Hi all,
I am new to the whole arduino programming thing. I am trying to use an Adafruit 3.5" resistive touch screen (SPI mode) with my new Teensy 3.2. I have gotten the graphics portion to work with the default breakouttouchpaint, but the touchscreen doesn't respond at all. I looked through a few of the other posts on here for answers, but I am still unable to get the touchscreen to work. I have tested the screen on my Mega2560 and everything works as expected, including the touchscreen. Any help is much appreciated.
My wiring is as follows:
Screen Teensy 3.2
GND GND (from USB)
Vin +5v (from USB)
CLK 13
MISO 12
MOSI 11
CS 25 (I need the hardware serial ports so I reassigned this pin)
D/C 26
RST 24
Lite N/C
Y+ A12
X+ 32
Y- 33
X- A13
The IM2 jumper solder pad jumper is soldered closed to enable SPI
Here is the complete source:
This is our touchscreen painting example for the Adafruit HX8357 Breakout
----> http://www.adafruit.com/products/2050
Check out the links above for our tutorials and wiring diagrams
These displays use SPI to communicate, 4 or 5 pins are required to
interface (RST is optional)
products from Adafruit!
MIT license, all text above must be included in any redistribution
/** NOT FOR USE WITH THE TOUCH SHIELD, ONLY FOR THE 3.5" BREAKOUT! **/
#include <Adafruit_GFX.h> // Core graphics library
#include "Adafruit_HX8357.h"
#include "TouchScreen.h"
// These are the four touchscreen analog pins
#define YP A12 // must be an analog pin, use "An" notation!
#define XM A13 // must be an analog pin, use "An" notation!
#define YM 33 // can be a digital pin
#define XP 32 // can be a digital pin
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 110
#define TS_MINY 80
#define TS_MAXX 900
#define TS_MAXY 940
#define MINPRESSURE 10
#define MAXPRESSURE 1000
// The display uses hardware SPI, plus #9 & #10
#define TFT_RST 24 // dont use a reset pin, tie to arduino RST if you like
#define TFT_DC 26
#define TFT_CS 25
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 200);
// Size of the color selection boxes and the paintbrush size
#define BOXSIZE 40
#define PENRADIUS 3
int oldcolor, currentcolor;
void setup(void) {
while (!Serial); // used for leonardo debugging
Serial.println(F("Touch Paint!"));
tft.begin(HX8357D);
tft.fillScreen(HX8357_BLACK);
// make the color selection boxes
tft.fillRect(0, 0, BOXSIZE, BOXSIZE, HX8357_RED);
tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, HX8357_YELLOW);
tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, HX8357_GREEN);
tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, HX8357_CYAN);
tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, HX8357_BLUE);
tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, HX8357_MAGENTA);
tft.fillRect(BOXSIZE*6, 0, BOXSIZE, BOXSIZE, HX8357_BLACK);
tft.fillRect(BOXSIZE*6, 0, BOXSIZE, BOXSIZE, HX8357_WHITE);
// select the current color 'red'
tft.drawRect(0, 0, BOXSIZE, BOXSIZE, HX8357_WHITE);
currentcolor = HX8357_RED;
// Retrieve a point
TSPoint p = ts.getPoint();
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
if (p.z < MINPRESSURE || p.z > MAXPRESSURE) {
return;
Serial.print("X = "); Serial.print(p.x);
Serial.print("\tY = "); Serial.print(p.y);
Serial.print("\tPressure = "); Serial.println(p.z);
// Scale from ~0->1000 to tft.width using the calibration #'s
p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
Serial.print("("); Serial.print(p.x);
Serial.print(", "); Serial.print(p.y);
Serial.println(")");
if (p.y < BOXSIZE) {
oldcolor = currentcolor;
if (p.x < BOXSIZE) {
} else if (p.x < BOXSIZE*2) {
currentcolor = HX8357_YELLOW;
tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, HX8357_WHITE);
} else if (p.x < BOXSIZE*3) {
currentcolor = HX8357_GREEN;
tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, HX8357_WHITE);
} else if (p.x < BOXSIZE*4) {
currentcolor = HX8357_CYAN;
tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, HX8357_WHITE);
} else if (p.x < BOXSIZE*5) {
currentcolor = HX8357_BLUE;
tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, HX8357_WHITE);
} else if (p.x < BOXSIZE*6) {
currentcolor = HX8357_MAGENTA;
tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, HX8357_WHITE);
} else if (p.x < BOXSIZE*7) {
currentcolor = HX8357_WHITE;
tft.drawRect(BOXSIZE*6, 0, BOXSIZE, BOXSIZE, HX8357_RED);
} else if (p.x < BOXSIZE*8) {
currentcolor = HX8357_BLACK;
tft.drawRect(BOXSIZE*7, 0, BOXSIZE, BOXSIZE, HX8357_WHITE);
if (oldcolor != currentcolor) {
if (oldcolor == HX8357_RED)
if (oldcolor == HX8357_YELLOW)
if (oldcolor == HX8357_GREEN)
if (oldcolor == HX8357_CYAN)
if (oldcolor == HX8357_BLUE)
if (oldcolor == HX8357_MAGENTA)
if (oldcolor == HX8357_WHITE)
if (oldcolor == HX8357_BLACK)
tft.fillRect(BOXSIZE*7, 0, BOXSIZE, BOXSIZE, HX8357_BLACK);
if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
Screen Teensy 3.2
GND GND (from USB)
Vin +5v (from USB)
CLK 13
MISO 12
MOSI 11
D/C 26
RST 24
Lite N/C
Y+ A12
X+ 32
Y- 33
X- A13
#define TS_MINX 110
#define TS_MINY 80
#define TS_MAXX 900
#define TS_MAXY 940
#define TFT_DC 26
#define TFT_CS 25
#define BOXSIZE 40
#define PENRADIUS 3
void setup(void) {
tft.begin(HX8357D);
// Retrieve a point
return;
