TechnoFrolics
Hello Paul,
I have not used your (very nice looking!) board previously, but am considering it for a museum/industrial-grade project where I need to stream multi-channel PWM data 24x7x365 from a C++ program running on Windows via USB.
My questions are:
1) Is the USB connection to a PC reliable enough to allow such industrial/museum use?
(I am not referring to mechanical USB connector - item will be within a protected box - but rather electrical/firmware issues.)
2) Does the answer to 1 (if in the affirmative) include environments where static discharges to nearby surrounding metal surfaces are present?
(E.g., museum visitors touching metal elements of cabinetry etc.)
3) Is there anything else I have omitted asking about that would contraindicate such a usage of your board?
Context for my question, based on over 25 years experience developing museum exhibits:
A) In the first half decade after USB's introduction, static sensitivity was so bad (whether due to USB hardware, USB firmware, or both, and whether originating on the PC side, the device side, or both) that sparking a 1ft x 1ft aluminum plate with Piezo charcoal lighter, *placed 2 feet away from USB keyboard and/or mouse (as well as many commercial I/O digital/analog data acquisition and machine control devices), and entirely unconnected to anything* (i.e., just EM pulse in space - no wired connection of any kind), would more times than not cause keyboard and/or mouse (and other "industrial-grade" USB I/O devices) to disconnect permanently until manual USB connector unplug/replug cycle or PC reboot.
(In consequence, we simply could not use USB - we had to use RS232/RS485 serial. Things are better now.)
B) Even today, over 1-1/2 decades after USB's introduction, we have found zero USB-connected hard drives that stay reliably connected to a Windows machine running 24x7x365.
(SATA virtually always fine - so not just "a Windows thing".)
Thank you,
David
My questions are:
Thank you,
David
