Hi all,
A little of background first on my project. I want to use the teensy to read the value of some sensors and then send the values to the raspberry. I was wondering which way would be the easiest to implement. Is using the microusb(teensy) to USB(raspi) cable a good idea?
Otherwise, Uart? Spi? I can't use I2C since on the raspi side is used for something else.
Now, let's say I can achieve that using the microusb cable, in order to power the teensy I was thinking to connect 3.3V at the 3.3V input, and cut the line on the back of the teensy between VIN and VUSB. In this way I can still program the teensy, and use the microusb for the communication with the raspi safely. Or I can power the Teensy with the 5V coming from the raspi without any need of the 3.3V?
Thanks.
Claudio
Thanks.
Claudio
