Good morning!
I have to make transmitter that will send two diffferent frames, depending on whether button is pushed or not. I've managed to do that with two arduino unos
with SeeedStudio's CAN bus shields. Library made for these shields is fairly easy to use, so it didn't take a lot of effort to make. Now I want to make same thing with teensys and that's where the problems start.
1. I don't really understand how to use Flexcan library, so I found someone on youTube that already made bus and tried to copy some code just to start communication between nodes but it doesn't work.
2. I need to send the frame in 83333 bps and I have no idea how to add new baud rate to the library.
Equipment
Windows 10
Teensy 3.2 x2
Arduino IDE with teensyduino
http://www.ebay.com/itm/SN65HVD230-C...085?rmvSB=true x2
https://www.seeedstudio.com/CAN-BUS-....2-p-2256.html
Photos (orange-3,3V; green-GRD; red-teensyTX-canRX; blue-teensyRX-canTX; | red-CAN HIGH; green-CAN LOW)
https://drive.google.com/open?id=0B0...1BWaFVhazllY1U
https://drive.google.com/open?id=0B0...Xo3TnpRamNud1E
First code - FlexCAN - sender
#include <FlexCAN.h>
#include <kinetis_flexcan.h>
const int baudRate = 50000;
const int ledPin = 13;
const int delayTime = 2000;
FlexCAN myCAN(baudRate);
CAN_message_t message_send;
pinMode(ledPin,OUTPUT);
digitalWrite(ledPin,HIGH);
digitalWrite(ledPin,LOW);
myCAN.begin();
//if(myCAN.available()) // if avaible enabled then it doesnt work at all
Serial.println("Sending every 2s");
message_send.buf[0] = 1;
message_send.buf[1] = 2;
message_send.buf[2] = 3;
message_send.buf[3] = 4;
message_send.buf[4] = 5;
message_send.buf[5] = 6;
message_send.buf[6] = 7;
message_send.buf[7] = 8;
message_send.id = 0x01;
message_send.len = 8;
Serial.print(message_send.id); //printin stuff that i hope to send
Serial.print(' ');
Serial.println(message_send.len);
for(int i = 0 ; i < message_send.len ; i++){
Serial.print(message_send.buf[i]);
Serial.print("\n");
myCAN.write(message_send);
delay(delayTime);
digitalWrite(ledPin, LOW);
Second code - FlexCAN - receiver
static CAN_message_t rxmsg;
//digitalWrite(ledPin,LOW);
myCAN.begin();
Serial.println("Reading...");
myCAN.read(rxmsg);
Serial.print(rxmsg.id); //displays message id and length
Serial.print(" ");
Serial.println(rxmsg.len);
for(int i = 0; i < rxmsg.len; i++){ //displays received frame
Serial.print( rxmsg.buf[i]);
Serial.print(" ");
Serial.print("\n");
I also attach Sender an Receiver code from arduino with shields version (It's messy but it works).
I've already tried messing with tx rx cables and switching CAN LOW AND CAN HIGH, lowered clock rate on teensy, nothing changes so it's almost certainly in my rather improvised code.
PLEASE HELP
