Results 1 to 18 of 18
Thread: Real-Time (Working) Vocoder
    Member Revalogics's Avatar
    Dec 2016
    Philippines
    79
    Hi everyone, this is a real-time vocoder code I developed a few days ago. It has two inputs: Voice In & Instrument/Synth In. It outputs the sound of the instrument with the voice syllables superimposed or somewhat combined with it. No extra libraries needed and no library modifications is needed, the original Teensyduino-supplied libraries work with it.
    The idea is based on the block diagram of MFOS DIY Vocoder. I made a school project based on it a couple of years ago but I didn't made it to work properly (components out-of-stock in my country hahaha). At least by using a Teensy, my dream came true .
    Sorry, the code is long but is worth it. Hardware used were Teensy 3.6, a board I found on my toolbox which has UDA1345TS 24-bit CODEC chip on it for I2C testing, a PC, and a headphone or speaker.
    Test Tracks (zip file, 9.23 MB) is available (you need to extract the contents of it first), play it and input to Teensy and listen to Teensy's output.
    UPDATE: Test Tracks + Output Recordings + ".ino" code + other stuffs (zip file, 13 MB) is also available through 4shared or Google Drive.
ID:	9825 Nodes everyone?
     * 19-Channel Vocoder                                           *
     * Left input is voice input                                    *
     * Right input is instrument/synth input                        *
     * Input is both in I2S and USB, with programmable gain         *
     * Output is both in I2S and USB                                *
     * My 37-channel Vocoder does not work, all I heard was noise.  *
     * I didn't have an Audio Shield, I used UDA1345TS 24bit Codec  *
     * for I2S testing. Note, the code is a bit long (768 lines),   *
     * but it is commented for you to understand its functions.     *
     * Testing Parameters                                           *
     *   Hardware: Teensy 3.6                                      *
     *   Teensyduino Version: 1.35                                 *
     *   USB Type: Serial + MIDI + Audio                           *
     *   CPU Speed: 240 MHz (overclock)                            *
     *   Optimize: Faster                                          *
     *   Audio Input: USB (routed to MP3 player)                   *
     *   Audio Output: USB (routed to headphone out)               *
     *   Processor Usage Max = 69.84                               *
     *   Memory Usage Max = 31                                     *
     * Using lower CPU speeds is possible, down to 168 MHz but you  *
     * need to adjust attack parameter (line 295).                  *
     * Memory usage isn't affected by CPU speed.                    *
     * Coded by Revalogics                                          *
    #include <Audio.h>                                              // no libraries were harmed (modified)
    AudioInputI2S            i2s1;           //xy=171,527
    AudioInputUSB            usb1;           //xy=171,559
    AudioMixer4              mixer1;         //xy=315,510
    AudioMixer4              mixer2;         //xy=315,572
    AudioFilterStateVariable filter39;       //xy=481,645
    AudioFilterStateVariable filter41;       //xy=481,691
    AudioFilterStateVariable filter43;       //xy=481,736
    AudioFilterStateVariable filter45;       //xy=481,782
    AudioFilterStateVariable filter47;       //xy=481,828
    AudioFilterStateVariable filter49;       //xy=481,874
    AudioFilterStateVariable filter51;       //xy=481,920
    AudioFilterStateVariable filter1;        //xy=488,112
    AudioFilterStateVariable filter3;        //xy=488,158
    AudioFilterStateVariable filter5;        //xy=488,203
    AudioFilterStateVariable filter7;        //xy=488,249
    AudioFilterStateVariable filter9;        //xy=488,295
    AudioFilterStateVariable filter11;       //xy=488,341
    AudioFilterStateVariable filter13;       //xy=488,387
    AudioAnalyzePeak         peak20;         //xy=546,513
    AudioAnalyzePeak         peak21;         //xy=546,552
    AudioFilterStateVariable filter40;       //xy=620,644
    AudioFilterStateVariable filter42;       //xy=620,690
    AudioFilterStateVariable filter44;       //xy=620,735
    AudioFilterStateVariable filter46;       //xy=620,781
    AudioFilterStateVariable filter48;       //xy=620,827
    AudioFilterStateVariable filter50;       //xy=620,873
    AudioFilterStateVariable filter52;       //xy=620,919
    AudioFilterStateVariable filter2;        //xy=627,111
    AudioFilterStateVariable filter4;        //xy=627,157
    AudioFilterStateVariable filter6;        //xy=627,202
    AudioFilterStateVariable filter8;        //xy=627,248
    AudioFilterStateVariable filter10;       //xy=627,294
    AudioFilterStateVariable filter12;       //xy=627,340
    AudioFilterStateVariable filter14;       //xy=627,386
    AudioAnalyzePeak         peak7;          //xy=770,386
