Page 14 of 15 FirstFirst ... 4 12 13 14 15 LastLast
Results 326 to 350 of 360
Thread: Teensy 3.x multithreading library first release
  1. #326
    Dec 2016
    Montreal, Canada
    1,991
    you can find out by putting a while(1); right after it in setup, loop wont run, but the thread might :P
  2. #327
    1,369
    Thanks tonton81. Never thought of that. Got my answer.
  3. #328
    Nov 2015
    14
    i played a bit around with this library.
    WOW is what i think
    But i have a question.
    I am using the FlexCan Library of "collin" (https://github.com/collin80/FlexCAN_Library) and i put the Can-Signal handling in a thread to have this always running without interrupting my loop.
    It looks good until some Can-Messages arrive when i send a request, then the Can-Read stop.
    Example:
    void thread_CanBus()
            while(1)
                   canbus();
    // Do some can init stuff here
    Can0.begin(125000);
    // Set Filter and so on...
    threads.addThread(thread_CanBus);
    // Do some Loop Stuff here...
    And my CanBus task is like that:
    void canbus()
      while (Can0.available())
        Can0.read(rxmsg);
    When i put a counter in the while can0 available it counts good.
    But when i send something through the canbus, after 3 times sending the counter of the can-messages goes down to 0. But i know 100% there are still messages.
    Before it was about 250.
    When i put this canbus(); in the loop everything runs fine, i can send as much messages i want and it will not stop.
    Is this CanBus Library not compatible with this Multithread Lib?
    Thanks a lot
    Thomas.
  4. #329
    Dec 2016
    Montreal, Canada
    1,991
    you need to add mutex locks if your accessing (writing) from outside the thread
    ex, if yiur doing writes off the loop and not the thread, and your thread scope is constantly polling the same hardware port, bounds are surely going to cause undefined behaviour
  5. #330
    Dec 2016
    Montreal, Canada
    1,991
    ... and without your entire sketch (not sippets), i cant obviously point you to where that problem lies.
  6. #331
    Nov 2015
    14
    Thank you vey much for your answer.
    I am not such a good programmer as you are so sorry for that, but i still try to learn
    Here is my test sketch:
    #include <Arduino.h>
    #include <FlexCan.h>
    #include <EEPROM.h>
    #include <TeensyThreads.h>
    static CAN_message_t msg, rxmsg;
    unsigned char canmessage1[8] = { 0x12, 0x34, 0x56, 0x78, 0x90, 0xFF, 0xFF, 0xFF };
    unsigned char buf[8];
    long actualmilliseconds = 0;
    long lLoopMillis = 0;
    long lLastLoopMillis = 0;
    long lLoops = 0;
    long lCanLoopMillis = 0;
    long lLastCanLoopMillis = 0;
    long lCanLoops = 0;
    String debugString;
    void canbus()
            while (Can0.read(rxmsg))
                    //Can0.read(rxmsg);
                    lCanLoopMillis = millis();
                    lCanLoops++;
                    if (lCanLoopMillis - lLastCanLoopMillis > 1000)
                            Serial.print("CanLoops: ");
                            Serial.println(lCanLoops);
                            lCanLoops = 0;
                            lLastCanLoopMillis = lCanLoopMillis;
            while(1)
                    canbus();
            Serial.begin(15200);
            Can0.begin(125000);
            msg.len = 8;
            msg.id = 0x10;
            Serial.println("SETUP DONE");
    }     // END SETUP
            actualmilliseconds = millis();
            lLoops++;
            if (actualmilliseconds - lLastLoopMillis > 1000)
                    Serial.print("Loops: ");
                    Serial.println(lLoops);
                    lLastLoopMillis = actualmilliseconds;
                    lLoops = 0;
            while (Serial.available())
                    char c = Serial.read();
                    debugString += c;
            debugString.trim();
            if (debugString.length() > 0)
              if (debugString == "send")
                      Serial.println("Sending canbus message");
                      memcpy(msg.buf, canmessage1, msg.len);
                      Can0.write(msg);
                    debugString = "";
    }     // END LOOP
    And the output is that:
    SETUP DONE
    Loops: 79724
    CanLoops: 159
    Loops: 130941
    CanLoops: 253
    Loops: 132772
    CanLoops: 253
    Loops: 132775
    CanLoops: 253
    Loops: 132759
    CanLoops: 253
    Loops: 132770
    CanLoops: 254
    Loops: 132772
    CanLoops: 253
    Loops: 131782
    CanLoops: 253
    Loops: 131314
    CanLoops: 253
    Loops: 131314
    CanLoops: 253
    Loops: 131363
    Loops: 131461
    Loops: 131462
    Loops: 131461
    Loops: 131462
    Loops: 131463
    Loops: 131461
    I read a bit about the mutex locks and have to play with it, because i understand nothing at the moment
    Thomas
  7. #332
    Dec 2016
    Montreal, Canada
    1,991
    in your loop() your doing can0.write, which means both loop and thread are accessing the hardware port at same time, thats why its crashing. if you implement mutex locks for the same hardware port (can0), you wont crash anymore since the other one waits for the other mutex to unlock before it locks it to use it
    so to simplify it,
    loop() is one thread
    thread_Canbus is another
    you have two choices here:
    1) implement mutex locks
    or
    2) only use can0 from within a single thread
    i posted some examples of mutex locking quite a few posts back on this thread, if you still need to find it
  8. #333
    Nov 2015
    14
    Thanks a lot.
