Results 1 to 3 of 3
Thread: 128x32 OLED display with teensy 3.2
    Sep 2016
    Mumbai
    16
    I am using teensy 3.2 along with audio adapter, and then I am also using pin 0 to pin 4. It is still possible to use 128x32 OLED display. I am not able to find tutorial explaining interfacing teensy 3.2 with 128x32 OLED using I2C.
    Regards,
    Tapas
    8,197
    Not sure, might help to know which OLED display.
    I believe the Audio adapter uses I2C on standard pins A4-A5. So you would need to have the display use the default I2C pins.
    Then the question is, is there a display driver for your display and does the driver work well with other I2C devices...
    Feb 2016
    Australia
    271
    I know that ssd1306 128x64 oled screens work with teensy 3.2/lc
    #include <i2c_t3.h>
    #include <Adafruit_GFX.h>
    #include "Adafruit_SSD1306.h"
    I put a local copy of Adafruit_SSD1306.h in my sketch folder and changed the include for wire.h to i2c_t3.h.
    Can't remember if I had to do much more than that.
    If that is any help.
