.data1 = pgm_read_byte_near(CCBankOP1 + i); // Get the controller number from the array above.
msg.data2 = muxValues1[i]; // Get the value of the analog input from the analogVal array.
// CCvals[] = muxValues1[i];
Serial1.write((uint8_t *)&msg, sizeof(msg)); // Send the MIDI message.
usbMIDI.sendControlChange(pgm_read_byte_near(CCBankOP1 + i), muxValues1[i], CHANNEL); //// Send the usbMIDI message.
prevMuxValues1[i] = muxValues1[i];
if (muxValues2[i] != prevMuxValues2[i]){
t_midiMsg msg;
msg.status = CC;
msg.data1 = pgm_read_byte_near(CCBankOP2 + i);
msg.data2 = muxValues2[i];
usbMIDI.sendControlChange(pgm_read_byte_near(CCBankOP2 +i), muxValues2[i], CHANNEL);
prevMuxValues2[i] = muxValues2[i];
if (muxValues3[i] != prevMuxValues3[i]){
t_midiMsg msg;
msg.status = CC;
msg.data1 = pgm_read_byte_near(CCBankOP3 +i);;
msg.data2 = muxValues3[i];
usbMIDI.sendControlChange(pgm_read_byte_near(CCBankOP3 +i), muxValues3[i], CHANNEL);
prevMuxValues3[i] = muxValues3[i];
if (muxValues4[i] != prevMuxValues4[i]){
t_midiMsg msg;
msg.status = CC;
msg.data1 = pgm_read_byte_near(CCBankOP4 +i);
msg.data2 = muxValues4[i];
usbMIDI.sendControlChange(pgm_read_byte_near(CCBankOP4 +i), muxValues4[i], CHANNEL);
prevMuxValues4[i] = muxValues4[i];
for (byte i = 2; i < 10; i++){ //For COM Board #5 - read Switches
setPin(i);
buttonState5[i] = map(analogRead(A0), 0,1024,0,2);
if (buttonState5[i] != lastButtonState5[i]) {
if (buttonState5[i] == 0) {
buttonCounter5[i]++;
EEPROM.write (i-2, buttonCounter5[i]);
lastButtonState5[i] = buttonState5[i];
if (buttonCounter5[i] % 2 == 0) { //every other state change
buttonCounter5[i] = 0;
muxValues5[i]= 127;
digitalWrite(pgm_read_byte_near(ledPin5 +i), HIGH);
else {
muxValues5[i]= 0;
digitalWrite(pgm_read_byte_near(ledPin5 +i), LOW);
if (muxValues5[i] != prevMuxValues5[i]){
t_midiMsg msg;
msg.status = CC;
msg.data1 = pgm_read_byte_near(CCBankCOM +i);
msg.data2 = muxValues5[i];
usbMIDI.sendControlChange(pgm_read_byte_near(CCBankCOM +i), muxValues5[i], CHANNEL);
prevMuxValues5[i] = muxValues5[i];
for (byte i = 10; i < 14; i++){ //COM Board #5 -Read Pots
setPin(i);
muxValues5[i]=map(analogRead(A0), 0,1024,0,128);
t_midiMsg msg;
msg.status = CC;
if (prevMuxValues5[13] != muxValues5[13]){
algorithm = map (muxValues5[13], 0,128,0,8);
for (byte i = 14; i < 16; i++){ //For COM Board #5 -read last 2 menu Switches (no Midi messages sent, no LEDS)
setPin(i);
if (buttonState5[i] == 1) {
if (buttonState5[14] == 1) {
MidiSendAll();
if (buttonCounter5[15] % 2 == 0){
buttonCounter5[15]= 0;
mainScreen();
else {
Menu();
for (byte i = 5; i < 6; i++){ //For LFO Board #6 - read Switches
setPin(i); // other switch is mux #0 for (i=0; i<6; i+5){
buttonState6[i] = map(analogRead(A5), 0,1024,0,2);
if (buttonState6[i] != lastButtonState6[i]) {
if (buttonState6[i] == 0) {
buttonCounter6[i]++;
EEPROM.write (i+8, buttonCounter6[i]);
lastButtonState6[i] = buttonState6[i];
if (buttonCounter6[i] % 2 == 0) { //every other state change
buttonCounter6[i] = 0;
muxValues6[i]= 127;
digitalWrite(pgm_read_byte_near(ledPin6 +i), HIGH);
else {
muxValues6[i]= 0;
digitalWrite(pgm_read_byte_near(ledPin6 +i), LOW);
if (muxValues6[i] != prevMuxValues6[i]){
t_midiMsg msg;
msg.status = CC;
msg.data1 = pgm_read_byte_near(CCBankLFO +i);
msg.data2 = muxValues6[i];
usbMIDI.sendControlChange(pgm_read_byte_near(CCBankLFO +i), muxValues6[i], CHANNEL);
prevMuxValues6[i] = muxValues6[i];
for (byte i = 10; i < 15; i++){ //LFO Board #6 -Read Pots
setPin(i);
muxValues6[i]=map(analogRead(A5), 0,1024,0,128);
t_midiMsg msg;
msg.status = CC;
if (prevMuxValues6[12] != muxValues6[12]){
LFOwave = map (muxValues6[12], 0,128,0,4);
for (byte i = 1; i < 5; i++){ //For LFO Board #6 -read menu Switches (no Midi messages sent, no LEDS)
setPin(i);
if (buttonState6[i] == 1) {
if (buttonState6[1] == 1) {
SavePreset();
if (buttonState6[2] == 1 && buttonState6[1] == 0) {
LoadPreset3();
if (buttonState6[3] == 1 && buttonState6[1] == 0) {
LoadPreset2();
if (buttonState6[4] == 1 && buttonState6[1] == 0) {
LoadPreset1();
if (buttonCounter6[3] % 2 == 0) {
// do something
if (buttonCounter6[2] % 2 == 0){
// do something else?
