Page 4 of 8 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 76 to 100 of 185
Thread: MTP Responder Contribution
  1. #76
    Mar 2016
    Portland, OR
    538
    Trying out MTP Responder. Shows up fine on Windows 10 using a Teensy 3.6 with the built-in SD running MTP Blinky with the patch mentioned in the PR applied. I can create folders, but not rename them (i.e. I can make some "New Folder"). Any clues to fix that so the folders / files can be renamed and manipulated in Windows Explorer? Thanks!
  2. #77
    2,515
    Quote Originally Posted by brtaylor View Post
    If you look up the code, you will see that rename (aka move) is not implemented.
  3. #78
    Mar 2016
    Portland, OR
    538
    Thanks for that bit of information!
  4. #79
    Oct 2015
    Vermont, USA
    207
    Hey, this is super cool! It seems to work well for me on my Teensy 3.6. Thanks for making it happen and for "MTP (Experimental)" getting pulled into the mainline Teensyduino that we all download by default.
    The downside, of course, is that we lose Serial when we are in MTP mode. And by "lose Serial", I mean that I can't seem to invoke usb_serial_class methods (like dtr()).
    I've seen in other threads that altering the USB modes is not that hard (certainly not as hard as getting MTP to work in the first place!). Is there any chance that someone here with some skills could do the edit to the USB modes to add serial to the MTP mode and do the pull request to Paul?
    (note: I see no reason to have MTP mode *without* Serial, so I would simply add serial to the existing MTP mode. This means that we wouldn't be adding yet another entry in the USB menu. But, others might have other opinions.)
    Thanks for the great work! I'd be happy to help as a tester!
    Chip
  5. #80
    2,515
    Chip,
    The original version of he MTP has serial and not seremu
    https://github.com/yoonghm/MTP/blob/master/usb_desc.h
    Not clear why Paul has chosen to use seremu.
    Also not clear (forgot) if and what we have changed in the original code, apart from using Paul's stock usb_desc.h
  6. #81
    Sep 2015
    Taiwan, Asai. (Traditional Chinese)
    159
    Hello, following also,
    had anyone successfully tested MTP on teensy 4.0?
  7. #82
    2,515
    Got MTP Responder working on T4
    code may be found on GitHub/WMXZ/MTP_t4
    directory "copy-of-core" contains modification of core library
    until they are merged and distributed with TD these file need to be copied to cores/teensy4
    PR requested to update core
  8. #83
    Dec 2013
    262
    WOW !!! Thank you WMXZ !!, now we need Teensyduino 1.50 beta with the "MTP Disk (Experimental)" in the Tools.
  9. #84
    2,515
    Quote Originally Posted by Chris O. View Post
    Until then, you can uncomment the relative lines in boards.txt
  10. #85
    Many thanks to wolfmanjm for getting this to work on Linux. I had all but given up!
    Also, thank you to WMXZ for trying it with Teensy 4. I can't get it to work yet, but hopefully will soon.
    Compiling the example mtp-test started with errors in files mtp_storage.cpp (line 35) and mtp_storage.h (line 40) stating "SdFat-Beta.h not found". Needed to edit those lines to "SdFat.h"
    Now the errors are:
    In file included from /tmp/arduino_build_954478/sketch/main.cpp:4:0:
    /home/dean/Desktop/arduino-1.8.9/hardware/teensy/avr/libraries/MTP_t4-master/src/MTP.h:64:70: warning: 'used' attribute ignored [-Wattributes]
       uint8_t data_buffer[MTP_RX_SIZE] __attribute__ ((used, aligned(32)));
    /home/dean/Desktop/arduino-1.8.9/hardware/teensy/avr/libraries/MTP_t4-master/src/MTP_Storage.cpp: In member function 'void MTPStorage_SD::ScanDir(uint32_t)':
    /home/dean/Desktop/arduino-1.8.9/hardware/teensy/avr/libraries/MTP_t4-master/src/MTP_Storage.cpp:180:37: error: conversion from 'FsFile' to non-scalar type 'File {aka File32}' requested
             File child = f_.openNextFile();
    /home/dean/Desktop/arduino-1.8.9/hardware/teensy/avr/libraries/MTP_t4-master/src/MTP_Storage.cpp: In member function 'virtual uint32_t MTPStorage_SD::Create(uint32_t, bool, const char*)':
    /home/dean/Desktop/arduino-1.8.9/hardware/teensy/avr/libraries/MTP_t4-master/src/MTP_Storage.cpp:333:38: warning: large integer implicitly truncated to unsigned type [-Woverflow]
           OpenFileByIndex(ret, FILE_WRITE);
    In file included from /home/dean/Desktop/arduino-1.8.9/hardware/teensy/avr/libraries/MTP_t4-master/src/MTP.cpp:30:0:
    /home/dean/Desktop/arduino-1.8.9/hardware/teensy/avr/libraries/MTP_t4-master/src/MTP.cpp: In member function 'void MTPD::read_until_short_packet()':
    /home/dean/Desktop/arduino-1.8.9/hardware/teensy/avr/libraries/MTP_t4-master/src/MTP.cpp:431:42: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
             done = *((uint32_t *) data_buffer) < MTP_RX_SIZE;
    This is beyond my capabilities unfortunately.
