Hi All,
I just brought up a new development machine, a Dell XPS 8900 desktop, and I'm experiencing a problem that appears to be specific to the Teensy products. I've been doing Arduino and AVR development for a while now. Historically, things have been working well. My development environment of choice is Ubuntu Linux and I am currently using Ubuntu 16.04. The problem appears to be with the way Teensyduino works with the USB port. My previous system is a Dell Optiplex 330. Everything works fine on that machine and I am continuing development on it while I try to figure out what is going on with the new machine.
After setting up the new machine with Ubuntu, Arduino, and Teensyduino, and plugging in a Teensy device, lsusb shows:
Bus 001 Device 016: ID 16c0:0483 Van Ooijen Technische Informatica Teensyduino Serial
and the tty device shows up as:
crw-rw-rw- 1 root dialout 166, 0 Mar 15 11:06 ttyACM0.
All looks good. When I try to download code to a Teensy device, Teensyduino seems to start the download but then stops before it is complete and just hangs there. It finally times out and I get this message:
Teensy did not respond to a USB-based request to automatically reboot.
Pressing the program mode button does not start things back up again.
If I do an lsusb at that time the USB network still shows this:
Bus 001 Device 015: ID 16c0:0478 Van Ooijen Technische Informatica Teensy Halfkay Bootloader
If I list the tty devices, the Teensy device has disappeared. If I unplug the Teensy device and plug it back in, the tty device come back and everything looks normal again.
I see this problem with all Teensy devices I have, Teensy 3.2, 3.5, and 3.6.
I hooked up an Arduino UNO to see if that would work and was able to download code to it just fine.
Seems there is a problem with the Teensyduino code and newer USB networks at least when it comes to Dell XPS 8900 systems. I still have my old system up and running so I can just continue my Teensy development on that but it would sure be nice to move over to the new system, it's much faster.
What can I do to resolve this problem?
Thanks in advance,
Dave
Thanks in advance,
Dave
