I want my teensy to listen only one CAN ID. I use the following code:
My problem is that I have to set at least two mailboxes for the same filter to work. Is it a bug or why is that?
The can interface is MCP2562, with Flexcan (collin80) library.
Thanks!
#include <FlexCAN.h>
Can0.begin();
CAN_filter_t test_filter;
test_filter.id = 0x1F; //0b00011111; ID 31
test_filter.flags.extended = 0;
test_filter.flags.remote = 0;
for (int c = 0; c < 14; c++) {
Can0.setMask(0x1FFFFFFF, c);
//Can0.setMask(0b00011111111111111111111111111111, c);
Can0.setFilter(test_filter, 0);
Can0.setFilter(test_filter, 1); // without this does not work
CAN_message_t inMsg;
while (Can0.available()) {
Can0.read(inMsg);
print_can_message(inMsg);
void print_can_message(CAN_message_t msg) {
Serial.print(msg.id);
Serial.print(": ");
for (int i = 0; i < 8; i++) {
Serial.print(msg.buf[i]);
Serial.print(" ");
Thanks!
