Page 3 of 3 FirstFirst 1 2 3
Results 51 to 54 of 54
Thread: MTP Responder Contribution
  1. #51
    Junior Member obiwan45's Avatar
    Dec 2017
    13
    THANK YOU.. Maybe its not working on Teensy 3.5 I guess
  2. #52
    Feb 2014
    Colmar, France
    1,901
    That's normal. Only the Teensy 3.6 has the second USB port which can be configured as a USB host. That's clearly visible in the comparison table here : https://www.pjrc.com/teensy/techspecs.html.
  3. #53
    Sep 2015
    Taiwan, Asai. (Traditional Chinese)
    136
    just in case,
    it may need a micro SD card in the built-in slot to show the device?
  4. #54
    Apr 2018
    1
    Hi, just inquiring if it is possible to use the second USB port on the Teensy 3.6 with MTP? If so, can you advise how to make it work?
    Thanks in advance.