    AudioAnalyzePeak         peak3;          //xy=771,202
    AudioAnalyzePeak         peak4;          //xy=771,248
    AudioAnalyzePeak         peak5;          //xy=771,295
    AudioAnalyzePeak         peak6;          //xy=771,340
    AudioAnalyzePeak         peak1;          //xy=772,110
    AudioAnalyzePeak         peak2;          //xy=772,157
    AudioMixer4              mixer3;         //xy=853,1023
    AudioMixer4              mixer4;         //xy=854,1085
    AudioFilterStateVariable filter53;       //xy=913,643
    AudioFilterStateVariable filter55;       //xy=913,689
    AudioFilterStateVariable filter57;       //xy=913,734
    AudioFilterStateVariable filter59;       //xy=913,780
    AudioFilterStateVariable filter61;       //xy=913,826
    AudioFilterStateVariable filter63;       //xy=913,872
    AudioFilterStateVariable filter65;       //xy=913,918
    AudioFilterStateVariable filter15;       //xy=920,110
    AudioFilterStateVariable filter17;       //xy=920,156
    AudioFilterStateVariable filter19;       //xy=920,201
    AudioFilterStateVariable filter21;       //xy=920,247
    AudioFilterStateVariable filter23;       //xy=920,293
    AudioFilterStateVariable filter25;       //xy=920,339
    AudioFilterStateVariable filter27;       //xy=920,385
    AudioFilterStateVariable filter54;       //xy=1052,642
    AudioFilterStateVariable filter56;       //xy=1052,688
    AudioFilterStateVariable filter58;       //xy=1052,733
    AudioFilterStateVariable filter60;       //xy=1052,779
    AudioFilterStateVariable filter62;       //xy=1052,825
    AudioFilterStateVariable filter64;       //xy=1052,871
    AudioFilterStateVariable filter66;       //xy=1052,917
    AudioFilterStateVariable filter16;       //xy=1059,109
    AudioFilterStateVariable filter18;       //xy=1059,155
    AudioFilterStateVariable filter20;       //xy=1059,200
    AudioFilterStateVariable filter22;       //xy=1059,246
    AudioFilterStateVariable filter24;       //xy=1059,292
    AudioFilterStateVariable filter26;       //xy=1059,338
    AudioFilterStateVariable filter28;       //xy=1059,384
    AudioSynthNoiseWhite     noise1;         //xy=1189,526
    AudioAnalyzePeak         peak14;         //xy=1202,384
    AudioAnalyzePeak         peak10;         //xy=1203,200
    AudioAnalyzePeak         peak11;         //xy=1203,246
    AudioAnalyzePeak         peak12;         //xy=1203,293
    AudioAnalyzePeak         peak13;         //xy=1203,338
    AudioAnalyzePeak         peak8;          //xy=1204,109
    AudioAnalyzePeak         peak9;          //xy=1204,155
    AudioMixer4              mixer5;         //xy=1317,1025
    AudioMixer4              mixer6;         //xy=1318,1087
    AudioFilterStateVariable filter67;       //xy=1350,641
    AudioFilterStateVariable filter69;       //xy=1350,687
    AudioFilterStateVariable filter71;       //xy=1350,732
    AudioFilterStateVariable filter73;       //xy=1350,778
    AudioFilterStateVariable filter75;       //xy=1350,824
    AudioFilterStateVariable filter77;       //xy=1350,870
    AudioFilterStateVariable filter29;       //xy=1356,107
    AudioFilterStateVariable filter31;       //xy=1356,153
    AudioFilterStateVariable filter33;       //xy=1356,198
    AudioFilterStateVariable filter35;       //xy=1356,244
    AudioFilterStateVariable filter37;       //xy=1356,290
    AudioFilterStateVariable filter68;       //xy=1489,640
    AudioFilterStateVariable filter70;       //xy=1489,686
    AudioFilterStateVariable filter72;       //xy=1489,731
    AudioFilterStateVariable filter74;       //xy=1489,777
    AudioFilterStateVariable filter76;       //xy=1489,823
    AudioFilterStateVariable filter78;       //xy=1489,869
    AudioFilterStateVariable filter30;       //xy=1495,106
    AudioFilterStateVariable filter32;       //xy=1495,152
    AudioFilterStateVariable filter34;       //xy=1495,197
    AudioFilterStateVariable filter36;       //xy=1495,243
    AudioFilterStateVariable filter38;       //xy=1495,289
    AudioAnalyzePeak         peak17;         //xy=1639,197
    AudioAnalyzePeak         peak18;         //xy=1639,243
    AudioAnalyzePeak         peak19;         //xy=1639,290
    AudioAnalyzePeak         peak15;         //xy=1640,106
    AudioAnalyzePeak         peak16;         //xy=1640,152
    AudioMixer4              mixer9;         //xy=1639,1023
    AudioMixer4              mixer10;        //xy=1641,1085
    AudioMixer4              mixer7;         //xy=1694,728
    AudioMixer4              mixer8;         //xy=1695,791
    AudioMixer4              mixer11;        //xy=1803,1050
    AudioAnalyzePeak         peak22;         //xy=1961,991
    AudioOutputI2S           i2s2;           //xy=1965,1033
    AudioOutputUSB           usb2;           //xy=1965,1064
    AudioConnection          patchCord1(i2s1, 0, mixer1, 0);
    AudioConnection          patchCord2(i2s1, 1, mixer2, 0);
    AudioConnection          patchCord3(usb1, 0, mixer1, 1);
    AudioConnection          patchCord4(usb1, 1, mixer2, 1);
    AudioConnection          patchCord5(mixer1, 0, filter1, 0);
