Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 51 to 75 of 142
Thread: Teeny Guitar Audio Board
  1. #51
    Senior Member Blackaddr's Avatar
    Mar 2017
    Canada
    184
    UPDATE!
    Sorry for the lack of updates guys. Last month has been crazy as I nearly changed jobs (and countries!). In the end, I'm staying where I am and it's back to work on the Teensy Guitar board. I've spent the last week assembling and testing a proto. Here's a summary
    - power supply circuits all appear to be functional
    - schematic was missing DC blocking capacitor on preamp feedback paths (oops!)
    - analog AUDIO IN is passing to DRY OUT, and to AUDIO OUT via Teensy Audio Library (TAL)
    - USB audio from PC passes to AUDIO OUT via TAL
    - USB audio from AUDIO IN to PC via TAL
    What's next?
    - populate and test the MIDI circuits
    - populate and test the SPI memories
    - populate and test the external power supply circuit
    - evaluate noise performance
  2. #52
    I am working on some project, with quiet the same principles.
    my pickups are piezo sensors (I don't know their exact impedance but It should be is very high)
    I am working with the teensy audio board (the SGTL5000),and Teensy 3.2, My knowledge in the analog field is really weak.
    I looked in your schemes and specifically in the buffer section,
    I wonder why you chose these values for RA1,CA1,RA3,RA4?
    And what is the idea behind the RA7,RA9,CA3?
    For testing the circuits I connected 2 PIEZO pickups.
    One PIEZO is connected straight to the LEFT LINE-IN.
    the second PIEZO connected to a buffer same as you designed, but no RA1, and RA3=RA4 = 1M and CA1 = 3.9nanoF (I would like to filter the low frequencies [50-60Hz from the 220V..])
    I see that I've got constant noises(bzzzss...) in both of the channels. the one with the Buffer has much low-frequencies noise (hmm..)
    How can I reduce the noise to get more studio-like signal?
    BTW my OP-AMP is feeded by the 3.3V of the Teensy...
    Thanks in advance!
  3. #53
    Mar 2017
    Canada
    184
    CA1 is used to AC-couple the audio signal to the op-amp. Audio signals vary around some offset other than 0V in order to avoid using negative voltages in the circuits. RA3 and RA4 form a voltage divider to bias the AC signal to a suitable offset for use with the 9V power-op amp. They also set the input impedance, which needs to be high for things like passive guitar pickups. RA1 is used to ensure voltages cannot build up on CA1 when nothing is plugged in, it acts like a drain. If voltages build up on the cap you can get a very loud pop when switching things like TRUE BYPASS pedals.
    The components at the output of the preamp (RA7, RA9, CA3 etc) form a high pass filter (once again, to AC couple the audio signal from the op-amp) as well as a low-pass anti-aliasing filter for the ADC.
  4. #54
    Quote Originally Posted by Blackaddr View Post
    Thanks!
    I am working with your design(except that RA3=RA4=1M), but I've got much noise from that channel, Do you have an idea why?
    This is the Piezo connected straight to the LINE-IN
    This is the Piezo connected to the buffer you designed (maybe because I built it on a matrix?)
  5. #55
    Mar 2017
    Canada
    184
    @alonper - at this point you should start a new thread to debug your project rather than hijack this one.
    If you use my preamp, note also that my updated schematic in post #46 was missing a capacitor between RA16=1K and GND. The cutoff frequency for the feedback path is 1/2*pi*R*C where R = RA16 and for audio applications should be less than 20 Hz.
  6. #56
    Alright!
    Thanks a lot! sorry for hijacking..
  7. #57
    May 2017
    2
    Hi Blackaddr !
    Very interesting project. We are considering starting a project of effect/synth pedal, with requirements quite close to what you mention in your initial post.
    Would you mind if we start from your schematic ? Do you have a github project linked to it ?
  8. #58
    Mar 2017
    Canada
    184
    Quote Originally Posted by Shogun Web View Post
    Hi Blackaddr !
    Feel free to use the schematic, though be warned I'm currently in the process of testing a prototype and as usual there changes required! I will post an updated schematic once I have revision 2 ready. In the mean time I'm happy to discuss design details of my board in the thread.
  9. #59
    May 2017
    2
    Ok thanks ! We will surely have questions when looking at the details ;-)
  10. #60
    Please, Can you explain how RA7, RA9, CA3,CA5 form a HPF and LPF? (I tried to play with the values in the 1/2piRC and I cant understand how it fits with 20-20Khz)
    and why is it necessary to form a HPF if you already got one with the RA16 and the series cap[8uF for (1/2pi*1K*8u)~20hz?
    and RA17/RA16 make the gain?
    Thanks a lot and sorry for my newbie's questions...
  11. #61
    Mar 2017
    Canada
    184
    Quote Originally Posted by alonper View Post
    The structure for the circuit actually comes from the datasheet of the WM8731 and is designed to complement the filtering inside the codec. I've modified the values because the the 12.5K input resistance of the WM8731 could form a voltage divider with RA7 and reduce the input amplitude on the assuming the incoming signal was line-level. I have not simulated the circuit and it is quite possible it is not behaving as I expect since I haven't characterized it yet either.
