i recently started playing around with the snooze library. I've noticed that when i attach an interrupt to a pin (not digital.pinMode but attachInterrupt) the interrupt will wake up my Teensy 3.6 from hibernation. Is this intended to be like this? As far as i understood the only pin interrupts that should wake up the Teensy are the ones declared by digital.pinMode but my normal Interrupts seem to wake the Teensy too.
Here is the code i've used:
#include <Snooze.h>
#define but_pin 23
#define but2_pin 10
boolean flag = true;
SnoozeDigital digital;
SnoozeBlock config_teensy36(digital);
pinMode(LED_BUILTIN, OUTPUT);
digital.pinMode(but2_pin, INPUT_PULLUP, LOW);
pinMode(but_pin, INPUT_PULLUP);
attachInterrupt(but_pin, button_int, LOW);
Snooze.hibernate( config_teensy36 );
delay(5000);
if (flag == true) {
for (int i = 0; i < 5; i++) {
delay(200);
delay(200);
flag = false;
void button_int() {
if (flag == false) {
flag = true;
Setup :
Teensy 3.6
Arduino IDE v1.8.1
Teensyduino v1.35
Snooze v6.2.5
