Results 1 to 2 of 2
Thread: Parallel OLED LD7222 with Teensy 3.2/3.6
    Jul 2016
    4
    I'm trying to use the OLED Display that I've been bought here in the Philippines to work with Teensy 3.2/3.6, the OLED Display works just fine on Arduino Mega. This is the code that I'm using with the Arduino Mega
    /* OLED Shield Sample Program
    This code shows you the sample program
    for OLED screen test interfacing with
    GizDuino MCU board.
    Codes By: Carlos, Cathie & Medel
    Visit us at: http://sfpanganibans.blogspot.com/
    (Last update October 21, 2011)
      ChangeLog:
     06/02/14 - @egizmoMehatronix Central
              - SD library Modified and additional codes
                for gizDuino + and X.
     For gizDuino 328:(UnComment the two define ports
                if you are using the gizDuino 168/328 ONLY)
     For gizDuino + or X: Same procedure in + and X
                if you want to use them.
    Go to the *selection of gizDuino Boards to use.
    const byte REG_SOFTRES = 0x01; //Software Reset
    const byte REG_DDISP_ON_OFF = 0x02; //Display ON/OFF SET
    const byte REG_DSTBY_ON_OFF = 0x03; //Stanby Mode Set
    const byte REG_DFRAME = 0x04; //Set Frame Frequence
    const byte REG_WriteDirection = 0x05; //Sets GRAM Writing Direction
    const byte REG_ScanDirection = 0x06; //Row Scan Direction
    const byte REG_DispSize = 0x07; //Display Size Set
    const byte REG_IF_Bus_Sel = 0x08; //Interface bus Select
    const byte REG_Data_Masking = 0x09; //Masking Data
    const byte REG_MBOXSize = 0x0A; //Data Reading/Writing Box
    const byte REG_DISPStart = 0x0B; //Display Start Address
    const byte REG_DataWrite = 0x0C; //Reading/Write Dot matrix Display Data
    const byte REG_READREG = 0x0D; //Read Register Status
    const byte REG_DotCurrent = 0x0E; //Set Dot Marix Current Level
    const byte REG_DotPeakCurrent = 0x0F; //Set Dot Marix Peak Current Level
    const byte REG_PreC_Width = 0x1C; //Sets Precharge pulse width
    const byte REG_PeakWidth = 0x1D; //Set Peak Pulse Width
    const byte REG_PeakDelay = 0x1E; //Sets Peak Pulse Delay(0u~63u)
    const byte REG_Row_Scan = 0x1F; //Set Row Scan Operation
    const byte REG_IF_SEL = 0x2D; //Set Interface Mode
    const byte REG_RGB_IF_CTRL = 0x2E; //RGB I/F Control
    const byte REG_RGB_IF_POL = 0x2F; //Set RGB I/F Polarity
    const byte REG_VCC_R_SEL = 0x30; //Set Internal Regulator for Row Scan
    const byte REG_XTALK_Mode = 0x31; //Set XTALK Condition Setting
    const byte REG_XTALK_EN = 0x32; //Set XTALK Enable
    const byte REG_AGING_EN = 0x35; //Set AGING Mode
    const byte REG_Gamma_Tune = 0x3A; //Set Gamma Correction Table Set
    const byte REG_Gamma_Initial = 0x3B; //Set Gamma Correction Table Initialize
    const byte A0B = 5;
    const byte CSB = 4;
    const byte WRB = 3;
    const byte RES = 2;
    byte RED;
    byte GREEN;
    byte BLUE;
    /*--------- Selection of gizDuino Boards to use ------------*/
    /* For gizDuino 328 */
    //#define PORTOLED PORTC
    //#define PORTOLEDDDR DDRC
    /* For gizDuino +   */
    #define PORTOLED PORTA
    #define PORTOLEDDDR DDRA
    /* For gizDuino X  */
    //#define PORTOLED PORTF
    //#define PORTOLEDDDR DDRF
    unsigned int Y, X;
    const int chipSelect = 10;
      PORTOLEDDDR = ~0x00;    //D0-D7 output
      pinMode(A0B, OUTPUT);
      pinMode(CSB, OUTPUT);
      pinMode(WRB, OUTPUT);
      pinMode(RES, OUTPUT);
      pinMode(7, INPUT);
      pinMode(8, INPUT);
      pinMode(9, INPUT);
      pinMode(10, INPUT);
      pinMode(11, INPUT);
      pinMode(12, INPUT);
      //    WRITE_COMMAND(0x01); // Display ON/OFF SET
      //    while(1);
      init_OLED();
      // make sure that the default chip select pin is set to
      // output, even if you don't use it:
      pinMode(10, OUTPUT);
      // see if the card is present and can be initialized:
      Serial.println("card initialized.");
      while(1) {
        // 180 red lines
        // reset screen to receive data
        WRITE_COMMAND(REG_DISPStart);
        WRITE_DATA(0x00);
        WRITE_COMMAND(REG_DataWrite);
        for(Y=0; Y<160; Y++) {
          for(X=0; X<128; X++) {
            // blue
            WRITE_DATA(0);
            // green
            WRITE_DATA(0);
            // red
            WRITE_DATA(255);
        // 180 green lines
        WRITE_DATA(0x00);
            // blue
            WRITE_DATA(0);
            // green
            WRITE_DATA(255);
            // red
