Results 1 to 5 of 5
Thread: does not name a type
    Can someone please help me, when i run this script or other programs which work with xplane:
    #include <Bounce.h>
    #include <Encoder.h>
    #include <DogLcd.h>
    // hardware objects, for accessing the buttons, rotary encoder and LCD
    Bounce buttonUp = Bounce(3, 5); // Pushbutton on pin 3, 5ms debounce
    Bounce buttonDown = Bounce(4, 5); // Pushbutton on pin 4, 5ms debounce
    Encoder wheel = Encoder(5, 6); // Rotary Encoder on pin 5 and 6
    DogLcd lcd = DogLcd(10, 9, 7, 8); // DogM LCD on pins 7, 8, 9, 10
    // X-Plane objects, 3 command refs and 1 data ref
    FlightSimCommand NavCoarseUp;
    FlightSimCommand NavCoarseDown;
    FlightSimCommand NavFineUp;
    FlightSimInteger NavFrequencyHz;
    // variables
    long encoder_prev=0; // for detecting rotary position change
    elapsedMillis inactivityTimeout;// an inactivity timeout
    // setup runs once, when Teensy boots.
    // initialize all hardware
    pinMode(3, INPUT_PULLUP); // input pullup mode allows connecting
    pinMode(4, INPUT_PULLUP); // buttons and switches from the pins
    pinMode(5, INPUT_PULLUP); // to ground, and the chip provide the
    pinMode(6, INPUT_PULLUP); // required pullup resistor :-)
    lcd.begin(DOG_LCD_M162);
    lcd.print("nav1:");
    // configure the X-Plane variables
    NavCoarseUp = XPlaneRef("sim/radios/actv_nav1_coarse_up");
    NavCoarseDown = XPlaneRef("sim/radios/actv_nav1_coarse_down");
    NavFineUp = XPlaneRef("sim/radios/actv_nav1_fine_up");
    NavFrequencyHz = XPlaneRef("sim/cockpit2/radios/actuators/nav1_frequency_hz");
    NavFrequencyHz.onChange(update_lcd); // update the LCD when X-Plane changes
    // loop runs repetitively, as long as Teensy is powered up
    // normally the first step in loop() should update from X-Plane
    FlightSim.update();
    // read the rotary encoder, if it's changed, write to NavFrequencyHz
    long enc = wheel.read();
    if (enc != encoder_prev) {
    NavFrequencyHz = NavFrequencyHz + (enc - encoder_prev);
    encoder_prev = enc;
    update_lcd(NavFrequencyHz);
    inactivityTimeout = 0; // reset the inactivity timeout
    // read the pushbuttons, and send X-Plane commands when they're pressed
    buttonUp.update();
    buttonDown.update();
    if (buttonUp.fallingEdge()) {
    NavCoarseUp = 1;
    if (buttonUp.risingEdge()) {
    NavCoarseUp = 0;
    if (buttonDown.fallingEdge()) {
    NavCoarseDown = 1;
    if (buttonDown.risingEdge()) {
    NavCoarseDown = 0;
    // if there's no user activity for 2 seconds, send the NavFineUp.
    // admittedly this is not very useful, but it's meant to demonstrate
    // possibility of automated actions in addition to driving everything
    // directly from physical user inputs.
    if (inactivityTimeout > 2000) {
    NavFineUp.once();
    // write a number onto the LCD, first row, starting at 6th column
    void update_lcd(long val)
    lcd.setCursor(6, 0);
    lcd.print(val);
    lcd.print(" ");
    i get a similar error saying:
    Arduino: 1.8.1 (Mac OS X), TD: 1.35, Board: "Teensy++ 2.0, Serial, 16 MHz, US English"
    NavFrequency:13: error: 'FlightSimCommand' does not name a type
    NavFrequency:14: error: 'FlightSimCommand' does not name a type
    NavFrequency:15: error: 'FlightSimCommand' does not name a type
    NavFrequency:16: error: 'FlightSimInteger' does not name a type
    NavFrequency: In function 'void setup()':
    NavFrequency:35: error: 'NavCoarseUp' was not declared in this scope
    NavFrequency:35: error: 'XPlaneRef' was not declared in this scope
    NavFrequency:36: error: 'NavCoarseDown' was not declared in this scope
    NavFrequency:37: error: 'NavFineUp' was not declared in this scope
    NavFrequency:38: error: 'NavFrequencyHz' was not declared in this scope
    NavFrequency: In function 'void loop()':
    NavFrequency:46: error: 'FlightSim' was not declared in this scope
    To make a Flight Simulator device, use the Tools > USB Type menu
    FlightSim.update();
    NavFrequency:51: error: 'NavFrequencyHz' was not declared in this scope
    NavFrequency:61: error: 'NavCoarseUp' was not declared in this scope
    NavCoarseUp = 1;
    NavFrequency:65: error: 'NavCoarseUp' was not declared in this scope
    NavCoarseUp = 0;
    NavFrequency:68: error: 'NavCoarseDown' was not declared in this scope
    NavCoarseDown = 1;
    NavFrequency:72: error: 'NavCoarseDown' was not declared in this scope
    NavCoarseDown = 0;
    NavFrequency:80: error: 'NavFineUp' was not declared in this scope
    NavFineUp.once();
    Can someone please help me fix this.
    Oct 2016
    Colchester, Essex, UK
    55
    These lines look like they are declaring variables of FlightSimCommand and FlightSimInteger types, but you haven't told the compiler what those types are.
    I suspect you have a header file missing.
    Also, what is the return type of your XPlaneRef function?
    It looks like you expect it to return a FlightSimCommand type in some uses, and a FlightSimInteger in other uses.
    Sorry i dont know much about this, whats a header file and where do i get the return type of my XplaneRef function?
    24,834
    Use the Tools > USB Type menu. Select Flight Sim Controls. That will cause Arduino to automatically do all this special header stuff (which you would have to do manually if not using Arduino).
    oh ok thanks! its working now
