That sounds good - glad you didn't order the new PCB's yet! That would make using the SD2IEC add on much easier. Especially given the trouble of Floppy drives - being slow and costing so much and then not working very long.
One like this: NEU-SD2IEC-mini-fur-Commodore-64-128-VC20-4-C64DTV-1541 - even in GERMAN which I cannot read except metric size and 8GB - much bigger than a BOX of floppies!
Or this 2GB one? : Internal-fit-SD2IEC-Commodore-1541-Disk-Drive-Emulator-SD-Card-Reader-C64-Vic20 - attach External LED's and Eject button?
@firehopper A Teensy could do that with the right code written - the boards linked in posts just above do it with an AVR chip it seems - so just for that purpose it would be more than needed. In this case Frank's Teensy 64 emulating the c64 interfaces to one of those. If you follow the ebay links there are a couple versions - one seems to plug right onto the adapter.
@firehopper: A sourcecode is here: https://www.sd2iec.de/ You need to port it to Teensy.
I want to do that sometime, but that will take a while..
The good news is, since it runs on an AVR, a Teensy LC or 3.2 might be OK.
nice. as for porting, I have no skill in that reguard. it might be nice to be able to get it running on a 3.6 since it has a built in sd card slot.
I would like to put my hand up for a PCB if/when they become available.
I just noticed Paul added a new sub-forum specially for adding blog entries. This might be a useful item to go there.I don't want to mis-use this forum, and i'm searching for a better solution for this project. Maybe an own forum or blog or something like that and a central page which lists "HOWTOs" and a list of compatible/incompatible software
