Hi everyone,
I'm new to Teensy and Arduino and so far I'm really impressed.
I'm an electronics engineer and used to writing assembly and C, but I've ot myself a teensy 3.6 to have a play with without all the faff of writing low level drivers.
Anyway, I've managed to get myself a Teensy 3.6 hooked up to 8 of the Adafruit Trellis PCBs via a level shifter and it's working great.
What I want to do now is use the other I2C busses (well at least one, if not two), I want to use one of them for the 3 axis accelerometer.
I've read up and know that I should be using the "i2c_t3" library in place of the "wire" library, but when I swap "#include <wire.h>" for "#include <i2c_t3.h>" I get the following errors ;
Digging a little deeper it seems the trellis libraries have the 'wire.h' library hardwired in.
Is there a way around this?
Many thanks in advance
Paula
Arduino: 1.8.1 (Mac OS X), TD: 1.35, Board: "Teensy 3.6, Serial, 180 MHz, Fast, US English"
In file included from /Users/Paula/Documents/Arduino/libraries/Adafruit_Trellis_Library-master/Adafruit_Trellis.h:35:0,
from /Users/Paula/Dropbox/Projects/Nexus/TrellisTest/TrellisTest.ino:20:
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/Wire.h:104:16: error: conflicting declaration 'TwoWire Wire'
extern TwoWire Wire;
In file included from /Users/Paula/Dropbox/Projects/Nexus/TrellisTest/TrellisTest.ino:19:0:
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/i2c_t3/i2c_t3.h:987:15: error: 'Wire' has a previous declaration as 'i2c_t3 Wire'
extern i2c_t3 Wire;
Error compiling for board Teensy 3.6.
Paula