    AudioConnection          patchCord6(mixer1, 0, filter3, 0);
    AudioConnection          patchCord7(mixer1, 0, filter5, 0);
    AudioConnection          patchCord8(mixer1, 0, filter7, 0);
    AudioConnection          patchCord9(mixer1, 0, filter9, 0);
    AudioConnection          patchCord10(mixer1, 0, filter11, 0);
    AudioConnection          patchCord11(mixer1, 0, filter13, 0);
    AudioConnection          patchCord12(mixer1, 0, filter15, 0);
    AudioConnection          patchCord13(mixer1, 0, filter17, 0);
    AudioConnection          patchCord14(mixer1, 0, filter19, 0);
    AudioConnection          patchCord15(mixer1, 0, filter21, 0);
    AudioConnection          patchCord16(mixer1, 0, filter23, 0);
    AudioConnection          patchCord17(mixer1, 0, filter25, 0);
    AudioConnection          patchCord18(mixer1, 0, filter27, 0);
    AudioConnection          patchCord19(mixer1, 0, filter29, 0);
    AudioConnection          patchCord20(mixer1, 0, filter31, 0);
    AudioConnection          patchCord21(mixer1, 0, filter33, 0);
    AudioConnection          patchCord22(mixer1, 0, filter35, 0);
    AudioConnection          patchCord23(mixer1, 0, filter37, 0);
    AudioConnection          patchCord24(mixer1, peak20);
    AudioConnection          patchCord25(mixer2, 0, filter39, 0);
    AudioConnection          patchCord26(mixer2, 0, filter41, 0);
    AudioConnection          patchCord27(mixer2, 0, filter43, 0);
    AudioConnection          patchCord28(mixer2, 0, filter45, 0);
    AudioConnection          patchCord29(mixer2, 0, filter47, 0);
    AudioConnection          patchCord30(mixer2, 0, filter49, 0);
    AudioConnection          patchCord31(mixer2, 0, filter51, 0);
    AudioConnection          patchCord32(mixer2, 0, filter53, 0);
    AudioConnection          patchCord33(mixer2, 0, filter55, 0);
    AudioConnection          patchCord34(mixer2, 0, filter57, 0);
    AudioConnection          patchCord35(mixer2, 0, filter59, 0);
    AudioConnection          patchCord36(mixer2, 0, filter61, 0);
    AudioConnection          patchCord37(mixer2, 0, filter63, 0);
    AudioConnection          patchCord38(mixer2, 0, filter65, 0);
    AudioConnection          patchCord39(mixer2, 0, filter67, 0);
    AudioConnection          patchCord40(mixer2, 0, filter69, 0);
    AudioConnection          patchCord41(mixer2, 0, filter71, 0);
    AudioConnection          patchCord42(mixer2, 0, filter73, 0);
    AudioConnection          patchCord43(mixer2, 0, filter75, 0);
    AudioConnection          patchCord44(mixer2, 0, mixer11, 2);
    AudioConnection          patchCord45(mixer2, peak21);
    AudioConnection          patchCord46(filter39, 0, filter40, 0);
    AudioConnection          patchCord47(filter41, 1, filter42, 0);
    AudioConnection          patchCord48(filter43, 1, filter44, 0);
    AudioConnection          patchCord49(filter45, 1, filter46, 0);
    AudioConnection          patchCord50(filter47, 1, filter48, 0);
    AudioConnection          patchCord51(filter49, 1, filter50, 0);
    AudioConnection          patchCord52(filter51, 1, filter52, 0);
    AudioConnection          patchCord53(filter1, 0, filter2, 0);
    AudioConnection          patchCord54(filter3, 1, filter4, 0);
    AudioConnection          patchCord55(filter5, 1, filter6, 0);
    AudioConnection          patchCord56(filter7, 1, filter8, 0);
    AudioConnection          patchCord57(filter9, 1, filter10, 0);
    AudioConnection          patchCord58(filter11, 1, filter12, 0);
    AudioConnection          patchCord59(filter13, 1, filter14, 0);
    AudioConnection          patchCord60(filter40, 0, mixer3, 0);
    AudioConnection          patchCord61(filter42, 1, mixer3, 1);
    AudioConnection          patchCord62(filter44, 1, mixer3, 2);
    AudioConnection          patchCord63(filter46, 1, mixer3, 3);
    AudioConnection          patchCord64(filter48, 1, mixer4, 0);
    AudioConnection          patchCord65(filter50, 1, mixer4, 1);
    AudioConnection          patchCord66(filter52, 1, mixer4, 2);
    AudioConnection          patchCord67(filter2, 0, peak1, 0);
    AudioConnection          patchCord68(filter4, 1, peak2, 0);
    AudioConnection          patchCord69(filter6, 1, peak3, 0);
    AudioConnection          patchCord70(filter8, 1, peak4, 0);
    AudioConnection          patchCord71(filter10, 1, peak5, 0);
    AudioConnection          patchCord72(filter12, 1, peak6, 0);
    AudioConnection          patchCord73(filter14, 1, peak7, 0);
    AudioConnection          patchCord74(mixer3, 0, mixer9, 0);
    AudioConnection          patchCord75(mixer4, 0, mixer9, 1);
    AudioConnection          patchCord76(filter53, 1, filter54, 0);
    AudioConnection          patchCord77(filter55, 1, filter56, 0);
    AudioConnection          patchCord78(filter57, 1, filter58, 0);
    AudioConnection          patchCord79(filter59, 1, filter60, 0);
    AudioConnection          patchCord80(filter61, 1, filter62, 0);
    AudioConnection          patchCord81(filter63, 1, filter64, 0);
