Hi all,
I would like to know if there is a relatively simple way to make an UDP interface that can replace the current "Serial" transport layer in the MIDI_Libray in order to use the beauty of the library itself on the midi message's manipulation (callbacks, etc.) on a faster and more flexible configuration.
Here I'm not referring to the Apple-Midi standard.
I would like to use the midi-library in a setup that require "udp multicast" and involve the ipMIDI software ( http://www.nerds.de/en/ipmidi.html ).
I know that a previous problem that did not allowed use of udp multicast has been resolved on teensyduino 3.6 release.
(https://forum.pjrc.com/threads/42468-UDP-Multicast-issues?highlight=udp+multicast).
Please, can someone point me in the right directions?
Thank you!
Thank you!
