In my project I have an MCP23017 connected via i2c to a teensy 3.2 that is also wired up to receive interrupts from the mcp to pins 8 and 2 on the teensy. As per the (Adafruit library )library I have both banks of 8 i/o pins setup with separate interrupts so i can tell which bank the change occurred in. On both interrupt lines i have wired an LED so I can monitor the activity. Sometimes the interrupt signal coming from the mcp works. I can see the LEDs trigger and then quickly reset when the teensy handles the interrupt. Sometimes this is not the case and the interrupt from the mcp never resets the interrupt pin as indicated by the LED still being on. I am somewhat new to Working with interrupts and setting registers so sorry if this is an obvious question. When I power cycle the teensy and mcp the interrupt on the mcp usually wont reset. It isnt until I load another project onto the teensy that it sometimes resets the flag. Once I reprogram the teensy with this code, everything seems to work fine until I hit a button thats attached to the mcp and triggers an interrupt, which it sets its int pin high, only to never been registered by the teensy, and therefor wont reset? Am I missing something? seems like this should be pretty straight forward. Thanks!
#include <Adafruit_MCP23017.h>
#include <Adafruit_LiquidCrystal.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#define led0 9
#define led1 11
#define led2 13
#define led3 15
#define button0 8
#define button1 10
#define button2 12
#define button3 14
#define knob0 2
#define knob1 3
#define knob2 6
#define knob3 7
#define encAPin 0
#define encBPin 1
#define encButton 2
#define intAPin 8
#define intBPin 2
void ledUpdate();
void intAHandler();
void intBHandler();
Adafruit_MCP23017 mcp;
Adafruit_LiquidCrystal lcd(0);
volatile int intACount = 0;
volatile int intBCount = 0;
pinMode(intAPin, INPUT);
pinMode(intBPin, INPUT);
mcp.begin(1);
mcp.pinMode(led0, OUTPUT);
mcp.pinMode(led1, OUTPUT);
mcp.pinMode(led2, OUTPUT);
mcp.pinMode(led3, OUTPUT);
mcp.pinMode(encAPin, INPUT);
mcp.pinMode(encBPin, INPUT);
mcp.pinMode(encButton, INPUT);
mcp.digitalWrite(led0, LOW);
mcp.digitalWrite(led1, LOW);
mcp.digitalWrite(led2, LOW);
mcp.digitalWrite(led3, LOW);
mcp.setupInterrupts(false,false,HIGH);
mcp.setupInterruptPin(button0,CHANGE);
mcp.setupInterruptPin(button1,CHANGE);
mcp.setupInterruptPin(button2,CHANGE);
mcp.setupInterruptPin(button3,CHANGE);
mcp.setupInterruptPin(encAPin,CHANGE);
mcp.setupInterruptPin(encBPin,CHANGE);
mcp.setupInterruptPin(encButton,CHANGE);
attachInterrupt(intAPin, intAHandler, HIGH);
attachInterrupt(intBPin, intBHandler, HIGH);
lcd.begin(16, 2);
lcd.clear();
lcd.setBacklight(HIGH);
lcd.print("CLEAR");
lcd.clear();
ledUpdate();
lcd.setCursor(0,0);
lcd.print(digitalRead(intAPin));
lcd.setCursor(1,0);
lcd.print(digitalRead(intBPin));
lcd.setCursor(8,0);
lcd.print(mcp.digitalRead(encAPin));
lcd.print(mcp.digitalRead(encBPin));
lcd.print(mcp.digitalRead(encButton));
lcd.setCursor(0,1);
lcd.print(intACount);
lcd.setCursor(8,1);
lcd.print(intBCount);
void ledUpdate(){
if(mcp.digitalRead(button0) == HIGH){
mcp.digitalWrite(led0, HIGH);
if(mcp.digitalRead(button0) == LOW){
if(mcp.digitalRead(button1) == HIGH){
mcp.digitalWrite(led1, HIGH);
if(mcp.digitalRead(button1) == LOW){
if(mcp.digitalRead(button2) == HIGH){
mcp.digitalWrite(led2, HIGH);
if(mcp.digitalRead(button2) == LOW){
if(mcp.digitalRead(button3) == HIGH){
mcp.digitalWrite(led3, HIGH);
if(mcp.digitalRead(button3) == LOW){
void intAHandler(){
cli();
intACount++;
sei()
void intBHandler(){
cli();
intBCount++;
sei();
#include <avr/io.h>
#define led0 9
#define led1 11
#define led2 13
#define led3 15
#define button0 8
#define button1 10
#define button2 12
#define button3 14
#define knob0 2
#define knob1 3
#define knob2 6
#define knob3 7
#define encAPin 0
#define encBPin 1
#define encButton 2
#define intAPin 8
#define intBPin 2
void ledUpdate();
void intAHandler();
void intBHandler();
mcp.begin(1);
lcd.begin(16, 2);
lcd.clear();
lcd.print("CLEAR");
lcd.clear();
ledUpdate();
lcd.setCursor(0,0);
lcd.setCursor(1,0);
lcd.setCursor(8,0);
lcd.setCursor(0,1);
lcd.setCursor(8,1);
void ledUpdate(){
void intAHandler(){
cli();
intACount++;
sei()
void intBHandler(){
cli();
intBCount++;
sei();