    AudioConnection          patchCord82(filter65, 1, filter66, 0);
    AudioConnection          patchCord83(filter15, 1, filter16, 0);
    AudioConnection          patchCord84(filter17, 1, filter18, 0);
    AudioConnection          patchCord85(filter19, 1, filter20, 0);
    AudioConnection          patchCord86(filter21, 1, filter22, 0);
    AudioConnection          patchCord87(filter23, 1, filter24, 0);
    AudioConnection          patchCord88(filter25, 1, filter26, 0);
    AudioConnection          patchCord89(filter27, 1, filter28, 0);
    AudioConnection          patchCord90(filter54, 1, mixer5, 0);
    AudioConnection          patchCord91(filter56, 1, mixer5, 1);
    AudioConnection          patchCord92(filter58, 1, mixer5, 2);
    AudioConnection          patchCord93(filter60, 1, mixer5, 3);
    AudioConnection          patchCord94(filter62, 1, mixer6, 0);
    AudioConnection          patchCord95(filter64, 1, mixer6, 1);
    AudioConnection          patchCord96(filter66, 1, mixer6, 2);
    AudioConnection          patchCord97(filter16, 1, peak8, 0);
    AudioConnection          patchCord98(filter18, 1, peak9, 0);
    AudioConnection          patchCord99(filter20, 1, peak10, 0);
    AudioConnection          patchCord100(filter22, 1, peak11, 0);
    AudioConnection          patchCord101(filter24, 1, peak12, 0);
    AudioConnection          patchCord102(filter26, 1, peak13, 0);
    AudioConnection          patchCord103(filter28, 1, peak14, 0);
    AudioConnection          patchCord104(noise1, 0, filter77, 0);
    AudioConnection          patchCord105(mixer5, 0, mixer9, 2);
    AudioConnection          patchCord106(mixer6, 0, mixer9, 3);
    AudioConnection          patchCord107(filter67, 1, filter68, 0);
    AudioConnection          patchCord108(filter69, 1, filter70, 0);
    AudioConnection          patchCord109(filter71, 1, filter72, 0);
    AudioConnection          patchCord110(filter73, 1, filter74, 0);
    AudioConnection          patchCord111(filter75, 2, filter76, 0);
    AudioConnection          patchCord112(filter77, 2, filter78, 0);
    AudioConnection          patchCord113(filter29, 1, filter30, 0);
    AudioConnection          patchCord114(filter31, 1, filter32, 0);
    AudioConnection          patchCord115(filter33, 1, filter34, 0);
    AudioConnection          patchCord116(filter35, 1, filter36, 0);
    AudioConnection          patchCord117(filter37, 2, filter38, 0);
    AudioConnection          patchCord118(filter68, 1, mixer7, 0);
    AudioConnection          patchCord119(filter70, 1, mixer7, 1);
    AudioConnection          patchCord120(filter72, 1, mixer7, 2);
    AudioConnection          patchCord121(filter74, 1, mixer7, 3);
    AudioConnection          patchCord122(filter76, 1, mixer8, 0);
    AudioConnection          patchCord123(filter78, 1, mixer8, 1);
    AudioConnection          patchCord124(filter30, 1, peak15, 0);
    AudioConnection          patchCord125(filter32, 1, peak16, 0);
    AudioConnection          patchCord126(filter34, 1, peak17, 0);
    AudioConnection          patchCord127(filter36, 1, peak18, 0);
    AudioConnection          patchCord128(filter38, 2, peak19, 0);
    AudioConnection          patchCord129(mixer9, 0, mixer11, 0);
    AudioConnection          patchCord130(mixer10, 0, mixer11, 1);
    AudioConnection          patchCord131(mixer7, 0, mixer10, 0);
    AudioConnection          patchCord132(mixer8, 0, mixer10, 1);
    AudioConnection          patchCord133(mixer11, 0, i2s2, 0);
    AudioConnection          patchCord134(mixer11, 0, i2s2, 1);
    AudioConnection          patchCord135(mixer11, 0, usb2, 0);
    AudioConnection          patchCord136(mixer11, 0, usb2, 1);
    AudioConnection          patchCord137(mixer11, peak22);
    elapsedMillis serialtimer;
    const float res = 5;                                            // this is used as resonance value of all state variable filters
    const float attack = 0.99588;                                   // controls attack and decay, must not exceed or equal 1,
        // going near 1 decreases attack, must be set at a right value to minimize distortion,
        // while still responsive to voice, this parameter is CPU speed dependent
    const float threshold = 0.1;                                    // threshold value used to limit sound levels going to mixer used as amplitude
        // modulators
    const float freq[37] = {                                        // filter frequency table, tuned to specified musical notes
      110.0000000,  // A2   freq[0]
      123.4708253,  // B2   freq[1]
      138.5913155,  // C#3  freq[2]
      155.5634919,  // D#3  freq[3]
      174.6141157,  // F3   freq[4]
      195.9977180,  // G3   freq[5]
      220.0000000,  // A3   freq[6]
      246.9416506,  // B3   freq[7]
      277.1826310,  // C#4  freq[8]
      311.1269837,  // D#4  freq[9]
      349.2282314,  // F4   freq[10]
      391.9954360,  // G4   freq[11]
      440.0000000,  // A4   freq[12]
      493.8833013,  // B4   freq[13]