    The TeensySdioDemo example provided in the beta version of SdFat works fine.
  11. #86
    2,515
    Quote Originally Posted by xenington View Post
    This is a consequence of using SdFat-Beta together with SdFat.
    Please open SdFat-Beta and rename SdFat.h into SdFat-Beta.h
    You can use also SdFat (as you do) but then there is no ExFat support (which my application needs) and the "FsFile" must be converted to "File".
    At the moment I still debug some issues with copying files from PC to Teensy and to make sure it still works also on T3.6.
    keep an eye on Github updates.
  12. #87
    Making some progress.
    All compilation errors disappear after making the following changes:
    MTP_storage.cpp....line137....change "File" to "FsFile"
    MTP_storage.cpp....line180....change "uint8_t" to "oflag_t"
    MTP_storage.h....line158....change "uint8_t" to "oflag_t"
    However, some warnings sometimes appear (not always):
    In file included from /tmp/arduino_build_920329/sketch/main.cpp:4:0:
    /home/dean/arduino-1.8.10/hardware/teensy/avr/libraries/MTP_t4/src/MTP.h:64:70: warning: 'used' attribute ignored [-Wattributes]
    In file included from /home/dean/arduino-1.8.10/hardware/teensy/avr/libraries/MTP_t4/src/MTP.cpp:30:0:
    /home/dean/arduino-1.8.10/hardware/teensy/avr/libraries/MTP_t4/src/MTP.cpp: In member function 'void MTPD::read_until_short_packet()':
    /home/dean/arduino-1.8.10/hardware/teensy/avr/libraries/MTP_t4/src/MTP.cpp:431:42: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
    IDE fails to upload automatically to the Teensy, but pressing the button seems to work (red LED shows activity). However, the Teensy is not found by Nautilus.
    Hope this helps. I will keep watching Github for updates.
  13. #88
    2,515
    updated GitHub.
    Note: code is only tested with Teensy4.0 and Windows 10.
    Code for T3.x is included but not tested (code has worked in the past with Bill Greiman`s SdFs, which he is not supporting anymore. therefor switch to SdFat-beta).
  14. #89
    2,515
    Latest version is on GitHub https://github.com/WMXZ-EU/MTP_t4
    despite name I tested it also on T3.6
    it can be configured to use SdFat instead of SdFat-beta, and using SDIO or SPI (src/MTP_config.h)
  15. #90
    Oct 2015
    Vermont, USA
    207
    Does this generate an emulated serial port or a real one? Browsing the code it seems to generate an emulated one...please correct me if I'm wrong.
    Chip
  16. #91
    Oct 2015
    Vermont, USA
    207
    Also, for use with Teensy 3.6, I assume that I copy the "copy-of-core" files over to the Teensy3 core?
    Assuming that this was the right thing to do (and after making the other changes that you said in your readme), I get the following compilation errors:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/usb_dev.h:61:40: error: 'NUM_ENDPOINTS' was not declared in this scope
     extern uint16_t usb_rx_byte_count_data[NUM_ENDPOINTS];
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/usb_dev.h: In function 'uint32_t usb_rx_byte_count(uint32_t)':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/usb_dev.h:66:25: error: 'NUM_ENDPOINTS' was not declared in this scope
             if (endpoint >= NUM_ENDPOINTS) return 0;
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/usb_dev.h:67:16: error: 'usb_rx_byte_count_data' was not declared in this scope
             return usb_rx_byte_count_data[endpoint];
    Any suggestions for how I move forward?
