#elif defined(USB_MTPDISK)
#define VENDOR_ID 0x16C0
#define PRODUCT_ID 0x04D1
#define MANUFACTURER_NAME {'T','e','e','n','s','y','d','u','i','n','o'}
#define MANUFACTURER_NAME_LEN 11
#define PRODUCT_NAME {'T','e','e','n','s','y',' ','M','T','P',' ','D','i','s','k'}
#define PRODUCT_NAME_LEN 15
#define EP0_SIZE 64
#define NUM_ENDPOINTS 4
#define NUM_USB_BUFFERS 20
#define NUM_INTERFACE 2
#define MTP_INTERFACE 0 // MTP Disk
#define MTP_TX_ENDPOINT 3
#define MTP_TX_SIZE 64
#define MTP_RX_ENDPOINT 3
#define MTP_RX_SIZE 64
#define MTP_EVENT_ENDPOINT 4
#define MTP_EVENT_SIZE 16
#define MTP_EVENT_INTERVAL 10
#define SEREMU_INTERFACE 1 // Serial emulation
#define SEREMU_TX_ENDPOINT 1
#define SEREMU_TX_SIZE 64
#define SEREMU_TX_INTERVAL 1
#define SEREMU_RX_ENDPOINT 2
#define SEREMU_RX_SIZE 32
#define SEREMU_RX_INTERVAL 2
#define ENDPOINT1_CONFIG ENDPOINT_TRANSIMIT_ONLY
#define ENDPOINT2_CONFIG ENDPOINT_RECEIVE_ONLY
#define ENDPOINT3_CONFIG ENDPOINT_TRANSMIT_AND_RECEIVE
#define ENDPOINT4_CONFIG ENDPOINT_RECEIVE_ONLY
#elif defined(USB_MTPDISK_SERIAL)
#define PRODUCT_ID 0x0489 // NOT SURE ABOUT 0x0489, Perhaps this should be 0x04D1 ??
#define PRODUCT_NAME {'T','e','e','n','s','y',' ','M','T','P',' ','D','i','s','k','/','S','e','r','i','a','l'}
#define PRODUCT_NAME_LEN 22
#define EP0_SIZE 64
#define NUM_ENDPOINTS 7 // TODO
#define NUM_USB_BUFFERS 30
#define NUM_INTERFACE 3
#define CDC_IAD_DESCRIPTOR 1
#define CDC_STATUS_INTERFACE 1
#define CDC_DATA_INTERFACE 2 // Serial
#define CDC_ACM_ENDPOINT 5
#define CDC_RX_ENDPOINT 6
#define CDC_TX_ENDPOINT 7
#define CDC_ACM_SIZE 16
#define CDC_RX_SIZE 64
#define CDC_TX_SIZE 64
#define ENDPOINT5_CONFIG ENDPOINT_TRANSIMIT_ONLY // CDC_ACM_ENDPOINT 5
#define ENDPOINT6_CONFIG ENDPOINT_RECEIVE_ONLY // CDC_RX_ENDPOINT 6
#define ENDPOINT7_CONFIG ENDPOINT_TRANSIMIT_ONLY // CDC_TX_ENDPOINT 7
