Results 1 to 2 of 2
Thread: How to configure SPI1 on Tennsy3.6
    Dec 2016
    3
    I have problem how to configure SPI1 on Tennsy3.6? I try to connect to AD7175.
    Now I configure as below and then i check all pin in oscilloscope nothing happen.
    I test board is work on SPI0 connect to TCP module WIZ820io. Please help me about my mistake.( Thank you very much)
    int slaveSelectPin = 31;
    #define ID 0x0CD9
    unsigned int regValue;
    SPI1.setBitOrder(LSBFIRST);
    SPI1.setDataMode(SPI_MODE3);
    SPI1.setClockDivider(SPI_CLOCK_DIV16);
    SPI1.setSCK(32);
    SPI1.setMOSI(0);
    SPI1.setMISO(1);
    SPI1.setCS(31);
    SPI1.begin();
    pinMode(31,OUTPUT);
    pinMode(2,INPUT);
    //delayMicroseconds(1);
    SPI1.transfer(B01000111); // Bit 6 = 1 for read. Register 0x07 for ID register.
    //digitalWrite(slaveSelectPin,HIGH);
    digitalWrite(slaveSelectPin,LOW);
    byte b1 = SPI1.transfer(0);
    byte b0 = SPI1.transfer(0);
    byte b2 = SPI1.transfer(0);
    unsigned int result = b0 * 256 + b2;
    Serial.println(result, HEX);
    Attached Files Attached Files
    10,347
    Sorry, I don't know if I see anything obvious that would keep it from working at all. What Arduino/Teensyduino? pins actually connected (pictures help catch things like pins not soldered in...)
    Have you tried running it without your hardware connected to see if you get any signals, for example on the SCLK on Pin 31? Is anything printing, so we know the program is running...
    Some thoughts. I believe that some of these methods set some information in some of the registers that then get blasted by the call to begin. In particular the calls:
    Better yet replace these with calls to SPI1.beginTransfer(...) endTransfer
    So try putting them after the call to begin.
    The call to set
    SPI1.setCS(31);
    Is not needed as the SPI calls to transfer do not use the hardware SPI pins...
    You may want to also do a digitalWrite of that pin HIGH during setup to have it not asserted.
    Not sure of your code in loop is fully correct on usage of CS pin. I have not looked briefly at the spec for the chip you are using. I am not sure but this may be one of those chips that for read operations, that after you assert the CS, you then look at the state of one of the pins MISO? to see when the chip says it is OK to transfer. If so there have been a couple threads that talked about this, with a couple of options, like switch that momentarily to digital input, read, switch back to SPI, alternatively also connect that pin to another unused IO pin, that you configure to input and check the state there...
    Hopefully someone else who has used this chip will chime in.. But if not, maybe the loop needs to look more like:
    loop()
      digitalWrite(slaveSelectPin,LOW); // probably need to select for this transfer
      // Not sure if chip needs the chip select to go deassert after command and then reassert or wants
      // it asserted through transfer.  If it wants to toggle then you need.
      delayMicroseconds(1);   // may or may not need delay...
      // I don't think you need delays between cs and starting transfer but may need to either delay or check
      // state of IO pin mentioned above.
    Again I don't know enough about that chip to know if any of the above will help.
    One of the other threads talking about checking the MISO pin: https://forum.pjrc.com/threads/41608-reading-MISO