      554.3652620,  // C#5  freq[14]
      622.2539674,  // D#5  freq[15]
      698.4564629,  // F5   freq[16]
      783.9908720,  // G5   freq[17]
      880.0000000,  // A5   freq[18]
      987.7666025,  // B5   freq[19]
      1108.730524,  // C#6  freq[20]
      1244.507935,  // D#6  freq[21]
      1396.912926,  // F6   freq[22]
      1567.981744,  // G6   freq[23]
      1760.000000,  // A6   freq[24]
      1975.533205,  // B6   freq[25]
      2217.461048,  // C#7  freq[26]
      2489.015870,  // D#7  freq[27]
      2793.825851,  // F7   freq[28]
      3135.963488,  // G7   freq[29]
      3520.000000,  // A7   freq[30]
      3951.066410,  // B7   freq[31]
      4434.922096,  // C#8  freq[32]
      4978.031740,  // D#8  freq[33]
      5587.651703,  // F8   freq[34]
      6271.926976,  // G8   freq[35]
      7040.000000   // A8   freq[36]
    float peak1raw, peak2raw, peak3raw, peak4raw, peak5raw, peak6raw,
      peak7raw, peak8raw, peak9raw, peak10raw, peak11raw, peak12raw,
      peak13raw, peak14raw, peak15raw, peak16raw, peak17raw, peak18raw,
      peak19raw;
    float peak1val, peak2val, peak3val, peak4val, peak5val, peak6val,
      peak7val, peak8val, peak9val, peak10val, peak11val, peak12val,
      peak13val, peak14val, peak15val, peak16val, peak17val, peak18val,
      peak19val;
      AudioMemory(64);                                              // allocate some memory for audio library
      Serial.begin(115200);                                         // initialize serial communication
      noise1.amplitude(0.7);                                        // controls sibilance (hiss syllables)
      mixer1.gain(0, 0);                                            // I2S left input level
      mixer1.gain(1, 1);                                            // USB left input level
      mixer2.gain(0, 0);                                            // I2S right input level
      mixer2.gain(1, 1);                                            // USB right input level
      mixer11.gain(0, 1);                                           // vocoder output 1 level (low-mid freq)
      mixer11.gain(1, 1);                                           // vocoder output 2 level (high freq)
      mixer11.gain(2, 0);                                           // instrument to output mix level
      filter1.resonance(res);                                       // set the resonance of the filters
      filter2.resonance(res);
      filter3.resonance(res);
      filter4.resonance(res);
      filter5.resonance(res);
      filter6.resonance(res);
      filter7.resonance(res);
      filter8.resonance(res);
      filter9.resonance(res);
      filter10.resonance(res);
      filter11.resonance(res);
      filter12.resonance(res);
      filter13.resonance(res);
      filter14.resonance(res);
      filter15.resonance(res);
      filter16.resonance(res);
      filter17.resonance(res);
      filter18.resonance(res);
      filter19.resonance(res);
      filter20.resonance(res);
      filter21.resonance(res);
      filter22.resonance(res);
      filter23.resonance(res);
      filter24.resonance(res);
      filter25.resonance(res);
      filter26.resonance(res);
      filter27.resonance(res);
      filter28.resonance(res);
      filter29.resonance(res);
      filter30.resonance(res);
      filter31.resonance(res);
      filter32.resonance(res);
      filter33.resonance(res);
      filter34.resonance(res);
      filter35.resonance(res);
      filter36.resonance(res);
      filter37.resonance(res);
      filter38.resonance(res);
      filter39.resonance(res);
      filter40.resonance(res);
      filter41.resonance(res);
      filter42.resonance(res);
      filter43.resonance(res);
      filter44.resonance(res);
      filter45.resonance(res);
      filter46.resonance(res);
      filter47.resonance(res);
      filter48.resonance(res);
      filter49.resonance(res);
      filter50.resonance(res);
      filter51.resonance(res);
      filter52.resonance(res);
      filter53.resonance(res);
      filter54.resonance(res);
      filter55.resonance(res);
      filter56.resonance(res);
      filter57.resonance(res);
      filter58.resonance(res);
      filter59.resonance(res);
      filter60.resonance(res);
      filter61.resonance(res);
      filter62.resonance(res);
      filter63.resonance(res);
      filter64.resonance(res);
      filter65.resonance(res);
      filter66.resonance(res);
      filter67.resonance(res);
      filter68.resonance(res);
      filter69.resonance(res);
      filter70.resonance(res);
      filter71.resonance(res);
      filter72.resonance(res);
      filter73.resonance(res);
      filter74.resonance(res);
      filter75.resonance(res);
      filter76.resonance(res);
      filter77.resonance(res);
      filter78.resonance(res);
      filter1.frequency(freq[0]);                                   // set the frequencies of the filters
      filter2.frequency(freq[0]);                                   // frequencies are assigned to a pair of filters because they are cascaded
