/* OLED Shield Sample Program
This code shows you the sample program
for OLED screen test interfacing with
GizDuino MCU board.
Codes By: Carlos, Cathie & Medel
Visit us at: http://sfpanganibans.blogspot.com/
(Last update October 21, 2011)
ChangeLog:
06/02/14 - @egizmoMehatronix Central
- SD library Modified and additional codes
for gizDuino + and X.
For gizDuino 328:(UnComment the two define ports
if you are using the gizDuino 168/328 ONLY)
For gizDuino + or X: Same procedure in + and X
if you want to use them.
Go to the *selection of gizDuino Boards to use.
const byte REG_SOFTRES = 0x01; //Software Reset
const byte REG_DDISP_ON_OFF = 0x02; //Display ON/OFF SET
const byte REG_DSTBY_ON_OFF = 0x03; //Stanby Mode Set
const byte REG_DFRAME = 0x04; //Set Frame Frequence
const byte REG_WriteDirection = 0x05; //Sets GRAM Writing Direction
const byte REG_ScanDirection = 0x06; //Row Scan Direction
const byte REG_DispSize = 0x07; //Display Size Set
const byte REG_IF_Bus_Sel = 0x08; //Interface bus Select
const byte REG_Data_Masking = 0x09; //Masking Data
const byte REG_MBOXSize = 0x0A; //Data Reading/Writing Box
const byte REG_DISPStart = 0x0B; //Display Start Address
const byte REG_DataWrite = 0x0C; //Reading/Write Dot matrix Display Data
const byte REG_READREG = 0x0D; //Read Register Status
const byte REG_DotCurrent = 0x0E; //Set Dot Marix Current Level
const byte REG_DotPeakCurrent = 0x0F; //Set Dot Marix Peak Current Level
const byte REG_PreC_Width = 0x1C; //Sets Precharge pulse width
const byte REG_PeakWidth = 0x1D; //Set Peak Pulse Width
const byte REG_PeakDelay = 0x1E; //Sets Peak Pulse Delay(0u~63u)
const byte REG_Row_Scan = 0x1F; //Set Row Scan Operation
const byte REG_IF_SEL = 0x2D; //Set Interface Mode
const byte REG_RGB_IF_CTRL = 0x2E; //RGB I/F Control
const byte REG_RGB_IF_POL = 0x2F; //Set RGB I/F Polarity
const byte REG_VCC_R_SEL = 0x30; //Set Internal Regulator for Row Scan
const byte REG_XTALK_Mode = 0x31; //Set XTALK Condition Setting
const byte REG_XTALK_EN = 0x32; //Set XTALK Enable
const byte REG_AGING_EN = 0x35; //Set AGING Mode
const byte REG_Gamma_Tune = 0x3A; //Set Gamma Correction Table Set
const byte REG_Gamma_Initial = 0x3B; //Set Gamma Correction Table Initialize
const byte A0B = 5;
const byte CSB = 4;
const byte WRB = 3;
const byte RES = 2;
byte RED;
byte GREEN;
byte BLUE;
/*--------- Selection of gizDuino Boards to use ------------*/
/* For gizDuino 328 */
//#define PORTOLED PORTC
//#define PORTOLEDDDR DDRC
/* For gizDuino + */
#define PORTOLED PORTA
#define PORTOLEDDDR DDRA
/* For gizDuino X */
//#define PORTOLED PORTF
//#define PORTOLEDDDR DDRF
unsigned int Y, X;
const int chipSelect = 10;
PORTOLEDDDR = ~0x00; //D0-D7 output
pinMode(A0B, OUTPUT);
pinMode(CSB, OUTPUT);
pinMode(WRB, OUTPUT);
pinMode(RES, OUTPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(9, INPUT);
pinMode(10, INPUT);
pinMode(11, INPUT);
pinMode(12, INPUT);
// WRITE_COMMAND(0x01); // Display ON/OFF SET
// while(1);
