PJRC Ethernet Library + wiz850io
dimitre
Hello, I'm working on a project and everything is running smoothly.
I've made an array of EthernetUDP and noticed the project always freeze when a certain number of EthernetUDP objects are created.
I'm using Teensy 3.2 and wiz850io, but I feel it can be reproduced in other systems.
here is the minimal code to reproduce. in my setup if you use up to 4 objects the sistem runs, if you use 5 it freeze
#include <Ethernet.h>
#include <EthernetUdp.h>
#define NUMBEROFPACKETS 5
byte mac[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x00 };
IPAddress ip(192, 168, 1, 201);
EthernetUDP Udps[NUMBEROFPACKETS];
  Ethernet.begin(mac, ip);
  for (int a = 0; a < NUMBEROFPACKETS; a++) {
    Udps[a].begin(4001 + a);
  Serial.println("alive");
    if (Udps[a].parsePacket()) { //int n =
      byte packetBuffer[100]; //buffer to hold incoming & outgoing packets
      Udps[a].read(packetBuffer, 100);
Yup, only 4 sockets are supported.
Improving the ability to more easily configure 8 sockets, or fewer than 4 with larger buffers, is on my (very long) todo list.
Long-term, the default is probably going to remain 4 sockets with 4k buffers. Larger buffers help when you have network latency.
The hardware limit is 8 sockets.
Thanks! in fact in my application I dont' mind losing packets, I'll use a tiny TTL setting because I'm pushing pixels to LEDs.
I'll soon try this version of Ethernet library just to see if it works for my application.
https://github.com/sstaub/Ethernet3
Nice thing is actually I'm reading the Udp buffer directly inside the FastLED LEDS buffer, so I'm not even using memcpy anymore.
Each UDP port writes to a specific part of the buffer (one port for each 1464 bytes, or 488 leds) so this is why I'm looking for more ports.
I can loop through all UDP ports before updating leds.
This way I can handle 3904 pixels at a time.
My actual tests are running very fast, handling great 180 fps using 3 UDP ports.
If it doesn't work I'll try to use the first byte as a packet index, making teensy knowing in which position of the LED buffer it should write the UDP packet.
Ideas are welcome. Videos soon.