      filter3.frequency(freq[2]);                                   // two sets of filters are used: for voice signal analysis and instrument/synth filter
      filter4.frequency(freq[2]);
      filter5.frequency(freq[4]);
      filter6.frequency(freq[4]);
      filter7.frequency(freq[6]);
      filter8.frequency(freq[6]);
      filter9.frequency(freq[8]);
      filter10.frequency(freq[8]);
      filter11.frequency(freq[10]);
      filter12.frequency(freq[10]);
      filter13.frequency(freq[12]);
      filter14.frequency(freq[12]);
      filter15.frequency(freq[14]);
      filter16.frequency(freq[14]);
      filter17.frequency(freq[16]);
      filter18.frequency(freq[16]);
      filter19.frequency(freq[18]);
      filter20.frequency(freq[18]);
      filter21.frequency(freq[20]);
      filter22.frequency(freq[20]);
      filter23.frequency(freq[22]);
      filter24.frequency(freq[22]);
      filter25.frequency(freq[24]);
      filter26.frequency(freq[24]);
      filter27.frequency(freq[26]);
      filter28.frequency(freq[26]);
      filter29.frequency(freq[28]);
      filter30.frequency(freq[28]);
      filter31.frequency(freq[30]);
      filter32.frequency(freq[30]);
      filter33.frequency(freq[32]);
      filter34.frequency(freq[32]);
      filter35.frequency(freq[34]);
      filter36.frequency(freq[34]);
      filter37.frequency(freq[36]);
      filter38.frequency(freq[36]);
      filter39.frequency(freq[0]);
      filter40.frequency(freq[0]);
      filter41.frequency(freq[2]);
      filter42.frequency(freq[2]);
      filter43.frequency(freq[4]);
      filter44.frequency(freq[4]);
      filter45.frequency(freq[6]);
      filter46.frequency(freq[6]);
      filter47.frequency(freq[8]);
      filter48.frequency(freq[8]);
      filter49.frequency(freq[10]);
      filter50.frequency(freq[10]);
      filter51.frequency(freq[12]);
      filter52.frequency(freq[12]);
      filter53.frequency(freq[14]);
      filter54.frequency(freq[14]);
      filter55.frequency(freq[16]);
      filter56.frequency(freq[16]);
      filter57.frequency(freq[18]);
      filter58.frequency(freq[18]);
      filter59.frequency(freq[20]);
      filter60.frequency(freq[20]);
      filter61.frequency(freq[22]);
      filter62.frequency(freq[22]);
      filter63.frequency(freq[24]);
      filter64.frequency(freq[24]);
      filter65.frequency(freq[26]);
      filter66.frequency(freq[26]);
      filter67.frequency(freq[28]);
      filter68.frequency(freq[28]);
      filter69.frequency(freq[30]);
      filter70.frequency(freq[30]);
      filter71.frequency(freq[32]);
      filter72.frequency(freq[32]);
      filter73.frequency(freq[34]);
      filter74.frequency(freq[34]);
      filter75.frequency(freq[36]);
      filter76.frequency(freq[36]);
      filter77.frequency(freq[36]);                                 // last pair of filters are used for sibilance
      filter78.frequency(freq[36]);                                 // input is a white noise, instead of instrument/synth
      peak1val = 1;                                                 // initialize peak values
      peak2val = 1;
      peak3val = 1;
      peak4val = 1;
      peak5val = 1;
      peak6val = 1;
      peak7val = 1;
      peak8val = 1;
      peak9val = 1;
      peak10val = 1;
      peak11val = 1;
      peak12val = 1;
      peak13val = 1;
      peak14val = 1;
      peak15val = 1;
      peak16val = 1;
      peak17val = 1;
      peak18val = 1;
      peak19val = 1;
      AudioProcessorUsageMaxReset();                                // and reset these things
      AudioMemoryUsageMaxReset();
      if(peak1.available()) {                                       // store peak values at each read
        peak1raw = peak1.read();
      if(peak2.available()) {
        peak2raw = peak2.read();
      if(peak3.available()) {
        peak3raw = peak3.read();
      if(peak4.available()) {
        peak4raw = peak4.read();
      if(peak5.available()) {
        peak5raw = peak5.read();
      if(peak6.available()) {
        peak6raw = peak6.read();
      if(peak7.available()) {
        peak7raw = peak7.read();
      if(peak8.available()) {
        peak8raw = peak8.read();
      if(peak9.available()) {
        peak9raw = peak9.read();
      if(peak10.available()) {
        peak10raw = peak10.read();
      if(peak11.available()) {
        peak11raw = peak11.read();
      if(peak12.available()) {
        peak12raw = peak12.read();
      if(peak13.available()) {
        peak13raw = peak13.read();
      if(peak14.available()) {
        peak14raw = peak14.read();
      if(peak15.available()) {
        peak15raw = peak15.read();
      if(peak16.available()) {
        peak16raw = peak16.read();
      if(peak17.available()) {
        peak17raw = peak17.read();
      if(peak18.available()) {
        peak18raw = peak18.read();
      if(peak19.available()) {
        peak19raw = peak19.read();
      if((peak1raw * threshold) > peak1val) {                       // simulate envelope follower: it gets the envelope of the filtered signal through
