oddson
I've learned that the pitch wheel on many MIDI controllers use a pot with a center tap (fourth pin).
To utilize the pin I'm guessing you would connect the center tap to ground and the alternately source and sink the two ends to read pitch-up and -down positions separately.
This would give you an extra bit of resolution and would avoid having to calibrate a center voltage but uses at least one extra digital pin.
Does this sound right or do commercial controllers have a different (better?) means of using the center tap?
