Been using teensy 3.2 for a while, have always had intermittant ethernet init issues. An annoying issue is that 820io inits properly for a while, then doesn't, giving 0.0.0.0 instead of my fixed IP address. I have a couple 3.6 boards with newer ethernet, thought I would try that. With same code and build, this first one inits at 255.255.255.255, apparently same error. The build is using older 5100.h.
I added a long delay after ethernet.begin as I read in one of the posts but this didn't seem to help. I am using the gpio dance listed on the 820io webpage but also didn't seem to help in either case. I'm currently using teensyduino 1.35.
How can I resolve fundamental init error? I want to be able to use either teensy for different applications. Code and build log attached.
thanks in advance,
tim
thanks in advance,
tim
