Results 1 to 5 of 5
Thread: If statement help
    Mar 2017
    2
    If statement help
    I have been trying to make this diy h-shifter project
    i used the code from the post but when I'm not activating any switches it types "0123456701234567" and on and on. Even when all switches are pressed, it still types it. I've tried changing
    if (digitalRead(gearR) == 0) // gear engaged (the '0' means the pin has been shorted to the ground, causing a drop in voltage on that pin)
    Keyboard.press('0'); // send a keypress (and hold) '0' to the computer via Keyboard HID
    if (digitalRead(gearR) == 1) //gear disengaged (the '1' means the pin is no longer shorted to the ground, which increases voltage on that pin)
    Keyboard.release('0'); //tells the PC to let go of the key (otherwise, it would continue to hold it forever, even after another gear is selected)
    to
    if (digitalRead(gearR) == 1) // gear engaged (the '0' means the pin has been shorted to the ground, causing a drop in voltage on that pin)
    if (digitalRead(gearR) == 0) //gear disengaged (the '1' means the pin is no longer shorted to the ground, which increases voltage on that pin)
    , I've tried changing the second "if"s to "else"s but that gives me an error message.
    I checked the wiring and it is all correctly wired with the microswitches. could it be a problem with the teensy 2.0's pins?
    //Pin assignments for each gear
    int gearR = 0; // Reverse gear set to pin 0
    int gear1 = 1;
    int gear2 = 2;
    int gear3 = 3;
    int gear4 = 4;
    int gear5 = 5;
    int gear6 = 6;
    int gear7 = 7;
    //Gear Inputs
    pinMode(gearR, INPUT); // Set the gear as an input
    digitalWrite(gearR, HIGH);
    pinMode(gear1, INPUT);
    digitalWrite(gear1, HIGH);
    pinMode(gear2, INPUT);
    digitalWrite(gear2, HIGH);
    pinMode(gear3, INPUT);
    digitalWrite(gear3, HIGH);
    pinMode(gear4, INPUT);
    digitalWrite(gear4, HIGH);
    pinMode(gear5, INPUT);
    digitalWrite(gear5, HIGH);
    pinMode(gear6, INPUT);
    digitalWrite(gear6, HIGH);
    pinMode(gear7, INPUT);
    digitalWrite(gear7, HIGH);
    // Below is where the functions for each keypress and release are assigned.
    // If you currently have any of the number keys 0-7 mapped to a function, you can change them out below.
    // Be sure to change the key for both the "Press" function, and the "Release" function for each gear.
    // Note, these are the number keys above the letter keys on a keyboard, NOT the number pad keys.
    //////////*** Reverse GEAR ***\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    //////////*** 1ST GEAR ***\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    if (digitalRead(gear1) == 0)
    Keyboard.press('1');
    if (digitalRead(gear1) == 1) //gear disengaged
    Keyboard.release('1');
    //////////*** 2ND GEAR ***\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    if (digitalRead(gear2) == 0)
    Keyboard.press('2');
    if (digitalRead(gear2) == 1) //gear disengaged
    Keyboard.release('2');
    //////////*** 3RD GEAR ***\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    if (digitalRead(gear3) == 0)
    Keyboard.press('3');
    if (digitalRead(gear3) == 1) //gear disengaged
    Keyboard.release('3');
    //////////*** 4TH GEAR ***\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    if (digitalRead(gear4) == 0)
    Keyboard.press('4');
    if (digitalRead(gear4) == 1) //gear disengaged
    Keyboard.release('4');
    //////////*** 5TH GEAR ***\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    if (digitalRead(gear5) == 0)
    Keyboard.press('5');
    if (digitalRead(gear5) == 1) //gear disengaged
    Keyboard.release('5');
    //////////*** 6TH GEAR ***\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    if (digitalRead(gear6) == 0)
    Keyboard.press('6');
    if (digitalRead(gear6) == 1) //gear disengaged
    Keyboard.release('6');
    //////////*** 7TH GEAR ***\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    if (digitalRead(gear7) == 0)
    Keyboard.press('7');
    if (digitalRead(gear7) == 1) //gear disengaged
    Keyboard.release('7');
    Apr 2013
    1,936
    This is code intended for a Uno isn't it?
    Try deleting those
    lines and changing each pinmode line
    to
    pinMode(gear1, INPUT_PULLUP);
    Edit: the code was using an old way of enabling pullups to make the switches work which works on a Uno due to some oddities in the hardware but the latter chips get things specifically set:
    https://www.arduino.cc/en/Reference/pinMode
    Mar 2017
    2
    if the code is intended for an uno, then i guess I am using the wrong board. (edit:spelling)
    22,977
    Use the Bounce library.
    Look in File > Examples > Teensy > USB_Keyboard > Buttons.
    Apr 2013
    1,936
    Re Uno code it should work, was just using a very old way to get pullups enabled. And the next problem you will hit when you do would be switch bounce, hence Paul's suggestion to go straight to the bounce library.
    Something else to do as well would be to look at examples->teensy->tutorial1->blink and see how your drive the onboard LED. While getting this working might be worth adding two digital writes to the reverse IF statements to turn on and off the LED to make it a bit clearer what your switches are up to.
Tags for this Thread
