Results 1 to 11 of 11
Thread: PWM phase shift - help
    Feb 2017
    8
    hi,
    is it possible to create 2 PWM-signals with one of them have a 90 degrees phase shift?
    i am looking for a solution that uses the teensy's internal hardware timers.
    i use a teensy 3.6.
    kind regards
    manuel
    Yes. Depending on the frequency and accuracy you need there would be different ways to do it.
    The Library interval timer gives you pretty robust access to up to 4 hardware timers.
    What frequency/PWM step size/accuracy were you looking for?
    Feb 2017
    8
    i need two 500kHz PWMs with 50% duty cycle.
    Oct 2016
    Colchester, Essex, UK
    55
    In the Flextimer section of the manual, look up "Complementary mode".
    20,454
    Try this:
            FTM3_SC = 0;    // halt timer
            FTM3_COMBINE = FTM_COMBINE_COMBINE1; // ch 2+3 = adjustable high/low points
            FTM3_C0V = 59;  // high at 50% of period
            FTM3_C2V = 29;  // high at 25% of period
            FTM3_C3V = 89;  // low at 75% of period
            FTM3_CNT = 0;   // reset timer
            FTM3_MOD = 119; // timer period (MOD+1 clocks of F_BUS)
            FTM3_SC = FTM_SC_CLKS(1) | FTM_SC_PS(0); // start timer
            // configure the pins to be controlled by FTM3 channels
            CORE_PIN2_CONFIG =  PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE; // ch0
            CORE_PIN7_CONFIG =  PORT_PCR_MUX(4) | PORT_PCR_DSE | PORT_PCR_SRE; // ch2+3
    The signals will be on pins 2 and 7.
    Feb 2017
    8
    yes thanks it works well!!!! i was just studying the manual, its really complicated.
    my last newbie question, why do the timers work only with 60MHz?
    20,454
    The FTM timers run from the "bus clock", which is limited to 60 MHz. See chapter 6 for details.
    Feb 2017
    8
    thank you very much for your help.
    is there an elegant way to trigger a "single shot"-signal as soon as the PWM-signal repeated x-times?
    my first idea was to create an ISR that counts the modulo-compare matches (PWM-periods) and after a specific count of repetitions i would output a short pulse,
    but maybe there are better ways? Can someone give me an advise where to look in the manual?
    Feb 2017
    8
    no ideas :-(???
    20,454
    Well, have you tried the obvious way of just writing zeros after a fixed amount of time? Did that not work? If so, what happened that wasn't good?
    Look, I wrote some code for you last night. But that's not the norm. I can't do every step for you, and I can't quick answer every question. You're going to have to try to take it from here and solve some of these things.
    Feb 2017
    8
    i understand you and thanks for your help... I want to emulate an shaft encoder, it should output a small pulse everytime when the encoder turns 360 degrees (equate to e.g. 1000 pulses). It should be possible to variate the angular-speed of the shaft-encoder during the simulation. But now i found out by myself how to count my PWM-cycles with an additional timer, without using interrupts. ... when i finish my little project i will post it in the forum :-)
    regards
    manuel
