20:07:16 **** Incremental Build of configuration Release for project table ****
"E:\\ide\\sloeber2\\sloeber\\arduinoPlugin\\tools\\make\\make" all
'Building file: ../Table.cpp'
'Starting C++ compile'
"E:/ide/teensy/arduino/arduino-1.6.8/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=128 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS -I"E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\cores\teensy3" -I"E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\OctoWS2811" -I"E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED" -MMD -MP -MF"Table.cpp.d" -MT"Table.cpp.o" -D__IN_ECLIPSE__=1 -x c++ "../Table.cpp" -o "Table.cpp.o" -Wall
In file included from ../Table.cpp:10:0:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:12:2: warning: #warning FastLED version 3001000 (Not really a warning, just telling you here.) [-Wcpp]
../Table.cpp: In function 'void setup()':
../Table.cpp:40:52: error: no matching function for call to 'CFastLED::addLeds(CRGB [1312], int)'
LEDS.addLeds<OCTOWS2811>(leds, NUM_LEDS_PER_STRIP);
../Table.cpp:40:52: note: candidates are:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:172:129: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER, unsigned char SPI_DATA_RATE> CLEDController& CFastLED::addLeds(CRGB*, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER, uint8_t SPI_DATA_RATE > CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:172:129: note: template argument deduction/substitution failed:
../Table.cpp:40:52: error: could not convert template argument 'OCTOWS2811' to 'ESPIChipsets'
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:184:95: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN > static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:184:95: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:196:113: note: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER > static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:196:113: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:209:56: note: template<ESPIChipsets CHIPSET> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
template<ESPIChipsets CHIPSET> static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:209:56: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:213:74: note: template<ESPIChipsets CHIPSET, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
template<ESPIChipsets CHIPSET, EOrder RGB_ORDER> static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:213:74: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:217:97: note: template<ESPIChipsets CHIPSET, EOrder RGB_ORDER, unsigned char SPI_DATA_RATE> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
template<ESPIChipsets CHIPSET, EOrder RGB_ORDER, uint8_t SPI_DATA_RATE> static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:217:97: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:244:25: note: template<template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET, unsigned char DATA_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:244:25: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:250:25: note: template<template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:250:25: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:256:25: note: template<template<unsigned char DATA_PIN> class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:256:25: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:292:25: note: template<template<EOrder RGB_ORDER> class CHIPSET, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:292:25: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:298:25: note: template<template<EOrder RGB_ORDER> class CHIPSET> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:298:25: note: template argument deduction/substitution failed:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:354:25: note: template<EBlockChipsets CHIPSET, int NUM_LANES, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:354:25: note: template argument deduction/substitution failed:
../Table.cpp:40:52: error: could not convert template argument 'OCTOWS2811' to 'EBlockChipsets'
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:380:25: note: template<EBlockChipsets CHIPSET, int NUM_LANES> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:380:25: note: template argument deduction/substitution failed:
../Table.cpp:41:25: error: no matching function for call to 'CFastLED::addLeds(CRGB [1312], int)'
LEDS.addLeds(leds, 164);
../Table.cpp:41:25: note: candidates are:
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:150:25: note: static CLEDController& CFastLED::addLeds(CLEDController*, CRGB*, int, int)
static CLEDController &addLeds(CLEDController *pLed, struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0);
E:\ide\teensy\arduino\arduino-1.6.8\hardware\teensy\avr\libraries\FastLED/FastLED.h:150:25: note: candidate expects 4 arguments, 2 provided
../Table.cpp:41:25: note: couldn't deduce template parameter 'CHIPSET'
../Table.cpp:41:25: note: couldn't deduce template parameter 'template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET'
../Table.cpp:41:25: note: couldn't deduce template parameter 'template<unsigned char DATA_PIN> class CHIPSET'
../Table.cpp:41:25: note: couldn't deduce template parameter 'template<EOrder RGB_ORDER> class CHIPSET'
make: *** [Table.cpp.o] Error 1
subdir.mk:54: recipe for target 'Table.cpp.o' failed
20:07:17 Build Finished (took 827ms)
