want help about "configure TEENSY act as usb mouse (working independently) "
hello sir,
i want configure teensy to send usb mouse messeges into pc independently during use of a usb optical mouse.
for detail please read bellow.......
when two optical mouses are connected to a pc, both control a single pointer. they have not two pointers.
when two mouse are connected using (two mouse software) ,they can have two pointers. but they will not
working independently. i means if we used 1st mouse to open FILE MENU & placed pointer on list apeared from FILE MENU.then if
we will click on anywhere in same software window using 2nd mouse , FILE MENU will be closed.
please give me your advice about written bellow.,,,,,,,,,,,
if teensy is configured to send mouse dragging/ scroll wheel messege on (x,y) position anywhere in same software window
(not on FILE MENU).will FILE MENU list be closed cause of teensy's interfere? ,,,,,,,,or.........can teensy be configured to act without
disturbing in working of usb optical mouse(which is used during use of teensy's input )?
i want to use teensy & usb mouse together in same software.when teensy is working on software
window, then pointer of use mouse should not be move or affected cause of teensy.(teensy & usb mouse) both should
not affect pointer position eachother.
is it possible?
hello sir,
is it possible?