    Not i understand a bit better.
    I will try it
  9. #334
    Dec 2016
    Montreal, Canada
    1,991
    i will post a stripped down version of a few pages back:
    #include "TeensyThreads.h"
    #include <i2c_t3.h>
    Threads::Mutex wire1; // example lock
    Threads::Mutex spi1; // another lock
    Threads::Mutex serial; // another lock...
    Threads::Mutex can0; // <--pay attention to your own lock!
      Wire.begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_EXT, 100000);
      Wire.setDefaultTimeout(200000); // 200ms
      pinMode(LED, OUTPUT);
      auto blinky = threads.addThread(blinkthread);
      threads.setTimeSlice(0, 1); // <-- loop() thread
      threads.setTimeSlice(1, 1); // blinkthread() thread
      byte x, y;
      { Threads::Scope scope(serial);   // <----
        Serial.println("1");                    // <---- whatever is enclosed within the brackets is locked, last bracket here unlocks it. as an example, blinkthread will NOT be able to use "serial" locked scopes until this thread exits scope
      { Threads::Scope scope(wire1);  // <-- this locks the i2c_wire port, "wire1" is just the name of the lock and has no attachment to the port itself, you can call it anything you want in the constructor.
        Wire.beginTransmission(32); Wire.write(0x0C); Wire.write(0xFF); Wire.write(0xFF); Wire.endTransmission();
        Wire.beginTransmission(32); Wire.write(0x12); Wire.endTransmission(); Wire.requestFrom(32, 2);
        x = Wire.read();
        y = Wire.read();
      { Threads::Scope scope(serial); // scope starts lock on "serial" mutex
        Serial.println("2");
        if ( x == 191 && y == 127 ) {
          myCounter++;
          digitalWriteFast(LED, 1);
          Serial.print("Wire Register Read Thread1: ");
          Serial.print(x);
          Serial.print(" : ");
          Serial.print(y);
          Serial.print(" GOOD! : Counter: ");
          Serial.println(myCounter);
          Serial.println("3");
        else {
          Serial.print(x);
          Serial.print(y);
          Serial.println(" FAIL!");
        Serial.println("4");
      } // <-- lock is released since the scope ends here! anyone can use "serial" mutex now
    void blinkthread() {
      while (1) {
        byte x, y;
        { Threads::Scope scope(wire1); // <-- wire1 is used here as well, it takes turns with other thread to access it one at a time, never at same time
          Wire.beginTransmission(32); Wire.write(0x13); Wire.endTransmission(); Wire.requestFrom(32, 1);
          x = Wire.read();
          Wire.beginTransmission(32); Wire.write(0x12); Wire.endTransmission(); Wire.requestFrom(32, 1);
          y = Wire.read();
          Serial.println("Wire Written");
          if ( x == 127 && y == 191 ) {
            myCounter--;
            digitalWriteFast(LED, 0);
            Serial.print("Wire Register Read Thread2: ");
            Serial.print(x);
            Serial.print(y);
            Serial.print(x);
            Serial.print(y);
  10. #335
    Dec 2016
    Montreal, Canada
    1,991
    So if I take your code above, untested, should look something like this->:
    #include <EEPROM.h>
    Threads::Mutex can0_lock;
    long lLoops = 0;
    long lCanLoops = 0;
    String debugString;
    void canbus()
      while (1) {
        { Threads::Scope scope(can0_lock); // lock the mutex
            //Can0.read(rxmsg);
            lCanLoops++;
              lCanLoops = 0;
        } // <-- can0_lock unlocks here
      Can0.begin(125000); // always be careful here, this is OKAY because you did not "addThread" yet, so only accessed once, keep that in mind, so no mutex lock needed here. :)
      msg.len = 8;
      msg.id = 0x10;
      threads.addThread(canbus);
    }     // END SETUP
      lLoops++;
        lLoops = 0;
        debugString += c;
      debugString.trim();
          { Threads::Scope scope(can0_lock); // we start the lock here
            Can0.write(msg);
          } // it automatically unlocks here
        debugString = "";
    }     // END LOOP
  11. #336
    Nov 2015
    14
    Thank you soooo much
    I am using the can0.write so often in a lot of tasks, so maybe i just set a variable and do the write stuff in the thread.