        peak1val = peak1val / attack;                               // the peak values and is used to determine the direction (increase or decrease) of
        mixer3.gain(0, peak1val);                                   // the mixer gain
      }                                                             // filters won't work here because it is implemented as a sample-and-hold code
      if((peak1raw * threshold) < peak1val) {                       // peak values used to set mixer gain are divided to increase or multiplied to decrease
        peak1val = peak1val * attack;                               // the values must not change fast to avoid distortion
      if((peak2raw * threshold) > peak2val) {
        peak2val = peak2val / attack;
        mixer3.gain(1, peak2val);
      if((peak2raw * threshold) < peak2val) {
        peak2val = peak2val * attack;
      if((peak3raw * threshold) > peak3val) {
        peak3val = peak3val / attack;
        mixer3.gain(2, peak3val);
      if((peak3raw * threshold) < peak3val) {
        peak3val = peak3val * attack;
      if((peak4raw * threshold) > peak4val) {
        peak4val = peak4val / attack;
        mixer3.gain(3, peak4val);
      if((peak4raw * threshold) < peak4val) {
        peak4val = peak4val * attack;
      if((peak5raw * threshold) > peak5val) {
        peak5val = peak5val / attack;
        mixer4.gain(0, peak5val);
      if((peak5raw * threshold) < peak5val) {
        peak5val = peak5val * attack;
      if((peak6raw * threshold) > peak6val) {
        peak6val = peak6val / attack;
        mixer4.gain(1, peak6val);
      if((peak6raw * threshold) < peak6val) {
        peak6val = peak6val * attack;
      if((peak7raw * threshold) > peak7val) {
        peak7val = peak7val / attack;
        mixer4.gain(2, peak7val);
      if((peak7raw * threshold) < peak7val) {
        peak7val = peak7val * attack;
      if((peak8raw * threshold) > peak8val) {
        peak8val = peak8val / attack;
        mixer5.gain(0, peak8val);
      if((peak8raw * threshold) < peak8val) {
        peak8val = peak8val * attack;
      if((peak9raw * threshold) > peak9val) {
        peak9val = peak9val / attack;
        mixer5.gain(1, peak9val);
      if((peak9raw * threshold) < peak9val) {
        peak9val = peak9val * attack;
      if((peak10raw * threshold) > peak10val) {
        peak10val = peak10val / attack;
        mixer5.gain(2, peak10val);
      if((peak10raw * threshold) < peak10val) {
        peak10val = peak10val * attack;
      if((peak11raw * threshold) > peak11val) {
        peak11val = peak11val / attack;
        mixer5.gain(3, peak11val);
      if((peak11raw * threshold) < peak11val) {
        peak11val = peak11val * attack;
      if((peak12raw * threshold) > peak12val) {
        peak12val = peak12val / attack;
        mixer6.gain(0, peak12val);
      if((peak12raw * threshold) < peak12val) {
        peak12val = peak12val * attack;
      if((peak13raw * threshold) > peak13val) {
        peak13val = peak13val / attack;
        mixer6.gain(1, peak13val);
      if((peak13raw * threshold) < peak13val) {
        peak13val = peak13val * attack;
      if((peak14raw * threshold) > peak14val) {
        peak14val = peak14val / attack;
        mixer6.gain(2, peak14val);
      if((peak14raw * threshold) < peak14val) {
        peak14val = peak14val * attack;
      if((peak15raw * threshold) > peak15val) {
        peak15val = peak15val / attack;
        mixer7.gain(0, peak15val);
      if((peak15raw * threshold) < peak15val) {
        peak15val = peak15val * attack;
      if((peak16raw * threshold) > peak16val) {
        peak16val = peak16val / attack;
        mixer7.gain(1, peak16val);
      if((peak16raw * threshold) < peak16val) {
        peak16val = peak16val * attack;
      if((peak17raw * threshold) > peak17val) {
        peak17val = peak17val / attack;
        mixer7.gain(2, peak17val);
      if((peak17raw * threshold) < peak17val) {
        peak17val = peak17val * attack;
      if((peak18raw * threshold) > peak18val) {
        peak18val = peak18val / attack;
        mixer7.gain(3, peak18val);
      if((peak18raw * threshold) < peak18val) {
        peak18val = peak18val * attack;
      if((peak19raw * threshold) > peak19val) {
        peak19val = peak19val / attack;
        mixer8.gain(0, peak19val);
        mixer8.gain(1, peak19val);
      if((peak19raw * threshold) < peak19val) {
        peak19val = peak19val * attack;
      if(serialtimer >= 100) {                                      // and report MCU usage 10x per second
        serialtimer = 0;
        Serial.print("Processor Usage: ");
        Serial.print(AudioProcessorUsage());
        Serial.print("\nProcessor Usage Max: ");
        Serial.print(AudioProcessorUsageMax());
        Serial.print("\nMemory Usage: ");
        Serial.print(AudioMemoryUsage());
        Serial.print("\nMemory Usage Max: ");
        Serial.print(AudioMemoryUsageMax());
        Serial.print("\n\n\n\n\n\n\n\n\n\n");
    Nice work!
