I've added HEX-Files to this thread (a few posts above this) - just connect the display and a USB-A female connector and you can run a few tests. I've fixed some bugs since then, but it is far away from beeing perfect, and it is not as good as VICE (VICE has many years of development now..)
Please tell me every bug you find.
At the moment I do some heavy tests with the CIAs. It'll take some time..
I guess, it's (geek-)fun to connect the emulated C64-userport serialport to a teensy-hardwareserial on the same chip and transfer data..
At the moment, I'm considering buying an original floppy disk drive... I want the emulation to be cycle-exact enough to speak with an original drive. (I'm not sure that if this is really possible.I hope it is.)
Does anyone have (proven to work) original Disks ? And can you lend me some ? I send them back in some month.. (or copy them if i can buy some empty disks somewhere..)
The speed is around ~4000 bit/s - which are the best bi-directional level-shifters to use ?
EDIT: Sorry, ~ 150.000 BIT/s
Connecting a tape-drive would be fun, too.
Future-Plan is to support a larger display.
