Page 18 of 18 FirstFirst ... 8 16 17 18
Results 426 to 428 of 428
Thread: Teensy 3.x multithreading library first release
  1. #426
    Dec 2016
    Montreal, Canada
    3,337
    Dont know if this also helps, but the time slices of each thread can be changed which affects how long task switching stays in that thread, i had to adjust my time slices when i ran multiple uart displays in previous project to stop jittering
  2. #427
    May 2015
    USA
    332
    Fernando, thanks for making this. It certainly makes for better looking multitasking code. My simple test runs fine on teensy 4.0.
  3. #428
    Mar 2020
    1
    Any thoughts on setting a very large time slice to do cooperative multi-tasking with TeensyThreads?
    I needed yield-based cooperative multitasking that works on both Teensy 3 and Teensy 4, and so far this seems to work well. Thanks for the fine work!
    Maybe this could be turned into a feature, and avoid the 1000th-hour overflow-of-doom...
