Results 1 to 14 of 14
Thread: A set of scope-tested 100-500 ns delay macros
    After some frustration with timing jitter from a short loop like that in delayMicroseconds, I put a set of hundred-nanosecond delay macros together today for bit-banging a second SPI port on my Teensy 3.2 and thought I'd share. Dedicated to the public domain.
    The sketch below is what I used to empirically determine the combinations of NOP3, NOP4, and NOP6 to use for each macro in each case. I tried to get them all to conform as closely as possible to a 100-500 ns negative pulse width, from a high setting to a low setting and then back high again, erring on the side of a pulse too long rather than too short. I kept my eye on the positive pulse width, too, though that was intermittently longer (perhaps up to 20%) due to the beginning of the sketch loop.
    You can stack these up to get longer delays, although I wouldn't be surprised if there was some non-linearity involved. And if your desired delays get long enough, you're just getting into the territory of delayMicroseconds.
    Of course, the delay of digitalWriteFast is inherently included in the delay of each macro. That's probably what you'd want this delay to be used with anyhow.
    I'm sure all the macro expansion bloats the compiled code somewhat, especially with longer delays, but I doubt if it adds up to much. Even with an F_CPU of 96MHz and a PAUSE of P5, I'm only seeing this sketch occupy 5% of program storage space.
    // Empirically determined by Ed Suominen with an oscilloscope and a good deal of
    // pressing Ctrl+U in the Arduino window. No guarantees expressed or implied. Dedicated
    // to the public domain.
    #define pinNum 13
      pinMode(pinNum, OUTPUT);
    #define NOP3 "nop\n\t""nop\n\t""nop\n\t"
    #define NOP4 "nop\n\t""nop\n\t""nop\n\t""nop\n\t"
    #define NOP6 "nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t"
    // P1-5 are 100-500 ns pauses, tested with an oscilloscope (2 second
    // display persistence) and a Teensy 3.2 compiling with
    // Teensyduino/Arduino 1.8.1, "faster" setting
    #if F_CPU == 96000000
    #define P1 __asm__(NOP4 NOP4)
    #define P2 __asm__(NOP6 NOP6 NOP6)
    #define P3 __asm__(NOP6 NOP6 NOP6 NOP6 NOP3)
    #define P4 __asm__(NOP6 NOP6 NOP6 NOP6 NOP6 NOP4 NOP4)
    #define P5 __asm__(NOP6 NOP6 NOP6 NOP6 NOP6 NOP6 NOP6 NOP4 NOP3)
    #elif F_CPU == 72000000
    #define P1 __asm__(NOP6)
    #define P2 __asm__(NOP6 NOP6)
    #define P3 __asm__(NOP6 NOP6 NOP6 NOP3)
    #define P4 __asm__(NOP6 NOP6 NOP6 NOP6 NOP4)
    #define P5 __asm__(NOP6 NOP6 NOP6 NOP6 NOP4 NOP4 NOP3)
    #elif F_CPU == 48000000
    #define P1 __asm__(NOP4)
    #define P2 __asm__(NOP6 NOP3)
    #define P3 __asm__(NOP6 NOP4 NOP3)
    #define P4 __asm__(NOP6 NOP6 NOP6)
    #define P5 __asm__(NOP6 NOP6 NOP4 NOP4 NOP3)
    #define PAUSE P5
      noInterrupts();
      digitalWriteFast(pinNum, HIGH); // 1
      PAUSE;
      digitalWriteFast(pinNum, LOW);
      PAUSE;
      digitalWriteFast(pinNum, HIGH); // 2
      PAUSE;
      PAUSE;
      digitalWriteFast(pinNum, HIGH); // 3
      PAUSE;
      PAUSE;
      interrupts();
    20,175
    I've added a link to this thread, on this page.
    https://www.pjrc.com/teensy/td_timing_delay.html
    Hopefully it will help others to find these macros.
    Maybe in time others will be done for Teensy LC, 3.5, and 3.6 at their many clock speeds?
    Germany NRW
    5,673
    One should mention that interrupts should be disabled if a maximum delay time is desired.
    Not sure what you intended to say there. Interrupts will increase the delay time, so disabling them will result in minimum delay, not maximum.
    Germany NRW
    5,673
    I think I intended to write "exact".. ;-) Anyway, this post is a couple of month old..
    Ah, exact makes sense. As to couple of months old -- yeah, but posts on here continue to be useful for years!
    Sep 2017
    3
    Hi, I'm using Teensy 3.6 with clock rate of 180 Mhz, what should be my setup for P1 to P5?
    Dec 2018
    5
    Hi, what would be the __asm__ or NOP instructions for an Arduino UNO (F_CPU == 16000000)?
    8,837
    Quote Originally Posted by brice3010 View Post
    Look for nop in this file :: ...\hardware\teensy\avr\cores\teensy\core_pins.h
    like >> asm volatile("nop\n");
    Dec 2018
    5
    Hi defragster, I have no such file because I have no teensy board installed. But I will try to find the answer by iteration: I have a scope for doing the measurements.
    New question: How does the void loop() function work? By that I mean how do these commands digitalWriteFast(pinNum, LOW); and digitalWriteFast(pinNum, HIGH); actually work to get the different #define's of P1 through P4 to be shown on the output pin?
    Dec 2018
    Ohio
    1
    Hello, newbie here. Find this forum a goldmine for Teensy code ideas. Just a quick note on the nano-delays. Attached are pictures of pin 13 w/o and w/ slew rate limiting ( PORTC_PCR5 &= ~(0x04); ) using a spring-tip probe (very little loop) and a Tek 100 MHz scope. Works well. First positive pulse is a bit wider.
ID:	15344Click image for larger version.
    Mar 2019
    Bordeaux / France
    69
    How can these macros be adapted to a Teensy 3.6 running at 180MHZ ? I need accurate nanoseconds delays (10ns would be fine) for clock phases synchronization with an external CPU...
    Any hint ?
    20,175
    Quote Originally Posted by Tactif CIE View Post
    Any hint ?
    You would need a good oscilloscope. Then just run the code, measure the pulse width, and adjust (add more NOPs) until it's correct.
    Mar 2019
    Bordeaux / France
    69
    Very unfortunately, for the moment, I don't own an oscilloscope (being said I'll follow your advice to keep enough money back and buy a good one like the Rigol 1054Z)