    But i will test both, mutex and only write in the thread.
    I will see which is better for me.
    Thanks again
    Thomas
  12. #337
    Dec 2016
    Montreal, Canada
    1,991
    no prob, you also had an additional function in the thread calling another one, above i took it out and pointed the addThread to canbus() directly, and put the while(1) in there for you
  13. #338
    Dec 2016
    Montreal, Canada
    1,991
    after you got it working, I would suggest dropping the String class and look into character arrays, unless you want your heap to look like swiss cheeze
  14. #339
    1,369
    I am trying to set up a structure where the whole structure is atomic. Found there are some issues with doing it this way. i.e., not being able to reference/change members of the atomic structure that I managed to figure out from a stackoverflow question. Doing it this way avoids any race conditions (according to what I read) if you are reading the data from a thread into a global variable etc.
    So essentially I do what I read the data a temp structure so I can do an any changes and then assign it to the atomic version of the structure. In the main loop I put it back into another structure of the same type again so the main loop can use it (or another thread for doing some calculations - future updates).
    I am getting an error to _defined_referenced to atomic_store or atomic_load if I try to set the atomic struct equal to the non-atomic struct. Probably can't do it this way but not sure how to do it. Can any one tell me a way to do this or if there is better way. I am using a T3.5 for this project.
    Mike
    Happy Holidays to All
    Here is the code:
    Main:
    #include <EEPROM.h>
    #include <NMEAGPS.h>
    #include <Streaming.h>
    #include <StopWatch.h>
    #include <elapsedMillis.h>
    #include <atomic>
    #include <Adafruit_Sensor.h>
    #include <Adafruit_BNO055.h>
    #include <utility/imumaths.h>
    NMEAGPS  gps; // This parses the GPS characters
    #define gpsPort Serial1
    gps_fix  fix;
    #define telem Serial
    elapsedMillis sensorIMU;
    elapsedMillis sensorGPS;
    StopWatch etm_millis;
    // the interval in mS
    unsigned long currentTime;
    unsigned long currentTime_avg;
    unsigned long sensorRunTime;
    /* Set the delay between fresh samples for BNO055*/
    #define BNO055_SAMPLERATE_DELAY_MS (100)
    Adafruit_BNO055 bno = Adafruit_BNO055(55);
    #define EVENT_IMU 100
    #define EVENT_GPS 1000
    #define rad2deg 57.295779513082320876798154814105f
    #define m2ft 3.280839895f
    #define toMps 0.44704f
    struct imuSensor {
        float roll;
        float pitch;
        float heading;
        float rotx;
        float roty;
        float rotz;
        float accelx;
        float accely;
        float accelz;
    struct imuSensor tempAhrs, ahrs;
    std::atomic<imuSensor> threadAhrs;
    struct ublox {
        int32_t lat;
        int32_t lng;
        int fType;
        int fQuality;
        float alt;
        int cog;
        float sog;
        int satno;
        int hdop;
        int pdop;
    } rtk;
    int IMU, GPS;
        telem.begin(57600);
        while ( !telem && millis() < 2000 ) {};
        Wire.begin();
        Wire.setClock(400000L);
        gpsPort.setRX(27);
        gpsPort.begin(57600);
        delay(2000);
        // Initial Adafruit BNO055
        BNO055_Init();
        IMU = threads.addThread(readIMU);
        GPS = threads.addThread(readGPS);
        threads.setTimeSlice(IMU, 50);
        threads.setTimeSlice(GPS, 50);
        if (threads.getState(IMU) == Threads::RUNNING) Serial.println("BNO055 thread started");
        if (threads.getState(GPS) == Threads::RUNNING) Serial.println("GPS thread started");
        ahrs = threadAhrs;
        if(sensorIMU > EVENT_IMU)
            printIMU();
        if(sensorGPS > EVENT_GPS)
            printGPS();
    void printIMU() {
      telem << "IMU DATA (attitude, rotation, accel): " << endl;
      telem << _FLOAT(ahrs.roll, 6) << ", " << _FLOAT(ahrs.pitch,6) << ", " << _FLOAT(ahrs.heading,6) << endl;
      telem << _FLOAT(ahrs.rotx, 6) << ", " << _FLOAT(ahrs.roty,6) << ", " << _FLOAT(ahrs.rotz,6) << endl;
