radio.printDetails()
That is a great library, I use it to connect a T3.2 with a Pi. To make sure you have the wiring correct, can you show the output of thecommand?Code:radio.printDetails()
#include <RF24.h>
#include "printf.h"
RF24 radio(7,8);
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
void setup(void)
printf_begin();
Serial.println("Test connection to modules");
// Setup and configure rf radio
radio.begin();
// Set the TX and RX addreses in the module
radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1,pipes[1]);
// radio.setDataRate( RF24_2MBPS ) ;
// radio.setPALevel( RF24_PA_MAX ) ;
radio.enableDynamicPayloads() ;
radio.setAutoAck( true ) ;
radio.powerUp() ;
radio.startListening();
// Print out the configuration of the rf unit for debugging
radio.printDetails();
void loop(void)
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xf0f0f0f0e1 0xf0f0f0f0d2
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0xf0f0f0f0e1
RX_PW_P0-6 = 0x20 0x20 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x03
CONFIG = 0x0f
DYNPD/FEATURE = 0x3f 0x04
Data Rate = 1MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_LOW
while (!Serial) ; // wait for arduino serial monitor
Add this near the beginning:
Code:while (!Serial) ; // wait for arduino serial monitor
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0f
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_MAX
it is right?
Thanks now i can see this:
it is right?
#include "RF24.h"
bool radioNumber = 1;
RF24 radio(9,10);
byte addresses[][6] = {"1Node","2Node"};
bool role = 1; // 0 = pong back , 1 = ping out
delay(2000); // WNG - println's below started working after I put in this delay
Serial.println("RF24/examples/GettingStarted");
Serial.println("*** PRESS 'T' to begin transmitting to the other node");
radio.begin();
radio.setPALevel(RF24_PA_HIGH);
if(radioNumber){
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1,addresses[0]);
}else{
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1,addresses[1]);
// Start the radio listening for data
/****************** Ping Out Role ***************************/
if (role == 1) {
radio.stopListening();
Serial.println("Now sending");
unsigned long start_time = micros(); // Take the time, and send it. This will block until complete
if (!radio.write( &start_time, sizeof(unsigned long) )){
Serial.println("failed");
radio.startListening(); // Now, continue listening
unsigned long started_waiting_at = micros();
boolean timeout = false;
while ( ! radio.available() ){ // While nothing is received
if (micros() - started_waiting_at > 200000 ){
timeout = true;
if ( timeout ){ // Describe the results
Serial.println("Failed, response timed out.");
}else{
unsigned long got_time; // Grab the response, compare, and send to debugging spew
radio.read( &got_time, sizeof(unsigned long) );
unsigned long end_time = micros();
// Spew it
Serial.print("Sent ");
Serial.print(start_time);
Serial.print(", Got response ");
Serial.print(got_time);
Serial.print(", Round-trip delay ");
Serial.print(end_time-start_time);
Serial.println(" microseconds");
// Try again 1s later
/****************** Pong Back Role ***************************/
if ( role == 0 )
if( radio.available()){
// Variable for the received timestamp
while (radio.available()) { // While there is data ready
radio.read( &got_time, sizeof(unsigned long) ); // Get the payload
radio.stopListening(); // First, stop listening so we can talk
radio.write( &got_time, sizeof(unsigned long) ); // Send the final one back.
radio.startListening(); // Now, resume listening so we catch the next packets.
Serial.print("Sent response ");
Serial.println(got_time);
} // Loop
Now sending
failed
Now sending
failed
Now sending
failed
Now sending
failed
Sent 735797622, Got response 0, Round-trip delay 19005 microseconds
Now sending
Sent 736817038, Got response 0, Round-trip delay 19267 microseconds
Now sending
failed
Sent 737836715, Got response 0, Round-trip delay 19149 microseconds
Now sending
failed
Sent 738856277, Got response 0, Round-trip delay 19196 microseconds
Now sending
Sent 739875884, Got response 0, Round-trip delay 19291 microseconds
Sent response 4294967295
Sent response 0
Sent response 0
are you also changing radioNumber for UNO and teensy? one needs to be radioNumber 0 the other 1. as described in GettingStarted example
Now sending
Sent 132394015, Got response 132394015, Round-trip delay 1641 microseconds
Now sending
Sent 133396067, Got response 133396067, Round-trip delay 1641 microseconds
Now sending
Sent 134398119, Got response 134398119, Round-trip delay 1642 microseconds
Now sending
Sent 135400175, Got response 135400175, Round-trip delay 1640 microseconds
Now sending
Sent 136402230, Got response 136402230, Round-trip delay 1640 microseconds
Now sending
Sent 137404283, Got response 137404283, Round-trip delay 1665 microseconds
Now sending
Sent 138406363, Got response 138406363, Round-trip delay 1640 microseconds
Now sending
Sent 139408417, Got response 139408417, Round-trip delay 1641 microseconds
simple hack: instead of sending micros send your analog value. change unsigned long start_time = micros();
to unsigned long start_time =analogRead(A0);