    Chip
  17. #92
    2,515
    Sorry, copy-to-core only for teensy 4.0 (will add that to Instruction) cores/teensy3 remains as is.
  18. #93
    Oct 2015
    Vermont, USA
    207
    So, if we're not overwriting the Teensy3 usb_desc.h, we're going to get emulated serial, not real serial, right?
  19. #94
    Dec 2013
    262
    @ chipaudette
    Arduino-1.8.10
    Teensyduino 1.49
    Teensy 3.6 [all Teensy 3.x series]
    Unfortunately it doesn't look good, in the boards.txt file [ MS WIN10 C:\--------\arduino-1.8.10\hardware\teensy\avr ] I see this:
    teensy36.menu.usb.mtp=MTP Disk (Experimental)
    teensy36.menu.usb.mtp.build.usbtype=USB_MTPDISK
    teensy36.menu.usb.mtp.fake_serial=teensy_gateway
  20. #95
    Dec 2013
    262
    @ WMXZ
    Any reasons for this #elif defined(USB_MTPDISK_)<--underscore still in copy-of-core/usb_desc.h
    #elif defined(USB_MTPDISK)
      #define VENDOR_ID             0x16C0
      #define PRODUCT_ID            0x04D1
      #define MANUFACTURER_NAME     {'T','e','e','n','s','y','d','u','i','n','o'}
      #define MANUFACTURER_NAME_LEN 11
      #define PRODUCT_NAME          {'T','e','e','n','s','y',' ','M','T','P',' ','D','i','s','k'}
      #define PRODUCT_NAME_LEN      15
      #define EP0_SIZE              64
      #define NUM_INTERFACE		      2
      #define NUM_ENDPOINTS         4
      #define SEREMU_INTERFACE      1	// Serial emulation
      #define SEREMU_TX_ENDPOINT    2
      #define SEREMU_RX_ENDPOINT    2
      #define SEREMU_TX_SIZE        64
      #define SEREMU_RX_SIZE        32
      #define SEREMU_TX_INTERVAL    1	 // TODO: is this ok for 480 Mbit speed
      #define SEREMU_RX_INTERVAL    2	 // TODO: is this ok for 480 Mbit speed
      #define ENDPOINT2_CONFIG	ENDPOINT_RECEIVE_INTERRUPT + ENDPOINT_TRANSMIT_INTERRUPT
      #define MTP_INTERFACE         2 // MTP Disk
      #define MTP_TX_ENDPOINT       3
      #define MTP_RX_ENDPOINT       3
      #define MTP_EVENT_ENDPOINT    4
      #define MTP_TX_SIZE_480       512
      #define MTP_RX_SIZE_480       512
      #define MTP_TX_SIZE_12        64
      #define MTP_RX_SIZE_12        64
      #define MTP_EVENT_SIZE        16
      #define MTP_EVENT_INTERVAL    1
      #define ENDPOINT3_CONFIG	ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
      #define ENDPOINT4_CONFIG	ENDPOINT_RECEIVE_INTERRUPT + ENDPOINT_TRANSMIT_INTERRUPT  // ????
      #define EP0_SIZE		64
      #define MTP_INTERFACE		1	// MTP Disk
      #define MTP_TX_SIZE		64
      #define MTP_RX_SIZE		64
      #define MTP_EVENT_INTERVAL	10
      #define SEREMU_INTERFACE      2	// Serial emulation
      #define SEREMU_TX_ENDPOINT    1
      #define ENDPOINT1_CONFIG	ENDPOINT_TRANSMIT_ONLY
      #define ENDPOINT2_CONFIG	ENDPOINT_RECEIVE_ONLY
      #define ENDPOINT3_CONFIG	ENDPOINT_TRANSMIT_AND_RECEIVE
      #define ENDPOINT4_CONFIG	ENDPOINT_RECEIVE_ONLY
  21. #96
    2,515
    No,
    I only kept the original defines and added the underscore so they will never be activated.
