Results 1 to 11 of 11
Thread: Teensyduino 1.36 Beta #2
    Administrator Paul's Avatar
    Oct 2012
    306
    Here is a second beta test for Teensyduino 1.36.
    Changes since version 1.36-beta1:
    • Link Time Optimization (LTO) no longer default
    • Ethernet socketBeginMulticast (manitou)
    • Fix IntervalTimer on Teensy 3.5
    • Wire library supports Wire1, Wire2
    • Wire library timeouts for error conditions
    • Libraries updated: AccelStepper, Audio, FastLED, ShiftPWM, LedDisplay, TouchScreen
    • Minor improvements to AVR emulation
    • Hardware serial write() compatibility fix
    • Fix pin config on Serial6
    • Add extreme joystick, disabled by default, edit usb_desc.h
    • Fix String test as boolean
    • Faster installation, especially on Mac
    6,849
    sticky current "Beta/Release" posts while active would keep them from getting bumped down when an older announcement gets pinged.
    18,339
    Probably the biggest change, the thing most in need to beta testing, is the Wire library. I did quite a lot of testing over the weekend, but I can't try every program using I2C communication with Wire!
    Now you can use Wire1, Wire2, Wire3 to access the other ports on Teensy LC, 3.2, 3.5, 3.6, and of course the usual Wire accesses the main I2C port. The library now uses a thin abstraction layer, rather than just hard-coding everything for the main port. I also added timeouts for various error conditions, like the bus stuck busy or a slave device clock stretching for a ridiculously long time.
    To save memory, by default Wire1 on Teensy LC and Wire3 on Teensy 3.6 are not instantiated. To use these, put these lines near the top of your program:
    TwoWire Wire(KINETIS_I2C0, TwoWire::i2c0_hardware);
    void i2c0_isr(void) { Wire.isr(); }
    TwoWire Wire3(KINETIS_I2C3, TwoWire::i2c3_hardware);
    void i2c3_isr(void) { Wire3.isr(); }
    I'm considering just making Wire3 instantiated by default on Teensy 3.6, since it has so much RAM. Then again, with the pins only accessible on the bottom side and with 3 other ports easily available, widespread use of Wire3 seems pretty unlikely.
    If you get a chance to do any testing with Wire on any boards, please reply here, even if only "tried XYZ, worked fine". Thanks!
    3,653
    Looks good - At some point you might want to take a look at some of the other Pull requests like SPI (faster output with transfer of a buffer)
    3,653
    Is the first one correct? Looks more like Wire0...
    18,339
    Done. I've merged several other fixes and improvements today. Will probably make another beta by the weekend.
    I'd like to "freeze" features for 1.36 by this weekend and finalize 1.36 sometime next week, or at least before the end of March if things slip.
    Opps, yes, that's the wrong one. For Wire1 it should be:
    TwoWire Wire1(KINETIS_I2C1, TwoWire::i2c1_hardware);
    void i2c1_isr(void) { Wire1.isr(); }
    6,849
    FOR CONSIDERATION:: Paul put in my suggestion to split the delay(400) before setup() is called.
    <edit>: If you'd like to see Teensy Serial online some part of 350 ms faster (depending on hardware and Serial Monitor)please Beta test this as USB can be finicky and without decent testing it (or if odd cases show up) won't get released. Code below shows a simple set of time checks and prints for setup. Code change is in the github link above - but seems like it may be committed and coming out in 1.36b3 for test. Whatever your setup this shouldn't be slower and setup() entry time is the same - though as noted I've found TyCommander to be faster and picking up the Teensy with this change than IDE SerMon.
    Without that change T_3.0 and T-3.6 shows Serial online between 800ms and 950 ms with TyComm depending on USB port type. Times after Upload and Reset can vary.
    Made those changes to my 1.36b2 install. T_3.6 boots to setup in 400ms as expected.
    Using TyComm as SerMon Serial USB is seen online and printing at 414-433 ms. IDE SerMon when I was testing improved - but not as fast. Same for both of these tested on my Amazon Basics USB2 hub, my DELL monitor hub (FrankB said his similar has some slowness?)
    Front panel USB3 shows Serial at ~550ms. USB3 Hub USB3 and its USB2 ports shows ~450ms
    Also tested T_3.0 on same ports with same sketch and got same results
    Sketch for test reference: TimedStartBlinkMin.ino
    Shows setup entry time then millis when while(!Serial) exits - then blinks LED and shows millis each 10 seconds:
    BOOT_on_Time=400
    Serial_on_Time=411
    millis() =10412
    where that comes from this in the attached code:
    setup(){
    BOOT_on_Time=millis(); // print 400
    while(!Serial);
    Serial_on_Time=millis(); // print 411
    3,653
    Hi Paul,
    I am trying out the new Wire library and converting my Well monitor program back from i2c_t3 to wire... (Modified version of Adafruit_SHT31 library)
    Running into a few issues in conversion back, like I was using I2C_STOP, which I locally defined as 1... Also was using timeout... in requestFrom.
    Looking over the new requestFrom:
    Wondering: What the proper behavior should be if you ask for 6 bytes and times out after 3 bytes.
    Current code in the SHT31 library was doing:
    boolean Adafruit_SHT31::completeReadTempHum(void) {
      uint8_t readbuffer[6];
      Wire.requestFrom(_i2caddr, (uint8_t)6, I2C_STOP, I2C_T3_TIMEOUT);
      if (Wire.available() != 6)
        return false;
    So conversion is to remove the TIMEOUT parameter as there is no template for 4 parameters...
    Looking over the code it looks like if I get a timeout condition, the code now will return how bytes were actually received. However rxBufferLength is not updated so will will be zero, and so Wire.available will return 0. Also the read method checks for rxBufferIndex and rxBufferLength so it will not allow you to retrieve any of the values that was read before timeout. Not sure if that is the intended behavior? In my case it does not matter as I want all or nothing...
    Edit: I finished compiling for T3.6 and tested on the two boards one with the SHT31 and one without and it properly timed out on the one without (used to hang)... And it reads OK on the one with the sensor. Currently tested on Wire object
    Feb 2014
    Colmar, France
    1,890
    Install on my MacBook Pro took much less time than before. Like it!!!
    What I would still like now, is an auto-update feature. That means that at startup, it would look for a new version (configurable beta or only full releases) and suggest to install it. Eclipse has that, and it's very comfortable.
    18,339
    Oh, that's a good point....
    18,339
    Fixed.
    https://github.com/PaulStoffregen/Wi...ffe979ff9c0a5b
