I have something that looks similar to this, and I want to remove the pull-up resistor cause I'm using too many modules with built-in pull-up resistors:
The document I could find on this, seems to indicate it has 4.7k ohm pull-up resistors, but from another post on the forum, it seems it's typically 2.2k ohm.
If it's 2.2k ohm then it seems it's those "222" resistors. If I jump those with a piece of wire, I should be able to defeat the pull-up resistor.
Anything I should consider before lopping those off?