init_OLED();
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
Serial.println("card initialized.");
while(1) {
// 180 red lines
// reset screen to receive data
WRITE_COMMAND(REG_DISPStart);
WRITE_DATA(0x00);
WRITE_COMMAND(REG_DataWrite);
for(Y=0; Y<160; Y++) {
for(X=0; X<128; X++) {
// blue
WRITE_DATA(0);
// green
WRITE_DATA(0);
// red
WRITE_DATA(255);
// 180 green lines
WRITE_DATA(0x00);
// blue
WRITE_DATA(0);
// green
WRITE_DATA(255);
// red
WRITE_DATA(0);
// 180 blue lines
WRITE_DATA(0x00);
// blue
WRITE_DATA(255);
// green
WRITE_DATA(0);
// red
WRITE_DATA(0);
// random colored single lines
WRITE_DATA(0x00);
BLUE=random(0,256);
GREEN=random(0,256);
RED=random(0,256);
BLUE = BLUE + 1;
if (BLUE>255) {
BLUE=random(0,256);
GREEN = GREEN + 1;
if (GREEN>255) {
RED = RED + 1;
if (RED>255) {
RED=random(0,256);
BLUE=random(0,256);
RED=random(0,256);
// blue
WRITE_DATA(BLUE);
// green
WRITE_DATA(GREEN);
// red
WRITE_DATA(RED);
// random chunks
WRITE_DATA(0x00);
BLUE=random(0,256);
RED=random(0,256);
BLUE = BLUE + 1;
if (BLUE>255) {
BLUE=random(0,256);
GREEN = GREEN + 1;
if (GREEN>255) {
RED = RED + 1;
if (RED>255) {
RED=random(0,256);
BLUE=random(0,256);
RED=random(0,256);
BLUE = BLUE + 1;
if (BLUE>255) {
BLUE=random(0,256);
GREEN = GREEN + 1;
if (GREEN>255) {
RED = RED + 1;
if (RED>255) {
RED=random(0,256);
// blue
WRITE_DATA(BLUE);
// green
WRITE_DATA(GREEN);
// red
WRITE_DATA(RED);
// random dots
WRITE_DATA(0x00);
BLUE=random(0,256);
RED=random(0,256);
// blue
WRITE_DATA(BLUE);
// green
WRITE_DATA(GREEN);
// red
WRITE_DATA(RED);
void init_OLED() {
WRITE_COMMAND(REG_SOFTRES); // Software Reset
// WRITE_COMMAND(REG_DDISP_ON_OFF); // Display ON/OFF SET
// WRITE_DATA(0x00); // Display OFF
WRITE_COMMAND(REG_DSTBY_ON_OFF);
WRITE_DATA(0x00);
WRITE_COMMAND(REG_DFRAME);
// WRITE_DATA(0x00); //60Hz
// WRITE_DATA(0x01); //75Hz
WRITE_DATA(0x02); //90Hz
// WRITE_DATA(0x03); //105Hz
// WRITE_DATA(0x04); //120Hz
// WRITE_DATA(0x05); //135Hz
// WRITE_DATA(0x06); //150Hz
WRITE_COMMAND(REG_WriteDirection);
// WRITE_DATA(0x00); //RGB
WRITE_DATA(0x08); //BGR
WRITE_COMMAND(REG_ScanDirection);
WRITE_COMMAND(REG_IF_Bus_Sel);
WRITE_DATA(0x00); //6bit interface bus
// WRITE_DATA(0x01); //8bit interface bus
// WRITE_DATA(0x02); //9bit interface bus
// WRITE_DATA(0x03); //16bit interface bus
// WRITE_DATA(0x04); //18bit interface bus
// WRITE_COMMAND(REG_PeakDelay);
WRITE_COMMAND(REG_PeakWidth);
WRITE_DATA(0x03);
WRITE_DATA(0x0F);
WRITE_DATA(0x05);
WRITE_COMMAND(REG_DotCurrent);
WRITE_DATA(0x08);
WRITE_DATA(0x0B);
WRITE_DATA(0x02);
WRITE_DATA(0x09);
WRITE_DATA(0x0A);
WRITE_DATA(0x0D);
// WRITE_COMMAND(REG_PreC_Width);
WRITE_DATA(0x01); // Display OFF
void WRITE_COMMAND(unsigned char db_data)
digitalWrite(A0B, HIGH); //command
PORTOLED = ~db_data;
digitalWrite(CSB, HIGH);
digitalWrite(WRB, HIGH);
digitalWrite(WRB, LOW);
digitalWrite(CSB, LOW);
void WRITE_DATA(unsigned char db_data)
digitalWrite(A0B, LOW); //parameter
Naturally I need to edit the line
