New TeensyDMX library for Teensy 3
The reason that Teensy LC was returning zero for R8 was because it has a 2-stop-bit mode and it’s unnecessary to check that bit. Same goes for Teensy 3.5 and 3.6. This has been fixed in v3.2.2. The v4.0.0-alpha.1 has the fix for Teensy LC but not for Teensy 3.5 or 3.6.
I noticed if I try to send dmxTX.set() to a channel that is physically not connected, say on accident sent to channel out of range, that the library will stop responding. I can no longer send commands, until I reboot the PCB. Is this a known bug or is there a work around?
I’m happy to have a look. Can you provide a sketch that will reproduce this issue? Also, which Teensy and which version of TeensyDMX are you using?
