Page 2 of 2 FirstFirst 1 2
Results 26 to 29 of 29
Thread: Teensy Audio Shield Serial Ram - chip compatibility question
  1. #26
    Member dimitre's Avatar
    Aug 2016
    São Paulo
    75
    Thanks for the detailed explanation @Blackaddr
    I'll be ordering some of the IS62WVS5128GBLL-45NLI and I'll report here after installed
  2. #27
    Mar 2017
    Canada
    245
    Be aware the 45 MHz parts have a dummy cycle between the address and the data. The 20Mhz parts don't have that
  3. #28
    Aug 2016
    São Paulo
    75
    Great. IS62WVS5128GBLL arrived here and soldered on teensy audio
    Now I'm trying to update effect_delay_ext.cpp, it is the only effect which uses external RAM.
    I'm reading the datasheet and from what I've seen the only difference from the other chips is the dummy cycle. can it be solved like this?
    SPI.transfer(0xff);
    		addr *= 2;
    		SPI.beginTransaction(SPISETTING);
    		digitalWriteFast(SPIRAM_CS_PIN, LOW);
    		SPI.transfer16((0x03 << 8) | (addr >> 16));
    		SPI.transfer16(addr & 0xFFFF);
    		if (memory_type == AUDIO_MEMORY_IS62WVS5128GBLL) {
    			SPI.transfer(0xff);
    		while (count) {
    			*data++ = (int16_t)(SPI.transfer16(0));
    			count--;
    		digitalWriteFast(SPIRAM_CS_PIN, HIGH);
    		SPI.endTransaction();
    I still have doubt in operation mode. if I have to write something to the chip before start using it.
    like Write Mode Register or something.
    Thank you!
  4. #29
    Oct 2016
    171
    There is a working code for DelayExt and IS62WVS5128GBLL?
    Would be great