else {
// do something
for (byte i=0; i< 1; i++){
setPin(i); // other switch is mux #0 for (i=0; i<6; i+5){//For LFO Board #6 - read Switches
muxValues6[i]= 127;
digitalWrite(pgm_read_byte_near(ledPin6 + i), HIGH);
else {
muxValues6[i]= 0;
digitalWrite(pgm_read_byte_near(ledPin6 + i), LOW);
t_midiMsg msg;
msg.status = CC;
void MidiSendAll (){
preset = 0;
byte z = 0;
t_midiMsg msg;
msg.status = CC;
CCvals[z]= muxValues1[i];
z++;
t_midiMsg msg;
msg.status = CC;
CCvals[z]= muxValues2[i];
z++;
t_midiMsg msg;
msg.status = CC;
CCvals[z]= muxValues3[i];
z++;}
t_midiMsg msg;
msg.status = CC;
CCvals[z]= muxValues4[i];
z++;
for (byte i = 2; i < 14; i++){
t_midiMsg msg;
msg.status = CC;
CCvals[z]= muxValues5[i];
z++;
t_midiMsg msg;
msg.status = CC;
CCvals[z]= muxValues6[i];
z++;
t_midiMsg msg;
msg.status = CC;
z++;
t_midiMsg msg;
msg.status = CC;
z++;
void ReadPots(){
byte z = 0;
z++;
z++;
z++;
z++;
setPin(i);
muxValues5[i]= 127;
else {
muxValues5[i]= 0;
z++;
setPin(i);
z++;
muxValues6[i]= 127;
else {
muxValues6[i]= 0;
z++;
muxValues6[i]= 127;
else {
muxValues6[i]= 0;
z++;
setPin(i);
z++;
void MidiMerge(){
while(Serial1.available()){
inByte = Serial1.read();
if ( inByte != 0xFE ){ // dump active sensing
if( (inByte & 0x80) == 0x80 ){ //a midi command?
cmd = inByte; // current cmd including midi channel
// channel = inByte & 0x0f ; // save the midi channel to use for controllers
messageCnt = 1;
sendMidi(inByte);
ctrlSend = 0 ; //don't send ctrl now
else{
if (messageCnt == 1){
messageCnt = 2;
sendMidi(inByte);
else if(messageCnt == 2){
messageCnt = 3;
sendMidi(inByte);
ctrlSend = 1 ; //can send ctrl now
//velocity = inByte;
else if(messageCnt == 3){ // running status command
messageCnt = 2;
sendMidi(cmd);
sendMidi(inByte);
void sendMidi(byte midiByte){
if((midiByte & 0x80) == 0x80){ //a command?
lastCmd = midiByte ; // update new command running status
Serial1.write(midiByte); // send command data byte
else{
Serial1.write(midiByte); // just send data byte
void ctrlMessage(byte ccCmd, byte ctrl, byte value) {
//if(ctrl== VelocityDest){ value = value + velocity;}
sendMidi(ccCmd);
sendMidi(ctrl);
sendMidi(value);
void usbMidiMerge(){
if (usbMIDI.read()){
inByte = usbMIDI.read();
messageCnt = 1;
sendMidi(inByte);
else{
messageCnt = 2;
sendMidi(inByte);
messageCnt = 3;
sendMidi(inByte);
messageCnt = 2;
sendMidi(cmd);
sendMidi(inByte);
void mainScreen (){
display.setTextSize(2); //Print to display
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print(F(" Algorithm #"));
display.println(algorithm,DEC);
display.setTextSize(1); //Print to display
display.setCursor(0,45);
display.print(F("LFO Wave: "));
display.println(LFOwaveShape[LFOwave]);
if (preset >= 1){
display.setCursor(70,55);
display.print(F("Preset "));
display.println(preset);
else if (preset < 1){
display.setCursor(90,55);
display.print(F("Panel"));
display.display();
void Menu (){
setPin(13);
//velocityDest = map (muxValues5[13], 0,128,26,73);
CHANNEL = map (muxValues5[13], 0,128,1,17);
EEPROM.write (24, CHANNEL);
display.setCursor(0,5);
display.print(F(" Menu "));
display.setCursor(0,25);
//display.print(F(" Velocity Destination = CC#"));
// display.print(velocity,DEC);
//display.print(F(" MIDI Channel = #"));
//display.print(CHANNEL);
display.display();
void SavePreset(){
if (buttonState6[1] == 1){
if (buttonState6[2] == 1){
for (byte z = 0; z < 60; z++){
EEPROM.write (z+150, CCvals[z]);
if (buttonState6[3] == 1){
EEPROM.write (z+90, CCvals[z]);
if (buttonState6[4] == 1){
EEPROM.write (z+30, CCvals[z]);
void LoadPreset1(){
preset = 1;
CCvals[z] = EEPROM.read(z+30);
t_midiMsg msg;
msg.status = CC;
msg.data1 = pgm_read_byte_near(CCnums +z);
msg.data2 = CCvals[z];
void LoadPreset2(){
preset = 2;
CCvals[z] = EEPROM.read(z+90);
t_midiMsg msg;
msg.status = CC;
void LoadPreset3(){
preset = 3;
CCvals[z] = EEPROM.read(z+150);
t_midiMsg msg;
msg.status = CC;