      telem << _FLOAT(ahrs.accelx, 6) << ", " << _FLOAT(ahrs.accely,6) << ", " << _FLOAT(ahrs.accelz,6) << endl;
    void printGPS() {
      telem << "GPS DATA:" << endl;
      telem.printf("%12lf, %12lf\n",rtk.lat/1e7L, rtk.lng/1e7L);
      Serial.print( fix.latitudeL() );
      telem << rtk.fQuality << endl;
      telem << _FLOAT(rtk.alt, 6) << ", " << rtk.cog << ", ";
      telem << _FLOAT(rtk.sog, 6) << endl;
      telem << rtk.satno << endl;
    Thread:
    void readIMU(){
      while(1){
        sensors_event_t sensor;
        bno.getEvent(&sensor);
        imu::Vector<3> euler = bno.getVector(Adafruit_BNO055::VECTOR_EULER);
        imu::Vector<3> accel_linear = bno.getVector(Adafruit_BNO055::VECTOR_LINEARACCEL);
        imu::Vector<3> rot_rate = bno.getVector(Adafruit_BNO055::VECTOR_GYROSCOPE);
        tempAhrs.roll = (float)sensor.orientation.y;
        tempAhrs.pitch = (float)sensor.orientation.z;
        tempAhrs.heading = (float)sensor.orientation.x;
        tempAhrs.rotx = (float) rot_rate.x() * rad2deg;
        tempAhrs.roty = (float) rot_rate.y() * rad2deg;
        tempAhrs.rotz = (float) rot_rate.z() * rad2deg;  //heading
        tempAhrs.accelx = (float) accel_linear.x();
        tempAhrs.accely = (float) accel_linear.y();
        tempAhrs.accelz = (float) accel_linear.z();
        // Adjust heading to account for declination
        //tempAhrs.heading += DEC_ANGLE;
        //telem << "Compass Yar/dec Heading: " << yar_heading << " , " << heading << endl;
        // Correct for when signs are reversed.
        if(tempAhrs.heading < 0)
          tempAhrs.heading += 360.;
        // Check for wrap due to addition of declination.
        if(tempAhrs.heading > 360.)
          tempAhrs.heading -= 360.;
        threadAhrs = tempAhrs;
        //telem << roll << "\t" << pitch << "\t" << yar_heading << endl;
        //telem << "Changed heading: " << (float)sensor.orientation.x << endl;
        threads.delay(BNO055_SAMPLERATE_DELAY_MS);
    void readGPS(){
     while(1){
      while (gps.available( gpsPort )) {
        fix = gps.read();
        rtk.fQuality = fix.status;
        rtk.satno = fix.satellites;
        rtk.hdop = fix.hdop;
        rtk.lat = fix.latitudeL();
        rtk.lng = fix.longitudeL();
        rtk.cog = fix.heading_cd();
        rtk.sog = fix.speed_mph() * toMps;
        rtk.alt = fix.altitude();
        //cout << fix.satellites << ", " << fix.hdop << ", " << fix.pdop << ", ";
        //telem << "LAT: " << _FLOAT(fix.latitude(),8)                << ", " << _FLOAT(fix.longitude(),8) << ", "  << fix.heading() << ", ";
        //cout << fix.speed_kph() << ", " << fix.altitude() << ", " << fix.lat_err() << ", ";
        //cout << fix.lon_err() << endl;
  15. #340
    Dec 2016
    Montreal, Canada
    1,991
    what i did for the canbus global variables since i had different functions reading different busses and handling the data, i put the variable within the same scope lock so it doesnt run unless its inside the same scope that prevents others from touching it
  16. #341
    1,369
    Hi tonton81. Lets see if I understand your approach with a little example on scope lock's (still gives me a headache) using something like thomas7's example:
    float roll;
    Threads::Mutex GPS;
    Threads::Mutex IMU;
    void readGPS() {
      while (1) {
        { Threads::Scope scope(IMU);  //sets lock
           //Read global variables from imu
           //wire1 and any global variables should be locked
           //do any mods i want to the variable
           roll = roll + 180;
        }  // lock gets released
    void updateWaypoint(){
        Threads::Scope scope(GPS);  //sets lock
           //use any global variables should be locked
           lat = lat - oldlat;
           // lat is locked until thread finishes (theres a lot more to this routing of course
         new heading = cccc;
          // lock gets released and then readIMU is free to update the data
    void setup(){
          //add thread GPS - reads GPS data
          //add thread IMU - reads IMU so i need another scope lock
    void loop(){
         { (Threads::Scope scope(GPS) && Threads::Scope scope(IMU));  //sets lock  How do i add a second lock??
