Page 3 of 3 FirstFirst 1 2 3
Results 51 to 52 of 52
Thread: Teensyduino 1.36 Beta #1 (ARM Toolchain Update)
  1. #51
    3,653
    defragster: Yes this newer machine is working a lot nicer. My maybe 6 year old first generation i7 machine was acting real strange and the drive was having problems. I had already repleaced the USB 3 adapter as it had a .9 version which did not work well (especially on Logic Pro)... The CDRom drive would randomly open and close, and Arduino compiles were taking probably longer than when I compiled using a RPI3.... So it was time! But still figuring out this new machine.
    Updated and removed...
    The difference with LTO appears to be a problem in my test program that was overwriting an array. How this effected things was different depending on how compiled but was still just a simple memory corruption bug:
  2. #52
    May 2017
    5
    I definitely had some issues with the "Fastest" optimize option and a larger code base of ours. We mainly use the OctoWS2811 library but I had significant issues with some fades between LED colors. Once I switched back to the "Fast" or "Smallest Code" option everything performed as expected. I'm happy to help debug it a little more but I wasn't sure where to start and a colleague of mine needed to get our board out the door so I didn't test much after everything was functional.
    To note I tried Arduino 1.6.13, 1.8.1, 18.2 using Teensyduino 1.36
