How interface 74ls245 with 74ls373
Hi, this is a forum for PJRC products, which to the best of my knowledge doesn't include any kit with 8085. However, it is a good source of knowledge so someone MAY be able to help you.
In order to do so, however, they're going to need a lot more information. What you're trying to achieve, your hardware configuration currently and what progress you've made.
Ok, I'm going to be the rude guy and give the one line answer to the one line question as 'with the enable input'
For further advice could you confirm you are actually human and not a spambot trying to get a history, and give a bit more context on the question including why you are asking an 8085 related question on a forum focused on ARM based boards. If the question is real you may get some help here since it's a more general electronics logic question than CPU specific but you are kinda pulling up in a supermarket carpark and hollering 'can anybody replace the throttle body on a 2002 model Ford'. You might get an answer, might not but choice of place pretty much rules out getting a true expert to respond.