  22. #97
    2,515
    Quote Originally Posted by chipaudette View Post
    both Teensy3 and Teensy4 use Seremu.
    For an USB agnostic, like myself, it was easier to port MTP from Teensy3 to Teensy4 when using Seremu and not true Serial.
    After having it working, maybe one could try to replace Seremu with Serial.
    Unfortunately, the examples in usb_desc.h are only partially helpful, as Paul uses different complexities in different occasions without explanation and a little bit more reverse engineering is required.
    Eg: USB_SERIAL uses
      #define DEVICE_CLASS		2	// 2 = Communication Class
    but USB_SERIAL_HID uses
    #elif defined(USB_SERIAL_HID)
      #define DEVICE_CLASS		0xEF
      #define DEVICE_SUBCLASS	0x02
      #define DEVICE_PROTOCOL	0x01
    So Paul uses Misc (0xEF) as device class code and not 0x03. (https://www.usb.org/defined-class-codes)
    and USB_MIDI_SERIAL defines NO device class code
    there are also inconsistencies with
      #define CDC_IAD_DESCRIPTOR	1
    defined in USB_MIDI_SERIAL and USB_HID_SERIAL but not in USB_SERIAL
    A lot of these differences could simply be a left over from Teensy3 and without consequences, but to know requires understanding of all the different USB implementation.
  23. #98
    Dec 2013
    262
    Hey I'm working on this right now, not sure if this is all correct yet
      #define EP0_SIZE		64
      #define NUM_USB_BUFFERS	20
      #define MTP_INTERFACE		0	// MTP Disk
      #define ENDPOINT1_CONFIG	ENDPOINT_TRANSIMIT_ONLY
    #elif defined(USB_MTPDISK_SERIAL)
      #define PRODUCT_ID		0x0489 // NOT SURE ABOUT 0x0489, Perhaps this should be 0x04D1 ??
      #define PRODUCT_NAME		{'T','e','e','n','s','y',' ','M','T','P',' ','D','i','s','k','/','S','e','r','i','a','l'}
      #define PRODUCT_NAME_LEN	    22
      #define EP0_SIZE		        64
      #define NUM_ENDPOINTS         7 // TODO
      #define NUM_USB_BUFFERS	    30
      #define NUM_INTERFACE		    3
      #define CDC_STATUS_INTERFACE	1
      #define CDC_DATA_INTERFACE	2	// Serial
      #define CDC_ACM_ENDPOINT	    5
      #define CDC_RX_ENDPOINT       6
      #define CDC_TX_ENDPOINT       7
      #define CDC_ACM_SIZE          16
      #define CDC_RX_SIZE           64
      #define CDC_TX_SIZE           64
      #define ENDPOINT5_CONFIG  ENDPOINT_TRANSIMIT_ONLY         // CDC_ACM_ENDPOINT	     5
      #define ENDPOINT6_CONFIG  ENDPOINT_RECEIVE_ONLY           // CDC_RX_ENDPOINT       6
      #define ENDPOINT7_CONFIG  ENDPOINT_TRANSIMIT_ONLY         // CDC_TX_ENDPOINT       7
    in boards.txt file, need this edit for teensy 3.6:
    teensy36.menu.usb.mtpserial=MTP Disk (Experimental) + Serial
    teensy36.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
    This will need a fix:
    #if !defined(USB_MTPDISK)
      #error "You need to select USB Type: 'MTP Disk (Experimental)'"
    2,515
    For Teensy3 you can use the descriptor file made by yoonghm on his GitHub site.
    Im more interested in Teeny4
  25. #100
    Dec 2013
    262
    Oh yes I forgot to mention the above code belongs to ---\hardware\teensy\avr\cores\teensy3 usb_desc.h
    and there is a typo ENDPOINT_TRANSIMIT_ONLY replace with ENDPOINT_TRANSMIT_ONLY
    NOTE: untested code yet
    EDIT:
    Fix for MTP_Storage.h and MTP.h
    #if !defined(USB_MTPDISK) && !defined(USB_MTPDISK_SERIAL)
    #error "You need to select USB Type: 'MTP Disk (Experimental)' or 'MTP Disk (Experimental) + Serial'"
