Hi All.
I’m starting on a Teensy 3.2 project that will use the Audio Library and play sound from the SD card on the Audio shield. It will also drive a DotStar LED string. These LEDs are controlled by MOSI and SCK, but they don’t have a chip select input. Thus, I’d like to put them on a different SPI bus so they aren’t confused by the SD activity on SPI0.
The K20 Sub-Family Reference manual, claims that the device has two SPI modules and the pin multiplexer table shows SPI1_SOUT available on package Pins 2 & 39 (Teensy 3.2 Pins 26, & 0). But, I can’t find pin assignment options for SPI1_SCK. This signal is shown in Table 10-28 but nowhere else.
Interestingly, a different document (K20 Sub-Family Data Sheet: Technical Data) mentions only a “SPI Module” (singular).
So, does the processor chip on Teensy 3.2 have one or two SPI modules? And, if two, what pin(s) can be used for SPI1_SCK?
Thanks in advance.
Greg
Thanks in advance.
Greg