    The intent was RA7/CA3 form a LPF with cutoff frequency of approx 159 Khz (WM8731 datahseet originally had 130 Khz). This helps with some pre-ADC anti-aliasing. Further anti-aliasing is then applied inside the CODEC. If aliasing is still prsent, the cutoff for this filter could be reduced further.
    RA9/CA5 form a high pass filter to AC couple the signal from the 4.5V bias out of the OP-AMP to the VMID bias required by the CODEC. The cutoff of the HPF is approximately 1.6HZ. This removes the DC and ensures the low bass signals around 20 Hz aren't attenuated.
  12. #62
    @Blackaddr
    Thank you so much for the detailed explanation.
    Do you think that I must re-design the circuit to fit the Teensy Audio adapter(SGTL5000)?
    (I am asking because my knowledge in analog is very basic..)
  13. #63
    Mar 2017
    Canada
    184
    @Blackaddr
    I'm going to say no, it should work, it's just a passive filter and coupling circuit.
  14. #64
    Mar 2017
    Canada
    184
    UPDATE!
    What's next?
    MIDI Circuit - confirmed working!
    SPI Memories - confirmed working!
    External power - confirmed working!
    Noise Performance - in progress!
    After disabling the HP filter in the codec (similar problem to SGTL5000 board) the self-noise performance is very good ( > than 110db at low frequencies and > 125db at the higher frequencies).
    I'm going make a convenience library for the board utilizizing components of the Audio library and put some demo code on github.
    I will also start working on Rev 2 of the PCB to address some minor changes I'd like to make after characterizing.
  15. #65
    Mar 2017
    Canada
    184
    *** UPDATE ***
    Schematic REV 2 is complete.
    Changes include:
    - redesigned analog supply - Both 9V analog for guitar preamp and 3.3V analog for ADC are now both generated off of dedicated LDOs. Previously 3.3V analog was created from 3.3V digital with an inductor filter circuit.
    - External supply circuit redesigned to optionally tie in with VIN pin on Teensy.
    - added two GPIO headers (containing a total of 8 GPIO), one of which contains SPI0. This will permit adding stuff to your pedal like a SPI display**, stomp switch or rotary encoder circuits.
    - added missing feedback filter capacitors to preaamps to ensure gain is only applied in the audio domain (DC and high frequencies beyond 200 khz are not amplified)
    - added power LED and one user LED.
    ** Using the EXT/SPI pins for SPI operation means loosing the ability to use one of the two SPI memories.
    I've updated the OP with the new schematic, but here's a link as well:
    Teensy Guitar Rev2
    Attached Files Attached Files
  16. #66
    Mar 2017
    Canada
    184
    Rev2 PCBs have shipped from the factory. Should be building another round of protos in a couple weeks once they arrive.
  17. #67
    Jul 2017
    4
    Sorry, it seems i can't find how to download your "Teensy Guitar Rev2" file? Thanks for sharing though!
  18. #68
    Mar 2017
    Canada
    184
    Quote Originally Posted by najanajan View Post
    It's linked in the original post.
    I've got rev2 boards back, I can have a few assembled in case anyone is interested in one.
  19. #69
    Apr 2017
    17
    Hi Blackaddr
    Actually I would be very interested to buy one of your board (assembled would be even better).
    Let me know if and how we could do it...
    Ps: sorry if message was double posted due to browser problems.
  20. #70
    Mar 2017
    Canada
    184
    Quote Originally Posted by jcugnoni View Post
    Hi Blackaddr
    I should have it up on Tindie in a week or so to ensure safe transactions. What configuration do you need? I plan to have a lower-cost base solution, then you can add more components as optional add-ons.
    Base configuration would be:
    - single channel in, single channel out
    - no on-board connectors (you provide your own, ideal for custom enclosures)
    - no SPI memory or MIDI circuits
    Optional Add-ons:
    - two channel input, two channel output
    - MIDI circuits
    - 2 MBit SPI additional RAM
    - connectors (3x 1/4" stereo, 2x MIDI 5-pin DIN, 2x 40pin female header for Teensy)
  21. #71
    Apr 2017
    17
    Cool.
    The base option is perfect for me.
    I am not so much at ease with soldering SMT and multipin chips but adding bigger components if needed later will be just fine.
    Let me know when it is up on Tindie.
  22. #72
    Jul 2013
    Colorado
    87
    I am interested in an assembled board with add ons. Looks very capable. I'll keep an eye out for when you are ready. Cheers Kb
  23. #73
    18,967
    @Blackaddr - when you've got it up on Tindie and you're ready for a little promotion, please post on the blog projects forum, so Robin can show it on the PJRC home page.
  24. #74
    Mar 2017
    Canada
    184
    Hey guys, sorry for the delay in getting the boards up on Tindie. I've had to work insane extra hours at my day job the past week and didn't manage to get the listing setup before leaving on vacation. I'll be back in a week and will be a top priority when I'm home.
    Paul, I'll be sure to post on the blog projects forum! The Teensy 3.5 and 3.6 are really the perfect match for DIY guitarists looking to start experimenting with their own audio and MIDI projects. Can't say thanks enough for bringing such capable hardware to the Arduino community.
  25. #75
    TEPJunaid
    Guest
    I think TL072 Pinout details can make this problem understandable.
