Results 1 to 6 of 6
Thread: Teensy driving led strip crashes when adding audio
    Apr 2017
    2
    I've got a teensy 3.6 running a modified version of the "DemoReel100" example in the FastLED library, driving a strip of 150 WS2812B LEDs. When I attempt to add generated code from the teensy audio GUI webpage, it will run for a little bit. Once I go to a certain pattern ("sinelon") it just completely crashes once the lights hit the end.
    main code:
    AudioInputI2S            i2s1;           //xy=583,367
    AudioAnalyzeRMS          rms1;           //xy=865,387
    AudioConnection          patchCord1(i2s1, 0, rms1, 0);
    AudioControlSGTL5000     audioShield;     //xy=1047,245
    #include "FastLED.h"
    #define NUM_LEDS 150
    #define BUTTON_PIN 4
    #define FASTLED_ALLOW_INTERRUPTS 0
    CRGB leds[NUM_LEDS];
    uint8_t movement = 0;
    uint8_t patternNumber = 0;
    long lastDebounceTime = 0;
    uint8_t ccc = 0;
    int audio = 0;
    int cylonNumber = 0;
      FastLED.addLeds<WS2812B, 3, GRB>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
      FastLED.setBrightness(96);
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(BUTTON_PIN), nextPattern, FALLING);
    typedef void (*funcptr[]) ();
    funcptr patterns = {rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm, randomRainbow, randomRG, cylon, candyCane, snowFlake};
      patterns[patternNumber]();
      FastLED.show();
      FastLED.delay(1000 / 120);
      movement++;
    #define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
    void nextPattern()
      if ((millis() - lastDebounceTime) > 300) {
        // add one to the current pattern number, and wrap around at the end
        patternNumber = (patternNumber + 1) % ARRAY_SIZE( patterns);
        lastDebounceTime = millis();
    patterns:
    void rainbow() {
      fill_rainbow( leds, NUM_LEDS, movement, 2);
    void rainbowWithGlitter()
      // built-in FastLED rainbow, plus some random sparkly glitter
      rainbow();
      addGlitter(80);
    void confetti()
      // random colored speckles that blink in and fade smoothly
      fadeToBlackBy( leds, NUM_LEDS, 10);
      int pos = random16(NUM_LEDS);
      leds[pos] += CHSV( movement + random8(64), 200, 255);
    void sinelon()
      // a colored dot sweeping back and forth, with fading trails
      fadeToBlackBy( leds, NUM_LEDS, 20);
      int pos = beatsin16(13, 0, NUM_LEDS);
      leds[pos] += CHSV( movement, 255, 192);
    void bpm()
      // colored stripes pulsing at a defined Beats-Per-Minute (BPM)
      uint8_t BeatsPerMinute = 62;
      CRGBPalette16 palette = PartyColors_p;
      uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
      for ( int i = 0; i < NUM_LEDS; i++) { //9948
        leds[i] = ColorFromPalette(palette, movement + (i * 2), beat - movement + (i * 10));
    void juggle() {
      // eight colored dots, weaving in and out of sync with each other
      byte dothue = 0;
      for ( int i = 0; i < 8; i++) {
        leds[beatsin16(i + 7, 0, NUM_LEDS)] |= CHSV(dothue, 200, 255);
        dothue += 32;
    void randomRainbow()
      for (int i = 0; i < NUM_LEDS; i++) {
        leds[i] = CHSV(random(0, 255), 255, 255);
      delay(50);
    void randomRG()
      if (random(0, 100) > 75) {
        leds[0] = CRGB(255, 0, 0);
      else {
        leds[0] = CRGB(0, 255, 0);
      for (int i = NUM_LEDS; i > 0; i--) {
        leds[i] = leds[i - 1];
      delay(10);
    void cylon() {
      leds[cylonNumber] = CHSV(cylonNumber % 255, 255, 255);
      delay(10);
      cylonNumber++;
      if (cylonNumber > NUM_LEDS) {
        cylonNumber = 0;
    void candyCane() {
      if (ccc < 6) {
        leds[0] = CRGB(255, 255, 255);
      if (ccc > 9) {
        ccc = 0;
      ccc++;
      delay(10);
    void snowFlake()
      leds[random16(NUM_LEDS)] = CRGB(255, 255, 255);
    ////////////////////////////////////internal patterns////////////////////////////////////
    void addGlitter( fract8 chanceOfGlitter)
      if ( random8() < chanceOfGlitter) {
        leds[ random16(NUM_LEDS) ] += CRGB::White;
    Here's a video of the problem. https://www.youtube.com/watch?v=Fjx0_EUO4iI. You can see it hang at the end of the LED strip.
    Does anyone know the cause of this?
    16,282
    Does the crash magically go away if you use a smaller number of LEDs that update in much less than 1 audio block time (2.9 ms)? Perhaps try only 20 or 40 LEDs, just as a simple test?
    Of course also double check your power supply. But in the video I see all the LEDs on long before the problem happens, so power problems seem less likely in this case.
    16,282
    Also, try moving "#define FASTLED_ALLOW_INTERRUPTS 0" before the line where you include FastLED.h.
    Aug 2013
    Gothenburg, Sweden
    291
    Check the following discussion:
    https://github.com/FastLED/FastLED/issues/368
    Apr 2017
    2
    I think mlu got it. I was noticing weird variable corruption when I was printing some random variables to serial. It must have been writing to memory locations related to audio and crashing the teensy. Making sure that index NUM_LEDS was not being modified anywhere, and replacing it with NUM_LEDS-1 seems to have fixed the problem.
    I am experiencing a similar issue. It does seem to have something to do with the audio. I was able to determine the hanging is inside of FastLED.show(); It seems to be random any only occurs when audio is playing. #define FASTLED_ALLOW_INTERRUPTS 0 does seem to change the behavior.
    It also seems to happen when subsequent FastLED.show() calls are made too fast. I was able create a temporary work around by limiting the updates using something like the following. (TimerCounter is just set my millis somewhere else in the code)
    if (TimerCounter - lastShow > 17) // temporary to prevent crash, limit to 60fps
    FastLED.show();
    lastShow = TimerCounter;
