To connect power socket
tensian
I have been reading about how to put external feed in teensy, but I do not have it clear at all ...
I think option 3 here .. http://www.pjrc.com/teensy/external_power.html
Allows me to use the USB power (that is to say, I can still feed the screen I have connected) or the external or both at the same time and the teensy will choose, in the latter case.
is this correct?
In the drawing of the link appears a teensy different from mine, I have the 3.6 and the truth is that I do not know how to do it.
I made a drawing of how I think it is, but it is quite possible that this bad , someone could confirm it.
regards
You need to connect it like this (and cut the VIN VUSB pad):
The picture shows a Teensy 3.2 but it's the same for Teensy 3.6
Thank you very much HWGuy
I could confirm that after doing this I will be able to continue using the usb only to continue feeding all the components (screen, sdcard, ect), without the need for external power.
