Sorry if this is documented somewhere, I just could not find it.
What is the current limit for digital io pins on the teensy 3.5?
I plan on having a mux chip supplying power to a LED, with a resistor limiting the current to the 20mA the LED wants.
Can I drive the other end of the LED directly from a teensy 3.5 digital output? So that I if the teensy outputs "0" while the mux outputs "1", the LED lights up. The teensy will output 1 to turn off the LED and then there will be no current regardless of what the MUX does.
