Teensy 3.2 ILI9341 Touch and SD wiring (ILI9341_t examples)
Hello
today my ili9341 arrived and i successfully wired the display pins which also can be found on this site: https://www.pjrc.com/store/display_ili9341.html
There are only 9 pins listed for the display but not the 5 pins for touch and 4 for the sd card. How must i wire them to be able to use the ILI9341_t examples for touchpaint and bitmap example?
Thanks a lot
Senior Member+
Thank you it works with this wiring but seems like the library used in the ILI9341_t examples arent made for this touch, didnt know I have to use a different one than for the ILI9328.
Senior Member+
If you are using the Touch ILI_9341 display above
It needs another library included to utilize the associated SPI TOUCH pins as noted on that page: The XPT2046 touch controller can be read with this XPT2046_Touchscreen library.
Yeah thanks for linking the library, its already working for me like i want it but it might help future people
Have a good night!
Sorry for the bump, but are there also some guides on how to wire the SD part of the ILI9341 (4 Pins SD_CS, SD_MOSI, SD_MISO, SD_SCK) to a Teensy 3.2?
Thanks for any help!
Senior Member+
If you look at the page for the display on the store, you will see:
We do not recommend using the SD card socket on this display. It does not work, but
this hardware modification may be able to get it working
Senior Member+
Other side note: I decided to upload a copy of my modified version of touchpaint which I called touchpaint_xpt2046 which is setup to use the touch sensor on the PJRC screen. I issed PR #44 (https://github.com/PaulStoffregen/ILI9341_t3/pull/44) with the program.
But as I mentioned in the PR I have not tested it in awhile with default IO pins. Testing was done on my Flexiboard which uses alternate SPI pins.
Also maybe could still use a little more TLC on the MIN/MAX values used to convert touch point to screen coordinates. They currently are set to what values I observed on my first PJRC touch screen.
Senior Member+
I see you found these numbers on your device (re-ordered to match my array below):
#define TS_MINX 337
#define TS_MAXX 3729
#define TS_MINY 529
#define TS_MAXY 3711
I found these numbers as integrated into sample in the tsMap[0] group - last touched Nov 2015 - not even updated for Interrupt pin usage as I did it:
TS_MAP tsMap[5] = { {
200, 3700, 325, 3670 }, { 0, 319, 0, 239 }, { 319, 0, 0, 239 }, { 319, 0, 239, 0 }, { 0, 319, 239, 0 } };
That link to a short sample that could be easily updated to show interrupt usage and perhaps other cleanup. But that tsMap[] array allows for run time rotation with calibrated pixel return - which that sample demonstrates, along with a way to use the display to post DEBUG text to specific lines.
That [0] element holds the MIN/MAX values and an interface could be added to allow them to be updated during setup. Would be good in combination with a test hit sample perhaps to put out the device specific values as used. Those could then be compiled into setup() at runtime. I got distracted with my button work and never got that integrated back into the XPT2046_Touchscreen itself. After a year some folks using my samples saw the points may not have been right - though I never saw feedback to follow up on as the above might allow correcting as displays evolve/change.
Kurt let me know if you see value in that - perhaps you might tackle it or twist my arm into making it so.
- You may not post replies
- You may not edit your posts
Forum Rules
