Results 1 to 5 of 5
Thread: MacOs Sierra not recognizing Teensy 3.6
    Jun 2016
    2
    I recently purchased a new MacBook Pro 15" w/Touchbar running Sierra 10.12.2, Arduino 1.6.13, Teensyduino 1.35. I am using an Apple USB C to A adapter and plugging my Teensy 3.6 to it. Once plugged Arduino does not recognize it on any ports and the same is true for my teensy 3.2. Is there a driver that I am missing?
    I am running my Teensy 3.6 under OS X 10.12.2 and it is listed as "/dev/cu.usbmodem2430871". I am also using the USB C adapter as well.
    What do you see if you "ls -la /dev/cu*"?
    This is my output:
    crw-rw-rw- 1 root wheel 20, 1 Jan 13 11:00 /dev/cu.Bluetooth-Incoming-Port
    crw-rw-rw- 1 root wheel 20, 0x00000281 Jan 27 14:25 /dev/cu.usbmodem2430871
    Feb 2014
    Colmar, France
    2,596
    Could you perhaps check with a different USB device, for example a mouse or keyboard, if that works with that USB C to A adapter? Normally, there is no reason that the Teensy would not be recognized. Special drivers should not be needed.
    Senior Member Davidelvig's Avatar
    Aug 2015
    Wisconsin
    351
    I'm on Sierra (Arduino 1.8.1, Teensyduino 1.35)
    3-year old MacBoo, with USB A sockets.
    It all works fine. I see "/dev/cu/usbmodem/943311 (Teensy)" as a second option (after my Bluetooth option)
    11,382
    Quote Originally Posted by lukicharms View Post
    Is this a brand new Teensy? Never been programmed?
    If so did you follow the instructions given: https://www.pjrc.com/teensy/td_usage.html
    In particular plug in the Teensy. Then load a simple program like blink (examples->01.basics->blink)
    Then click the verify command button in the Arduino IDE. (Make sure the appropriate Teensy is selected as the device and USB->Serial selected)
    After the compiles completes and the Teensy Loader program loads.
    push the program button on the Teensy. Did it show it download program? And hopefully a new serial port object created.