            WRITE_DATA(0);
        // 180 blue lines
        WRITE_DATA(0x00);
            // blue
            WRITE_DATA(255);
            // green
            WRITE_DATA(0);
            // red
            WRITE_DATA(0);
        // random colored single lines
        WRITE_DATA(0x00);
        BLUE=random(0,256);
        GREEN=random(0,256);
        RED=random(0,256);
        BLUE = BLUE + 1;
        if (BLUE>255) {
          BLUE=random(0,256);
        GREEN = GREEN + 1;
        if (GREEN>255) {
        RED = RED + 1;
        if (RED>255) {
          RED=random(0,256);
          BLUE=random(0,256);
          RED=random(0,256);
            // blue
            WRITE_DATA(BLUE);
            // green
            WRITE_DATA(GREEN);
            // red
            WRITE_DATA(RED);
        // random chunks
        WRITE_DATA(0x00);
        BLUE=random(0,256);
        RED=random(0,256);
        BLUE = BLUE + 1;
        if (BLUE>255) {
          BLUE=random(0,256);
        GREEN = GREEN + 1;
        if (GREEN>255) {
        RED = RED + 1;
        if (RED>255) {
          RED=random(0,256);
          BLUE=random(0,256);
          RED=random(0,256);
            BLUE = BLUE + 1;
            if (BLUE>255) {
              BLUE=random(0,256);
            GREEN = GREEN + 1;
            if (GREEN>255) {
            RED = RED + 1;
            if (RED>255) {
              RED=random(0,256);
            // blue
            WRITE_DATA(BLUE);
            // green
            WRITE_DATA(GREEN);
            // red
            WRITE_DATA(RED);
        // random dots
        WRITE_DATA(0x00);
            BLUE=random(0,256);
            RED=random(0,256);
            // blue
            WRITE_DATA(BLUE);
            // green
            WRITE_DATA(GREEN);
            // red
            WRITE_DATA(RED);
    void init_OLED() {
      WRITE_COMMAND(REG_SOFTRES); // Software Reset
      //    WRITE_COMMAND(REG_DDISP_ON_OFF); // Display ON/OFF SET
      //    WRITE_DATA(0x00); // Display OFF
      WRITE_COMMAND(REG_DSTBY_ON_OFF);
      WRITE_DATA(0x00);
      WRITE_COMMAND(REG_DFRAME);
      //    WRITE_DATA(0x00);        //60Hz
      //    WRITE_DATA(0x01);        //75Hz
      WRITE_DATA(0x02);        //90Hz
      //    WRITE_DATA(0x03);        //105Hz
      //    WRITE_DATA(0x04);        //120Hz
      //    WRITE_DATA(0x05);        //135Hz
      //    WRITE_DATA(0x06);        //150Hz
      WRITE_COMMAND(REG_WriteDirection);
      //    WRITE_DATA(0x00);        //RGB
      WRITE_DATA(0x08);        //BGR
      WRITE_COMMAND(REG_ScanDirection);
      WRITE_COMMAND(REG_IF_Bus_Sel);
      WRITE_DATA(0x00);        //6bit interface bus
      //    WRITE_DATA(0x01);        //8bit interface bus
      //    WRITE_DATA(0x02);        //9bit interface bus
      //    WRITE_DATA(0x03);        //16bit interface bus
      //    WRITE_DATA(0x04);        //18bit interface bus
      //    WRITE_COMMAND(REG_PeakDelay);
      WRITE_COMMAND(REG_PeakWidth);
      WRITE_DATA(0x03);
      WRITE_DATA(0x0F);
      WRITE_DATA(0x05);
      WRITE_COMMAND(REG_DotCurrent);
      WRITE_DATA(0x08);
      WRITE_DATA(0x0B);
      WRITE_DATA(0x02);
      WRITE_DATA(0x09);
      WRITE_DATA(0x0A);
      WRITE_DATA(0x0D);
      //    WRITE_COMMAND(REG_PreC_Width);
      WRITE_DATA(0x01); // Display OFF
    void WRITE_COMMAND(unsigned char db_data)
      digitalWrite(A0B, HIGH);  //command
      PORTOLED = ~db_data;
      digitalWrite(CSB, HIGH);
      digitalWrite(WRB, HIGH);
      digitalWrite(WRB, LOW);
      digitalWrite(CSB, LOW);
    void WRITE_DATA(unsigned char db_data)
      digitalWrite(A0B, LOW);  //parameter
    Naturally I need to edit the line
    to make it work on teensy 3.2 or teensy 3.6 (I have both) but when I look into the pins_arduino.h file of both Arduino Mega and Teensy I see that the declaration of pins of the teensy is very different from the Arduino (as expected) and I have no experience in messing up the with the C++ files with microcontroller. Can you guys give me some help to make the OLED Display work with my teensy because in my country it is hard to find SPI LCD or OLED Displays. Any help will be much appreciated.
    The Datasheet and Schematic of the OLED Display is this
    NVK-160SC002F-S-0100.pdf, Schematic.pdf
    Jan 2019
    1
    Can you post the full schematic here? I am trying to connect an LD7222 to an Arduino now too , I am trying to follow your schematic but I don't see the full 42 pins.
    And can you say what is U3?