    I'll have to give this a try sometime soon.
    Have any actual recordings of it in use?
    Germany
    9,583
    Thats looks amazing !
    But I don't want a facebook-account to DL the file..
    Dec 2016
    Philippines
    79
    Hi Synthetech and Frank B, use this 4shared link (13 MB zip file).
    Added files are a screenshot, actual recordings of Teensy output, the "Nodes" image, and the "ino" code. Test tracks are still there.
    I changed the attack value (line 295) to 0.995884 for this recording (reflected on the code inside the archive). Note that I added -6 dB MP3 player playback gain to Teensy input during recording.
    Frank B, if you know or prefer other file-sharing website, let me know.
    Quote Originally Posted by Revalogics View Post
    Thanks for trying to share, but I'm not downloading from that site.
    All the song and dance it wants me to go through to get the file.. just not worth it.
    I had bad feelings of possibly getting trojans/virus's from there.
    I share files using my Google Drive and there isnt all that circus going on like on 4shared.
    Give Google a try. I have not had any issues with my Google Drive account sharing files.
    Dec 2016
    Philippines
    79
    Quote Originally Posted by Synthetech
    Google Drive Link here
    that was quick!
    Thanks... I was able to download the folder with ease.
    But none of the mp3's would open up and play properly.. no sound at all, and some of my apps would freeze up on me.
    Dec 2016
    Philippines
    79
    All the recorded files have 128 kbps bitrate at 48000 Hz and test tracks are 320 kbps at 44100 Hz, standard MP3 files.
    My MP3 player is Foobar 2000 and it works fine (at least, for me)
    Try using MP3 utilities like Audacity to re-sample the tracks.
    15,496
    Page never fully drew - except download button that worked. The MP3's played for me from the zip. Win 10 _ GROOVE.
    So the Teensy and that Audio D Tool layout replicates the hardware shown on the project page?
    I ended up getting the mp3s to work after a system restart... I must have botched up ASIO/System Sound settings when fiddling around with a Screen Cap project.
    Anyways, thanks! Sounds cool!
    I did notice some distortion in the recordings.
    Maybe you have the gain set too high on the mixers?
    I noticed I did not have much success if all the channels were at Gain of "1".
    I would have to split them up to equal 1 when all added together.
    So say I use all 4 channels.. each channel would be set with gain of 0.25.
    Dec 2016
    Philippines
    79
    Quote Originally Posted by defragster
    Google Drive links also appears that way to me, I don't know why.
    The MFOS page? Somewhat. Their build uses 12 channels and everything is hardware (using differential and transconductance opamps, and a bunch of passive components).
    I removed the noise-to-instrument-mix feature but the sibilance feature is still there. The envelope followers are hard-coded.
    Ooh, I get your point, maybe the distortion is introduced in the mixer objects, or by the fast changing of mixer object gains. Try lowering threshold value (line 298) or increasing attack value a bit (line 295). My initial sketch was worse than that .
    I use VoiceMeeter Banana (not recommended for slow PCs), and it enables me to use ASIO and native audio at the same time. Downloads can be found on their Facebook page.
    actually I meant this part of your sketch
    that last part in green, the red numbers probably should be 0.5
    thus when you add them together you get "1" as your total output.
    otherwise you may get distortion in your output when you exceed a total of "1".
    I could be wrong.. its just what I understood from the tutorials.
    Dec 2016
    Philippines
    79
    Thank you Synthetech, this should work. I doubt about it at first hahaha.
    Apr 2013
    1,938
    Yes, you need to be careful tracking levels through the system to keep clear of clipping because of the way it'll wrap integer math and such fun things. You can have mixers with all inputs 1, but you then need to track downstream that the total levels never add to more than one.
    Working with a synth for a light saber type effect did some fiddling with selectively muting 'background' ambient channels based on a pulse source being activated, tracking the gains of the various first stage generators and muting lower priority ones if the 'gain' budget' reached one.
    Unsure if you could use a peak detect node in the system to do the same with your live audio input, where you don't AGC the input itself but cut the gain of your additional effects.
    Dec 2016
    Philippines
    79
    Hi guys, it's me again. =)
    I managed to find the old sketch regarding this (also posted here before), and made another sketch out of it (check out the "vocoder_waveforms" folder in the Google Drive link).
    Old test tracks were nowhere to be found, but instead, I also included new mp3 recordings (direct via USB to DAW) inside "vocoder_waveforms" folder.
    Code structure on the new sketch also changed as compared to before; I used arrays of audio library objects (inputs, filters, etc.) to shorten the code.
    Link: https://drive.google.com/drive/folde...dc?usp=sharing
    Dec 2019
    134
    very cool! thanks for sharing
    Apr 2020
    Tucson
    142
    sample rate control signals
    Based on your sketch, I've rebuilt a demo of a vocoder that incorporates a new effects module I hacked together: Rectifier. This acts as a full wave rectifier on the audio signal, outputting a signal that is always at or greater than zero. This allows use as am demodulator, amplitude chain control for this vocoder - lots of things. By following the rectifier with a biquad filter, we make an envelope follower.
Name:	Screenshot from 2020-06-07 21-32-16.jpg
    Attached Files Attached Files
