I can see that the basic MPU-6050 example is working, but I'm trying to package it up to work more efficiently with i2c_t3. I see that there are other libraries out there that already do a lot of stuff, but they are all based on Wire, and I'm trying to keep the versatility of i2c_t3.
edit: I should add that the example is working with sensible values, but my example doesn't output sensible values.
I don't know if I'm not understanding the i2c stuff right, or if I'm doing something not right with the bitwise operators. The original example was doing 2 byte reads and doing a bitwise operation to concatenate into an int16_t.
I tried doing a single byte grab to try and replicate (which didn't work), but I'm also trying to do all 14 byte tx from the sensor and then do the bit-wise operations to store them into int16_t. Thanks for any help in identifying where I might be making a mistake.
This is the original example.
Here's my attempt so far:
// MPU-6050 Short Example Sketch
// By Arduino User JohnChi
// August 17, 2014
// Public Domain
#include<Wire.h>
const int MPU_addr=0x68; // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print("AcX = "); Serial.print(AcX);
Serial.print(" | AcY = "); Serial.print(AcY);
Serial.print(" | AcZ = "); Serial.print(AcZ);
Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53); //equation for temperature in degrees C from datasheet
Serial.print(" | GyX = "); Serial.print(GyX);
Serial.print(" | GyY = "); Serial.print(GyY);
Serial.print(" | GyZ = "); Serial.println(GyZ);
delay(333);
#include <i2c_t3.h>
#define MPU6050 2
//int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
struct i2cConfig {
uint32_t clock; // I2C clock frequency
uint8_t port; // I2C bus number
i2c_pins pins; // I2C pins
i2c_pullup pullups; // I2C pullups
uint8_t address; // I2C address
struct mpu6050Config {
char signalName[8];
uint8_t sampleDivisor = 1;
uint8_t sensorType = MPU6050;
uint8_t ID = 0x68;
uint8_t numSensor=1;
i2cConfig i2c;
mpu6050Config mpu6050Cfg;
void setup(){
mpu6050Cfg.i2c.address=0x68;
mpu6050Cfg.numSensor=1;
i2c_t3(mpu6050Cfg.i2c.port).begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_EXT, I2C_RATE_100); //t3.2
mpu6050Init(&mpu6050Cfg);
/* Successfully migrated to mpu6050Init() I think
Wire.begin();
//sampleMPU6050Single(mpu6050Cfg.i2c.port, mpu6050Cfg.i2c.address);
sampleMPU6050(mpu6050Cfg.i2c.port, mpu6050Cfg.i2c.address);
void sampleMPU6050Single(uint8_t i2cPort, uint8_t i2cAddress) {
int nVal = 7;
int16_t vals[nVal];
int16_t tmp;
for (int i=0;i<nVal;i++) {
tmp = readByteWire(i2cPort, i2cAddress, 0x3B) << 8 | readByteWire(i2cPort, i2cAddress, 0x3B);
vals[nVal] = tmp;
Serial.print("single val");
Serial.print(i);
Serial.print(": ");
Serial.println(vals[i]);
void sampleMPU6050(uint8_t i2cPort, uint8_t i2cAddress) {
int nVal = 7;
uint8_t bytes[nVal*2];
int16_t vals[nVal];
readBytesWire(i2cPort, i2cAddress, 0X3B, (nVal*2), &bytes[0]);
for (int i = 0; i < nVal; i += 2) {
// vals[i/2] = bytes[i] + (bytes[i+1] << 8);
vals[i/2] = bytes[i] | (int16_t)bytes[i+1] << 8;
Serial.print("mpu6050 vals: ");
Serial.print(i);
Serial.print("=");
Serial.print(vals[i]);
Serial.print(" | ");
void mpu6050Init(struct mpu6050Config *cfg) {
writeByteWire(cfg->i2c.port, cfg->i2c.address, 0x6B, 0);
* write data to sensor
void writeByteWire(uint8_t port, uint8_t address, uint8_t subAddress, uint8_t data) {
i2c_t3(port).beginTransmission(address); // Initialize the Tx buffer
i2c_t3(port).write(subAddress); // Put slave register address in Tx buffer
i2c_t3(port).write(data); // Put data in Tx buffer
i2c_t3(port).endTransmission(); // Send the Tx buffer
* read a byte of data from sensor
uint8_t readByteWire(uint8_t port, uint8_t address, uint8_t subAddress) {
uint8_t data; // `data` will store the register data
i2c_t3(port).endTransmission(I2C_NOSTOP); // Send the Tx buffer, but send a restart to keep connection alive
// Wire.endTransmission(false); // Send the Tx buffer, but send a restart to keep connection alive
// Wire.requestFrom(address, 1); // Read one byte from slave register address
i2c_t3(port).requestFrom(address, (size_t) 1); // Read one byte from slave register address
data = i2c_t3(port).read(); // Fill Rx buffer with result
return data; // Return data read from slave register
* read a chunk of data from sensor
void readBytesWire(uint8_t i2cPort, uint8_t address, uint8_t subAddress, uint8_t count, uint8_t * dest) {
i2c_t3(i2cPort).beginTransmission(address); // Initialize the Tx buffer
i2c_t3(i2cPort).write(subAddress); // Put slave register address in Tx buffer
i2c_t3(i2cPort).endTransmission(I2C_NOSTOP); // Send the Tx buffer, but send a restart to keep connection alive
uint8_t i = 0;
// Wire.requestFrom(address, count); // Read bytes from slave register address
i2c_t3(i2cPort).requestFrom(address, (size_t) count); // Read bytes from slave register address
while (i2c_t3(i2cPort).available()) {
dest[i++] = i2c_t3(i2cPort).read(); } // Put read results in the Rx buffer