                 updateWaypoint();
                 getSteeringAngle();
          }  //both locks get released???
    or would it be better to put all the sensor reads in loop because i will have a third for wheel encoders that will need to be added
    Mike
  17. #342
    Dec 2016
    Montreal, Canada
    1,991
    for reading its no problem i think even for uint16_t but the scope IMU lock above protects roll as long as roll is not updated anywhere else of course. youd have to include those rolls in a lock as well but in the same named scopes. if you have 2 different locks on 2 different scopes, and roll is in both, they have the right to edit it at same time *boom*
    i prefer to put the mutex lock on the port itself, not just the devices, think of it as grouping if you will
    SPI0_lock for example, and use those locks instead, thereby if your using multiple devices in the same bus, using a single lock, it doesnt matter who edits “roll”, because the group lock SPI0_lock everyone who uses it, has to wait their turn
  18. #343
    1,369
    Ok so if I do something like this:
    Threads::Mutex wire_lock;
    Threads::Mutex serial1_lock;
    struct ublox {
        double lat;
        double lng;
        int fType;
        int fQuality;
        float alt;
        int cog;
        float sog;
        int satno;
        int hdop;
        int pdop;
    } rtk;
    void readGPS() {
      while (1) {
        { Threads::Scope scope(serial1_lock);  //sets lock
           rtk.lat = rtk.latitudeL()/10000000;
    void readIMU) {
      while (1) {
        { Threads::Scope scope(wire_lock);  //sets lock
           imu.yaw = imu.roll + 180;
           // might better to use local copies of any variables that I might change
           lat = lat - oldlat;
         new heading = cccc;
    void setup(){
    void loop(){
         { Threads::Scope scope(serial1_lock ) ;
              {Threads::Scope scope(wire1_lock);  //sets lock  How do i add a second lock??
                 updateWaypoint();
                 getSteeringAngle();
  19. #344
    Dec 2016
    Montreal, Canada
    1,991
    try to do only single locks never double, you must keep them in the exact order if you use 2 or more and has potential to deadlock and hard to keep track of. do you really need wire1 and serial locked at same time? i usually have it do one and close then do another, this gives other threads possibility to use serial as well while your in wire1 locked
    but yeah to add a series of locks you did it right, but still dangerous to do
  20. #345
    1,369
    Now that you mention it. Not really. Could do it with one. Would simplify the whole thing
    Yeah, that what I was reading when I looked up multiple locks.
    Thanks for the help and the lesson on locks. Always got me confused.
    Mike
  21. #346
    Sep 2017
    Bay Area, USA
    17
    Guys, when using TeensyThreads and you have a thread with an infinite loop as it's body, should that loop call yield() every pass through, or will the threading know when to preempt this so that all threads on the same priority get a chance to run in a timely manner?
  22. #347
    Dec 2016
    Montreal, Canada
    1,991
    you dont need to call yield on threads, the library does all the switch work for you, regardless whats in your infinite loop
  23. #348
    Sep 2017
    Bay Area, USA
    17
    OK, this is good to know and is what I would expect. We were having a threads.sleep(1) at the end of all our infinite loops.
    In our system we have 3 threads running at the default priority, and one thread running at a higher priority to service the UI (capture button presses, update the LCD etc.). As an experiment I removed the sleeps from all our loops, but when I re-ran the system, I am pretty sure I observed a slowdown in the button/UI responsiveness. Does this sound right?
  24. #349
    Dec 2016
    Montreal, Canada
    1,991
    no doesnt sound right, if you sleep the threads it just temporarily stops queuing that thread from switching, but if 2 threads are fighting over a hardware interface that could be your problem, are two threads accessing your lcd port or library ?
    mutex locks would ressolve this if you say yes, as it gives them turns instead of fighting over it
  25. #350
    Sep 2017
    Bay Area, USA
    17
    Thanks - I don't think we have > 1 thread trying to access each of the hw resources, but will verify this tonight.
    Does Teensy Threads support task time-slicing (e.g. giving fair and prompt scheduling to two threads at the same priority level)?
    Teensy Threads is working well for us overall, nice work guys :-)
