bodger
New member
I was writing some code to transfer binary numbers over a serial port and it kept getting out of synch. I kept simplifying the code until it was about as trivial as it can be (sends 0x11, 0x22, 0x33 repeatedly, with a delay). The output is still out of order. Here's the code:
Here's a hex dump of what I receive:
This is with a Teensy 3.2 using the USB serial port. I don't think I'm overflowing any buffers, I'm not overclocking, and I don't think the compiler is reordering the code (I've tried it with both 72MHz optimize speed and 72MHz reduce code size). If I uncomment the line to send 0x44, I get this:
My original application sent 0xff synch bytes, along with 4-byte floating point values. I'd get the synch bytes scattered throughout my data, not every 5th byte as expected.
#define SERIALPORT Serial
void
setup()
SERIALPORT.begin(9600);
void
loop()
SERIALPORT.write((byte) 0x11);
SERIALPORT.write((byte) 0x22);
SERIALPORT.write((byte) 0x33);
//SERIALPORT.write((byte) 0x44);
0000000 2211 1133 3322 2211 1133 3322 2211 1133
0000020 3322 2211 1133 3322 2211 1133 3322 2211
0000040 1133 3322 2211 1133 3322 2211 1133 3322
0000000 2211 4433 2211 4433 2211 4433 2211 4433
